Old 01-27-2013, 02:52 PM   #1
ksantarina
Member#: 314667
2012 STi
Default 2012 Stage 1 93 SF Data Logging Review Please? Thanks!
Hi all,
Just loaded the SF Intake and loaded the OTS Stage 1 93 + SF Map on my 2012 STi with 13500 miles. I have about ~80 miles on the tune before pulling some logs last night.
Other than the intake, I have the Nameless Performance Axleback which I don't think should have any implications on the logs .
I have about 7 pulls logged from 3k - redline in S# mode and 3rd gear. They've been compiled into a single google doc sheet below.
https://docs.google.com/spreadsheet/...1lNd0p3NkJmZmc
Based on my initial analysis, I'm not seeing any feedback knock in any of the seven logs which I would assume is a good sign. AF learning jumps around a bit, which should settle as the tune runs through more miles. I'm within target boost without overboosting, so no LWG map necessary right now.
Anything else I'm overlooking? I'm pretty new to interpreting logs and as always, feedback is always appreciated. Hopefully I'll continue expanding my knowledge with the help of your comments.
Thanks again for all your help!
ksantarina is offline   Reply With Quote
Old 01-27-2013, 04:35 PM   #2
bluemax189
Member#: 137405
looking good.
bluemax189 is offline   Reply With Quote
Old 01-27-2013, 04:39 PM   #3
ProfessWRX
Member#: 323379
06 WRX
Looks great to me.
Old 01-28-2013, 08:27 AM   #4
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
Originally Posted by ksantarina View Post
Hi all,
Log looks good but you do have a bit of a boost spike. It is within tolerances for a 4th gear run (for 6-speed tranny), but given that this is a 3rd gear run, it means that this spike is likely to be worse in higher gears. I would recommend downloading the low wastegate (LWG) map from the maps section at cobbtuning.com and reflashing that to the car.
Bill
Old 01-28-2013, 08:28 PM   #5
bacalhau16
Member#: 297565
2011 WRX hatch
I would pull some logs in 4th and 5th where you might currently rev to in those gears and see what happens.
Otherwise, your car must be running great with that tune. Its definitely on the higher end of boost and the logs look great.
bacalhau16 is offline   Reply With Quote
Old 01-28-2013, 08:36 PM   #6
ksantarina
Member#: 314667
2012 STi
All,
Thanks for the feedback. I'll load the LWG map this weekend and see what I get.
Bill, question for you: Will loading the new LWG map require me to run the tune in a little as well? Meaning would it be required for me to get ~100 miles of normal driving on the tune prior to coming to any conclusions? I'd assume yes, but just looking for that confirmation.
Again thanks for all the feedback everyone. I'll follow up with weekend with fresh logs.
Old 01-29-2013, 10:06 AM   #7
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
All,
You can do the runs immediately with these particular maps for this car.
Bill
Message Board Statistics All times are GMT -4. The time now is 02:54 AM.
