Old 01-25-2013, 10:04 AM   #1
What v8
Member#: 254718
Default fuel pump took a dump
so the other day my car started to bog down then died, i can key it on and not hear the fuel pump anymore. I figured my fuel pump went out so i bought one off a kid locally. It had a walbro 255 in it and thats what i thought i got off the kid. after i purchased it he said it was a mgp racing fuel pump but it was still 255lph. so i swapped them out...nothing. still no fuel, and i cant hear the pump run when i turn the car on. Should i buy a new walbro 255 and try that?
What v8 is offline   Reply With Quote
Old 01-25-2013, 10:04 AM   #2
What v8
Member#: 254718
Fuel system upgrades are just the fuel pump and 1000cc injectors
Old 01-25-2013, 10:51 AM   #3
white240hatch
Member#: 95556
2012 WRX 5dr
not sure if this helps, but my old 2002 wrx did the same thing. i spent like 10hours to diag the problem and came up with nothing. I ended up running a wire from the pump to the ignition wire going to the fuse boxs and it worked for 40k miles before i sold it. I am not sure what the correct fix would be but that was my remedy
white240hatch is offline   Reply With Quote
Old 01-25-2013, 11:37 AM   #4
tuzzio
Member#: 292532
05 STI
Check all your fuses first.
tuzzio is offline   Reply With Quote
Old 01-25-2013, 11:43 AM   #5
the suicidal eggroll
Member#: 51961
2005 STi
Get a DMM and see if you're even getting voltage at the pump. If not, trace the system backwards until you find where you are getting voltage, and you've found your failure. Attaching the green test connectors under the dash and turning the key on will cycle the fuel pump indefinitely, letting you probe around until you find the problem.
Old 01-25-2013, 01:47 PM   #6
What v8
Member#: 254718
thanks for all of thr info guys, im going to check the fuses tonight, if its not that i will diagnose it this weekend.
Old 01-27-2013, 03:05 AM   #7
What v8
Member#: 254718
turned out to be a fuse, anyone know why the fuse would blow? replaced it and t runs fine.
