Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 01-21-2010, 08:54 PM   #26
seanski06
Member#: 105432
ooooh ok...For some reason I thought everyone on here was using the metal ones (hense the expensive price)
seanski06 is offline   Reply With Quote
Old 01-22-2010, 04:11 AM   #27
kami333
Member#: 22068
00 GF4, 00 GM6
93 GF2
Found the pics!
The dark red (top one in first pic, right one in second) is the 32714AA190 gear. The lighter orange one (bottom one and left one) is 32714AA230.
32714AA190 is the correct one (and is more expensive). Also it was a problem of 28 vs 30 teeth, 30 is the correct count.
PS I have an extra 32714AA230 if anyone wants to buy it from me
kami333 is offline   Reply With Quote
Old 10-29-2010, 03:58 AM   #28
EvenSteven
Member#: 156542
I know this is an old thread. I was just swapping in a 05 Outback XT tranny in to my 02 WRX. It has a final drive of 4.44 i believe. Would i still use the 32714AA190. Or would mine be different? Thanks.
EvenSteven is offline   Reply With Quote
Old 10-29-2010, 01:10 PM   #29
foolio
Member#: 9351
2006 trailblazer SS
black
^^ PMed ya.
foolio is offline   Reply With Quote
Old 10-29-2010, 10:37 PM   #30
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
32714AA190 is the forester 4.44 gear, 32714AA230 is the 4.11 gear. Use the 4.44 gear.
theotherguy is offline   Reply With Quote
Old 10-30-2010, 03:06 PM   #31
Supraru
Member#: 23313
99' 2.5Rs
black
I too had swapping issues but found the problem when putting the case back together. Saw the 3.90 speedo gear was pressed down so I just ordered the 99 2.5 Rs red speedo gear from my parts department. Made sure it sat in the groves properly and rolled with no issue. Zero issues. Glad I didn't overlook that. Always gotta make sure everything spins freely before you put it back in your car!
Supraru is offline   Reply With Quote
Old 10-31-2010, 09:15 PM   #32
EvenSteven
Member#: 156542
The Outback XT does not use the Forester gear. Even though they are both the same final drive. I just found out and ordered the correct one. Contact Jodie at Rallispec if you are attempting this swap. He was very helpful. Thanks all.
Old 11-02-2010, 12:02 AM   #33
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Really? I've been running a forester 4.44 gear in an outaback xt transmission for a year. No problems at all.
Old 04-19-2012, 01:33 PM   #34
crisco555
Member#: 56339
2005 saabaru x 2
"wash me"
similar but different question:
i have a 93 legacy turbo and im using a 03 impreza TS transmission. will i need to convert the newer trans to mechanical vs electronic speed sensor?
crisco555 is offline   Reply With Quote
Old 04-19-2012, 03:46 PM   #35
EvenSteven
Member#: 156542
I believe you would just pull out the Impreza speed sensor and use the speed sensor from the 93 Legacy? But i am not familiar sure with that year transmission. Pull out both sensors and see if they are similar where they plug in and post it here. I am curious.
Old 04-19-2012, 03:50 PM   #36
crisco555
Member#: 56339
2005 saabaru x 2
"wash me"
ok i will report back once i figure it out.
Old 07-10-2012, 12:03 AM   #37
thestory8
Member#: 235561
2005 LGT Wagon
What axles are you running with the LGT trans?
thestory8 is offline   Reply With Quote
Old 07-10-2012, 01:23 AM   #38
EvenSteven
Member#: 156542
I used the 05 LGT center diff which takes the male axels. But i went to a junk yard and pulled the stubs off of a 98 Legacy (automatic) and put them in the center diff. Then i was able to use my 02 WRX axles. The stubs will pop out of the automatic trannys (not the 5spd) and can be used to convert to the older style axles. So you can use both.
Old 01-26-2013, 10:25 AM   #39
vip007
Member#: 344944
2005 Saab 9-2x = WRX
I've got a Saab 9-2X, essentially a rebadged '05 WRX. And last week I got the dreaded p0502 code, which unfortunately translated into the speed sensor gear having been shredded. Cost me an arm and a leg to have it fixed, all for a little piece of plastic.
Wouldn't this be considered a flawed design?
