Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 02-15-2011, 07:25 PM   #1
Member#: 165300
2006 WRX
Steel Gray Met.
Default Grimspeed V2 MBC with Grimspeed EBCS (Hybrid)
Hay guys. Im in the process of upgrading my car. here it is so far.
2006 WRX 2.5
20G turbo 2.5 inlet
900 CC injectors
TGV Delets
Un = lenght headers
AP turbo inlet
SPT short ram intake.
STI + size TMIC.
I have both the MBC and EBCS from Grimspeed and I was wondering about doing a hybrid set up. Using the EBCS to control boost at partial and low boost range and use the MBC to control overboost and potential spike issues. I searched and didnt see much on the hybrid idea. But if anybody has any imput im all ears. Im looking for how to set it up, to what to look for while tuning. Please help. THANKS.
WreaKLoosE is offline   Reply With Quote
Old 02-15-2011, 07:55 PM   #2
Member#: 171293
'05 WRX Hybrid
EJ257 w/Blouch 18G 8cm^2
^^^^Discussed in thread above...and it is a sticky in the Engine Management formum.
csmithwrx'05 is offline   Reply With Quote
Old 02-16-2011, 03:15 PM   #3
Member#: 232940
just shows that if you make something a sticky people will all take it as gospel. internet forum sheep.
there is no reason to use both an MBC and an EBCS. Nobody does that except Subaru owners. If you know how to tune the factory boost control system + EBCS it will be responsive. If you are overboosting you need to adjust the turbo dynamics tables and the compensation tables.
arghx7 is offline   Reply With Quote
Old 01-26-2013, 05:51 PM   #4
Member#: 329580
2008 Impreza STI
Spark Silver Metalic
Dont forget that even a properly tuned car can experience boost spike or overboost if driven wrong. If your going 60 in sixth and you give it full throttle you will experience either or both. Turbo cars tend to function smoother in higher rpms. Staying away from the open loop closed loop transition as much as possible is a good thing. You want to try to keep it in boost. THats why we downshift to fourth. It puts us in a good rpm range for the power output when boosting. Just food for thought.
fathaigh is offline   Reply With Quote
FS : /GI: 02-03 wrx V2 Accessport with Asus Eee pc with Access Tuner software Alaskan EJ20 AKIC Private Classifieds 3 03-17-2011 04:17 PM
Best for EBCS or MBC with Turbo Upgrade? Coop1103 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 08-23-2010 11:20 PM
running stock bcs with grimspeed ebcs tune??? punswrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 05-01-2010 03:38 AM
Protune with an EBCS & V2. Advantages?? bluemicamatt AccessPort 8 09-23-2009 07:06 PM
stay with mbc or get ebc? WRXout Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-18-2005 09:48 PM
