Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 01-22-2013, 12:45 AM   #51
2011scoobywrx
Member#: 344372
2011 wrx
blue
Hold on... My gauge shows that when Im in cruise control go say 60mph, I'm at 6lbs of boost the whole time.. Should I be boosting that much when at a steady speed?? Or is my gauge off by 5 or 6 psi
2011scoobywrx is offline   Reply With Quote
Old 01-22-2013, 12:58 AM   #52
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
It should not be that high. For comparison I set my cruise to about 70-75 to work everyday and the gauge in vacuum (under 0). So yes your gauge is reading incorrectly.
I verified mine works correctly by monitoring boost off my AP at the same time. They always match.
Old 01-22-2013, 01:01 AM   #53
LUMBERZACK
Member#: 340009
2007 STi
48W
Originally Posted by HinshawWRX View Post
Crazy thought, boost gauge is off.
Dun Dun Dun
^ +1 x999
LUMBERZACK is offline   Reply With Quote
Old 01-22-2013, 09:45 AM   #54
thebigevilfoot
Member#: 253836
2008 AW e90 M3
2011 WRX 350/365- sold :(
Yup, given that you're at 5lbs at a steady speed of 60, the gauge is probably off, or something is horribly wrong with your car (which I'm starting to doubt) Even at 80-85 your should still be slightly in vacuum.
thebigevilfoot is offline   Reply With Quote
Old 01-22-2013, 10:07 AM   #55
NoGraffix
Member#: 276209
I am Rub
Function>Form
Your gauge is off. Under cruise conditions you should be in vacuum (anywhere between -10 and -20). What I would do is verify the gauge is installed correctly, then call the manufacturer of the gauge and ask if it can be calibrated. If it can do so, if not send it back to be repaired or buy a new one. If it was my car I'd still want to get it retuned for safety purposes.
NoGraffix is offline   Reply With Quote
Old 01-22-2013, 10:19 AM   #56
2011scoobywrx
Member#: 344372
2011 wrx
blue
LOOK!
Old 01-22-2013, 10:28 AM   #57
NoGraffix
Member#: 276209
I am Rub
Function>Form
Like I said call (or email) AEM and find out how to properly calibrate your gauge, it is obviously reading stupid high.
A retune would be a very intelligent use of your money in order to assure the car is running properly.
There really isn't anything anyone else can say in this thread that will serve you more then the first two sentances of this post. Go do those things and then come back.
Old 01-22-2013, 11:07 AM   #58
2011scoobywrx
Member#: 344372
2011 wrx
blue
Thank you
Old 01-22-2013, 11:11 AM   #59
jthatch12
Member#: 321715
03 Big 16G WRX
I talked to Buckey Lasek at the Philly auto show. His car is pushing ~45 psi
Old 01-22-2013, 11:37 AM   #60
bad mutha
Member#: 106747
04 forester xt
crp
hey hinshaw,move this to the southeast orlando thread,so we can find out whos car this used to be.
bad mutha is offline   Reply With Quote
Old 01-22-2013, 04:37 PM   #61
2011scoobywrx
Member#: 344372
2011 wrx
blue
Found out today that the gauge is on the outs. So i ordered a aem digital boost gauge and will be installed friday.
Old 01-22-2013, 04:46 PM   #62
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Alright keep us posted man. Hope that's the reason you were "hitting" 25psi.
Old 01-22-2013, 05:54 PM   #63
NoGraffix
Member#: 276209
I am Rub
Function>Form
Originally Posted by Mr Wrex View Post
All I see is a CAI and DP. It also looks like you have the stock boost controller, which I'm sure sucks to hold that kind of boost. You should get it up on a lift to check what other parts, if any, the previous owner slapped onto there. Like bigrob stated, the stock TMIC and BPV weren't designed those high boost levels with their plastic bits.
FWIW, I have a TP stage 3+ build and several other parts and I'm only doing 22psi on stock internals. I'm expecting the engine to give out fairly soon.
Either you are really pessimistic or badly misinformed. There is really no reason your block should give out with a stock turbo even if you have every bolt on known to man slapped on there. The only thing that will make it go boom would be a poor tune or poor maintence, and I personally know the quality of Eric's tunes, they are fantastic, so......
Will 22psi on a stock block likely degrade the engine components at a quicker rate (read "at a quicker rate" because there are some components that are wear items and over time everything will start to degrade) over a period of time then stock levels? Of course! The stock pressure is what around 12-14psi.
Will 22psi on a stock block with quality parts, quality maintence, a quality tune, and an owner that knows how to monitor his car (ie log regularly, check fluids, have proper gauges, stop beating on the car if something looks fishy, ect) last for 100k+ miles? EASILY
Sorry to rant and rave but too many people make the quality of the engines in this cars out to be total crap, when in reality 95% of the time is the quality of the owners that strongly influence the outcome of the engines.
Old 01-22-2013, 06:26 PM   #64
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
When I said "soon" I was talking about in another 5ish months. This is mostly because I love going WOT all the time
Old 01-22-2013, 10:08 PM   #65
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
good info. i agree. ive been tuned and at around 22 psi for about 4 years. no issues at all. no warranty work. burns no oil, nothing. at 52k now and 5 years of ownership. even stock clutch and brake pads still on the car!
Old 01-23-2013, 03:18 AM   #66
Ride1226
Member#: 201483
2010 WRX
WRBM
...and there's then unlucky ones like me who are pro tuned, take perfect care of their car, enjoy it for what it is, and crack a ring land, seize a rod bearing, scorch pistons, then have a vf52 bearing fail. 20psi on stock vf52, basic bolts on, 315whp 345wtq. Stock now. New everything.
Ride1226 is offline   Reply With Quote
Old 01-26-2013, 02:12 PM   #67
2011scoobywrx
Member#: 344372
2011 wrx
blue
Ok new gauge is in. Peak boost is 18psi! A lot lower than mentioned. I am ordering the cobb ap Monday and looking for factory airbox or aem/Cobb intake
Old 01-27-2013, 05:35 AM   #68
pauli133
Member#: 233261
2005 Outback XT
Have you had a professional look at what's actually on the car yet?
pauli133 is offline   Reply With Quote
