Old 06-08-2012, 11:41 PM   #26
markesc
Member#: 164875
2007 WRXTR blouch20G
This was huge problem on mine new...it's gone away as the car has aged...
markesc is offline   Reply With Quote
Old 06-09-2012, 12:05 AM   #27
feeltheneed
Member#: 205143
2008 WRX
Originally Posted by sweetsatin
Why would you ever downshift to first at 20-30 mph
Autocross comes to mind...
feeltheneed is offline   Reply With Quote
Old 01-27-2013, 02:11 AM   #28
Blue98leg
Member#: 65036
2013 WRX
Sorry to bring this back from the dead. My 2013 WRX is also having this issue, even at low RPMs it won't let me into 4th if I shift quickly. Has anyone gotten resolution from the dealers for this?
I also had alot of trouble with reverse (requiring me to go into 2nd pretty much 75% of the time before shifting to reverse) but took advice from another thread to unscrew the shift knob one turn and that helped alot but i have no idea why.
Blue98leg is offline   Reply With Quote
Old 01-27-2013, 02:42 AM   #29
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
I can't see why unscrewing the shift knob would do anything. The knob itself isn't connected to anything of importance.
My car has definitely began to shift better with age. You might just need to break it in a little bit. I've also heard that changing out your transmission fluid can really smooth out your shifts.
Check out this thread. Lots of good info here (http://www.clubwrx.net/forums/transm...reatest-5.html)
xabre1200 is offline   Reply With Quote
Old 01-27-2013, 02:46 AM   #30
Blue98leg
Member#: 65036
2013 WRX
I know, it sounds crazy and maybe its only a placebo but I swear after I unscrewed the crazy torqued shift knob from the factory a bit the reverse gear is working fine.
Old 01-27-2013, 02:52 AM   #31
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
It's possible. I noticed when I was putting on a new shift knob and tried to drive my car the next day my clutch pedal began to have a slight vibration when I let it up for about 2 mins and it went away ever since. I think this happens every time I put on a new shift knob... pretty weird.
Old 01-27-2013, 03:05 AM   #32
Blue98leg
Member#: 65036
2013 WRX
Yeah. Its the not being able to quickly shift into 4th consistently that worries me.
Old 01-27-2013, 12:48 PM   #33
MaddMax
Member#: 9264
2016 BMW M235i 6MT
Try this:
3-4 Shift
1) Invert hand with the thumb facing down.
2)Wrap hand around front of shift knob and pull back. It should literally fall into gear with no resistance.
This is the correct method to shift the 3-4 on any manual. It keep you from pulling back and towards your body which can result in getting hung up on "the gate" or even worse, inadvertently grabbing 2nd
Getting into reverse
1) Car must be stopped.
2) Shift into 1st and creep fractionally forward. 1" or 6", it doesn't matter.
3) Clutch in and shift into reverse. It should do it very easily.
Most every manual behaves in this manor. Some call it a reverse lock-out and others blame the straight cut reverse. Either way, do the method I described and the car should go into reverse easily.
MaddMax is offline   Reply With Quote
Old 01-27-2013, 01:05 PM   #34
Blue98leg
Member#: 65036
2013 WRX
Thanks for the advice. I do hold the shifter as you describe (don't pistol grip). It has happened enough (but isn't consistent) that I know I'm not pushing it towards 2nd.
Once I adjusted my knob, reverse is working like a charm ( as crazy as it sounds)
Old 01-28-2013, 08:00 PM   #35
90crxfreak
Member#: 318642
2012 WRX Premium
Originally Posted by xabre1200 View Post
...tried to drive my car the next day my clutch pedal began to have a slight vibration....
You get this too?!?!? My dealership thinks i'm crazy! It feels almost as its pulsating!
I've also noticed that double clutching works very well with my WRX.
90crxfreak is offline   Reply With Quote
Old 02-13-2013, 09:04 AM   #36
2011scoobywrx
Member#: 344372
2011 wrx
blue
I have had that same issue shifting into 4th on harder acceleration! I actually put it in 2nd one time and now i am cautious. It seems like most of the time it almost wants to guide itself into 2nd rather than 4th. Weird
2011scoobywrx is offline   Reply With Quote
Old 02-27-2013, 04:23 PM   #37
rugger17
Member#: 248147
2010 WRX
I finally just installed my kartboy bushings and am just now experiencing the 3rd to 4th gear problem! I am not even shifting at high rpms, its just regular driving.
Did I over tighten something when i installed these bushings? i never had this shift problem prior to installing the kartboy parts.
rugger17 is offline   Reply With Quote
Grinding noise when shifting into 4th gear? Help cvalianos02 Newbies & FAQs 24 10-05-2010 04:20 PM
shifting into 4th gear issues WheelieMonster Transmission (AT/MT) & Driveline 21 08-17-2009 03:52 PM
High Pitch Grinding Sound When Shifting Into 4th Gear mcrawford Newbies & FAQs 3 10-09-2007 01:10 PM
Hard shifting into 4th. tunedlevin Transmission (AT/MT) & Driveline 0 10-20-2005 10:10 PM
Hard time shifting into 4th and 5th jsmithjr732 Transmission (AT/MT) & Driveline 4 01-08-2003 05:05 PM
