Old 06-13-2012, 04:23 PM   #226
Webs1007
Member#: 315584
WOW!
Webs1007 is offline   Reply With Quote
Old 11-30-2012, 01:57 AM   #227
DoomsdayFAN
Member#: 320580
The two OPs were great reads. Before reading them, I was pretty much sold on methanol. After reading this thread, I'm now pretty much 100% leaning toward denatured alcohol injection. A 50/50 mix with distilled water seems like the best bet for me. I look forward to it.
So, I guess now my first mods will most likely be Intake/Exhaust/Tune/Alcohol Injection. That seems like a really great place to start. And sounds like I'll gain some really nice power from it.
Then later down the road I can go for more in-depth mods.
DoomsdayFAN is offline   Reply With Quote
Old 12-01-2012, 04:24 PM   #228
06BlueDemonSTi
Member#: 285897
2006 STi
Can I still tap into the boost gauge hose from the progressive controller since it's already tee to the bpv?
06BlueDemonSTi is offline   Reply With Quote
Old 01-02-2013, 04:39 AM   #229
cRashtEstDumy
Member#: 291602
2007 Limited STI#464
Mine is taped into my boost gauge line right under my dash and works fine!
cRashtEstDumy is offline   Reply With Quote
Old 01-08-2013, 01:00 AM   #230
Maniac007
Member#: 336045
Default Looking for the best bang for my buck...
Which system is the best? Is the aquamist worth the extra coin? Also, I have been having challenges finding a good tuner (that specializes on Subarus) in San Francisco...preferably a tuner who has done several Meth Injection installs...does anyone have any suggestions? Thanks!
Maniac007 is offline   Reply With Quote
Old 01-27-2013, 01:38 AM   #231
ABeastinWRX
Member#: 239469
2004 WRX
Thanks for this answered a lot of questions.
ABeastinWRX is offline   Reply With Quote
Old 08-25-2013, 12:34 AM   #232
Nola05STI
Member#: 366419
2005 WRX STI
Great write up, thanks!
Nola05STI is offline   Reply With Quote
Old 10-09-2013, 05:13 PM   #233
dmb882
Member#: 370200
Very informative write up! Thanks!
dmb882 is offline   Reply With Quote
Old 10-22-2013, 12:22 AM   #234
BJJMark95
Member#: 371004
2013 STi Hatch
Great write up - now it's making me consider this as a phase in my mod plan simply for the "conservative tune" application to help keep my daily driver safer at stage 2
BJJMark95 is offline   Reply With Quote
Old 10-22-2013, 01:18 PM   #235
Lukas_vee23
Member#: 342863
just a quick question. if running this setup, i have the manual option to spray this mixture?
(just wanted to know, i know nothing about this or nitrous but just want to clear this up.)
and can this setup run with e85, or is the octane rating too high for stock internals?
Lukas_vee23 is offline   Reply With Quote
Old 11-16-2013, 07:04 PM   #236
erok81
Member#: 300717
2004 WRX
JBP
I'm going to try here before I create a new thread.
I have a question on nozzle placement. I am running a Spearco TMIC and speed density. I have my IAT mounted in the lower end tank right before the TB. I've read that you should install the nozzle in a similar location. I could mount it next to the IAT or on the upper side of the end tank. But either way I am going to spraying onto the IAT - that can't be good not only for liquid on the sensor but also messing with temp readings.
My next option is install the nozzle in the silicon coupler between the IC and the throttle body. That would be about 2-3 inches after the IAT.
Edit: started a new thread so others could get the same info on a search.
erok81 is offline   Reply With Quote
Old 01-05-2014, 08:50 PM   #237
Steve1219
Member#: 377895
Steve1219 is offline   Reply With Quote
Old 01-12-2014, 10:43 AM   #238
nevadaflat4
Member#: 378477
great info thanks guys
nevadaflat4 is offline   Reply With Quote
Old 01-20-2014, 05:59 PM   #239
Aladeenster
Member#: 374582
2008 Sti
Matte Orange
Bump Question:
I understand that the safest way of tuning methanol is by having it go with your injector duty cycle. I have a question for when you are going up hills and not going in boost but when your duty cycle is high. Would that cause the motor to flood?
I think that is what's happening to mine, causing the AFR's to go wacky and cause misfires.
Can someone please chime in.