I'm really upset and wanted to write to Subaru. Has anyone done that?
vip007 is offline   Reply With Quote
Old 01-26-2013, 10:50 AM   #40
Supraru
Member#: 23313
99' 2.5Rs
black
Don't write Subaru a letter write Saab a letter. You bought a Saab not a Subaru.
Old 01-27-2013, 12:38 AM   #41
vip007
Member#: 344944
Well, Saab's been out of business since Dec'11. And this is, as I said, an Impreza WRX (made by Fuji Heavy Industries), with a few cosmetic mods.
But I was really trying to find out if anyone who owns a 05'WRX has complained about the speed sensor gear to Subaru.
Old 01-27-2013, 04:29 PM   #42
Supraru
Member#: 23313
99' 2.5Rs
black
I know Saab has been out of business. And you're right it may be an impreza wrx with some cosmetic mods but it doesn't mean anything because the badge on the car says Saab. You said you were going to write subaru a letter but I'm letting you know they aren't going to even care about a Saab owner. Not trying to be a d ick but that is just how business works. We've had Saab owners try to get us to do the control arm recall. They weren't happy when we broke it down to them and told them they don't own a subaru. Not sure what the hard part is to understand about that. I don't write nissan a letter when one of their switches goes bad in a subaru even though the part says nissan. I don't think you're ever going to understand that because you have Saab 9-2= wrx.
That type of code isn't generally a common issue neither is the wear of the plastic gear. Sure it can happen but not common. I can only imagine that kind of wear coming more from not changing the diff fluid. Probably gets dirty and has contaminants grinding between the gear and the pattern between the 3-4 cluster.
Another thing to add, you have a 2005. You are extremely far from any type of warranty. When something goes bad on a car and someone has to put out a lot of money they want to put someone to blame. In reality you're dealing with an older car and things go bad on cars that you have to pay to replace. No car can go it's life without replacing bad or worn parts.
Old 01-29-2013, 12:06 AM   #43
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
I've had mine in the LGT tranny for probably almost 4 years now.... still running strong
IllNastyImpreza is offline   Reply With Quote
Old 02-12-2013, 08:58 PM   #44
Swimminginblues
Member#: 336702
Hey I was just reading over this post about the speedo sensor swap. It sounded like you had to split the tranny case in order to do the work, is that right? I just did an lgt swap and we didn't realize the issue until we had everything going back in. I have been driving around in limp mode and relying on my spacial reasoning to avoid speeding tickets. I could live without the speedo, but I cannot live with the 5000 rev limit! In the end, it sounds like I need to split the old case, remove the shaft assembly, score another gear with 30 teeth, split the new case and instal. I hoped to avoid having to pull them apart if possible. Could you have done it without splitting the cases?
More importantly, could I? I am just looking for suggestions. I am gonna do it the right way no matter what, I just don't want to take more steps if I don't have to. I plan to take step by step pics for a later posting.
Swimminginblues is offline   Reply With Quote
Old 02-13-2013, 01:59 AM   #45
EvenSteven
Member#: 156542
Yah, you pretty much have to split the case to install the speedo gear. You also have to buy all the stuff... shaft, the clips, the seals and the plastic gear. Its sucked when i found out too. Not too hard to do though. Use the right torque specs on the bolts when you put it back together.. And use Anaerobic sealer instead of RTV. Make sure it is perfectly clean before you seal it. Wire brush and then some sort of dryer, like carb cleaner.
Old 02-13-2013, 01:01 PM   #46
Swimminginblues
Member#: 336702
that sucks, but, of course, I'll do it either way. Thanks for the heads up. this was a good, helpful thread
F.S.(WA) 05' LGT 5spd, Full wrx Swap kit, Low Miles morrocco88 Drivetrain 12 11-01-2010 11:48 PM
RS to Wrx swap speedo problem Rdwrc Subaru Conversions 8 07-26-2006 12:36 PM
LGT turbo swap problems yebokmj Subaru Conversions 11 05-22-2006 08:07 PM
speedo gear problem mikaust Transmission (AT/MT) & Driveline 2 12-05-2004 07:43 PM
Speedo quit, CEL: bad speed sensor or speedo gear? superg Transmission (AT/MT) & Driveline 4 06-20-2004 04:49 PM