Aladeenster is offline   Reply With Quote
Old 01-21-2014, 08:14 PM   #240
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Originally Posted by Aladeenster View Post
Bump Question:
At what IDC is your system spraying? If you have the threshold set high enough you should always be in boost when the meth kicks in.
Old 01-22-2014, 03:06 AM   #241
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
Bump Question:
IDC is directly related to "fuel flow vs load", regardless of 160mph with a head wind or going uphill at 40mph towing a heavy load, it demands the same IDC. Inversely, you can cruise at 160mph downhill with a tail wind or free-wheeling down hill. The idc will be low and wmi will not be triggered. If the system reads the IDC accurately.
Bump Question:
What system do you have?
Aquamist is offline   Reply With Quote
Old 01-22-2014, 03:56 PM   #242
Aladeenster
Member#: 374582
2008 Sti
Matte Orange
Originally Posted by Aquamist View Post
IDC is directly related to "fuel flow vs load", regardless of 160mph with a head wind or going uphill at 40mph towing a heavy load, it demands the same IDC. Inversely, you can cruise at 160mph downhill with a tail wind or free-wheeling down hill. The idc will be low and wmi will not be triggered. If the system reads the IDC accurately. What system do you have?
I have hfs3. I did not tune it so I don't know the details of the idc.
Old 02-09-2014, 12:34 PM   #243
Aquamist
NASIOC Manufacturer
Member#: 110029
If you are not tuning the system, reduce the injectant to 10-15% of fuel flow. I believe you are injecting too much beyond the engine management's ability to trim fuel.
Old 03-08-2014, 11:33 PM   #244
Young_Driven_STI
Member#: 381305
great write up
Young_Driven_STI is offline   Reply With Quote
Old 06-05-2014, 12:12 PM   #245
DECKER425
Member#: 369747
2012 STI Limited
Satin pear white
Smile Some advice
Is thre any way to tell what mixture you are tuned for?
Thanks in advance for any / all help
Scott
DECKER425 is offline   Reply With Quote
Old 07-02-2014, 09:14 PM   #246
rays_240
Member#: 395226
Awesome, this thread was really helpful
rays_240 is offline   Reply With Quote
Old 07-02-2014, 10:05 PM   #247
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Scott
If you know what nozzles you have installed and the gain you can estimate it. Or you can measure it by forcing 100% flow and measuring the output. From that you can calculate what ratio of water/meth:Fuel % you are injecting.
For the actual % meth you where tuned for you would have to ask the tuner or previous owner or whoever fills the meth tank if it isn't you.
Old 07-10-2014, 09:11 PM   #248
Gienek
Member#: 295695
2011 STi
Would you have a list or links to qualified and experienced installers/tuners in the USA? ...thanks in advance.
Gienek is offline   Reply With Quote
Old 10-10-2014, 01:02 PM   #249
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Glad to see this thread is still providing answers to people years after I wrote it. I am unfortunately out of the "tuning" game now...at least for a few years. I will probably pick up a BRZ sometime, but for now done with upgrading my cars. But thanks to everyone for continuing to breath life into this.
DonkeyPunch is offline   Reply With Quote
Old 01-15-2015, 11:03 AM   #250
ChamfornetRsTi
Member#: 383775
Impreza GC8 Thanks for the info
I know it's an old thread but just wanted to say Big thanks to DP and Davenow for the informative thread. It took a few days but just finished reading the whole thread. It provided great info and helped me make an informed decision. I have a 93impreza with an ej20g and a "550" rob tune with apexi intake,wrapped headers and up pipe, invidia bell mouth dp, 3"exhaust, walboro 255, 06sti coils and injectors. After many tweeks, found that the custom intercooler diffuser and the turbo blanket have helped the most to deter the flashing knock light up high but still it comes on, albeit sporadically, at full boost. I have decided to go 100% water injection based on the read. From the calculators I saw here the equation for 100% water went .5-1cc x bhp = 170-340cc x 340 estimated hp at crank or 5-15% water to fuel ratio= 105-315cc water to 2100cc total fuel available thru injectors. I'm thinking a pressure compensated 220cc's of water would put me right in the middle of that range. Would these be correct calculations?
Thanks in advanced for any and all help.
ChamfornetRsTi is offline   Reply With Quote
water / methanol injection kit -new or used blazin sti Private 'Wanted' Classifieds 3 05-27-2006 08:01 PM
Water/Methanol Injection or Race Fuel or Both ejh25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-28-2005 06:35 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-01-2004 05:52 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-01-2004 04:51 PM
