Welcome to the North American Subaru Impreza Owners Club Thursday December 8, 2016
Old 01-27-2013, 01:25 PM   #4551
2011boostdwrx
Member#: 263470
I agree i noticed a big difference in the powerband on my swap, but I went with the 2011 STI gearing.
2011boostdwrx is offline   Reply With Quote
Old 01-27-2013, 01:33 PM   #4552
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
1-4 are the sane on ours so that's the biggest difference. Your 5-6 are shorter than mine so they'll feel peppier.
Old 01-27-2013, 01:40 PM   #4553
J_Maher_WRX
Member#: 290307
I think you have the best combo though, cause how often are you going to be WOT in 5th or 6th, considering 4th almost hits 115 mph haha
Def helps the fuel economy with those taller gears, and we all know we need that with how these things guzzle fuel
J_Maher_WRX is offline   Reply With Quote
Old 01-27-2013, 01:53 PM   #4554
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I agree. The long gears ate nice from cruising. And 4th will go 140 if I revved to 9k
Old 01-27-2013, 02:01 PM   #4555
J_Maher_WRX
Member#: 290307
Destroke to a 2.3L and upgrade the turbo
Follow Dom at Maxwells car haha crazy 4500-9000rpm powerband, it's a lunatic!
Old 01-27-2013, 02:29 PM   #4556
guitarman19853
Member#: 290734
2012 WRB WRX Hatch
2015 Forester XT
Is the 6 speed stronger than the gear set you were running before? Those were some pretty beefy gears, especially with the straight cut 1&2. I did see that the reason you did the swap was the differentials. Just curious how the gearboxes compare in strength.
guitarman19853 is offline   Reply With Quote
Old 01-27-2013, 02:33 PM   #4557
Jive Turkey
Member#: 219492
i've been telling him and flex'nwrx about that motor for months now
i mean c'mon, who doesn't want this:
Jive Turkey is offline   Reply With Quote
Old 01-27-2013, 02:44 PM   #4558
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
What does that car run? The local NF guys have a 2.5 that revs to 9l and runs high 9's @ 140.
https://www.youtube.com/watch?v=uI-kLqUyiLA
They should be at least as strong I think.
Old 01-27-2013, 02:48 PM   #4559
PearlRex11
Member#: 284420
2011 WRX Sedan
That is crazy! I want that^
Old 01-27-2013, 03:07 PM   #4560
J_Maher_WRX
Member#: 290307
I'm not sure what it runs in the 1/4. They're still playing with I think, they certainly haven't wrung it out to its maximum levels yet tho.
Yeah I know about that car, it's insane! Haha thing is the 2.5L isn't as reliable at those high rpms as the 2.3L will be over time, I think the 2.5L needs more beefing up to be able to handle those high rpms than the 2.3L as well if I'm not mistaken.
You think the 6spd is only as strong as the PAR gearset? That's interesting, I was always under the impression that the 6spd was absolutely bulletproof, and that the 5spds just can't handle the power the 6spd can. Though I guess that could be just due to the shorter ratios/less force on the individual gear itself?
Old 01-27-2013, 03:08 PM   #4561
J_Maher_WRX
Member#: 290307
Video Link: http://youtu.be/_F30Vzb0qHg
Right? The powerband on that thing is actually retarded! When they are finished with that its going to be out of this world haha good bit of lag though... Power kicking in at 4500-5000 haha
Old 01-27-2013, 03:47 PM   #4562
FLEX'N WRX
Member#: 163672
GV
Same color as veneers
MP/ Doms configuration is awesome, and definitely respectable in everyway. That car will be an absolute blast. My thoughts, and possibly similar to Ben's...
Does it become feasible to completely alter the car with a stroked motor to achieve the desired power(band) goals? The prevelance of quick spooling, high power delivering turbos is reality. Especially with e85, 450-500whp is relatively quick work. If the budget is there, 550+whp is a necessity, the power band of the motor is applicable.... do anything and everything possible that's desired.
I am perfectly content with a short block and ~ 3.5k-7.5k power band. Realistically, other priorities/ obligations come into play with something as in depth as that build. Few years... Different story.
*Knowing Ben, there'd be a stroked motor sitting on his photo table sharing beverages with him and no one would know.
[url]http://youtu.be/_F30Vzb0qHg[url]
FLEX'N WRX is offline   Reply With Quote
Old 01-27-2013, 04:05 PM   #4563
J_Maher_WRX
Member#: 290307
I agree with a lot of this. While that car is an absolutely blast, I think that as a DD it wouldn't be nearly as a feasible nor as fun as bens current setup. I would much rather a lower power output, but have power almost 2K rpms sooner, then have a lot more power but onlu starting to kick in at 5K. Completely unusable in 99% of DD activities, unless your commute involves a lot of highway driving.
Doms car is a more of a track only/drag strip kinda car, as he himself has said many times, but when it comes to that subject area, its a monster
Old 01-27-2013, 05:14 PM   #4564
Android287
Member#: 180861
2005 IAG Closed Deck
Larry's Power built heads
At what rpm do you hit full boost in third?
Android287 is offline   Reply With Quote
Old 01-27-2013, 08:42 PM   #4565
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Haha. I don't have a destroked motor waiting for me. I don't ever plan on doing one. For a high revving track car it could make sense, but I wouldn't want to loose the spool and low end grunt of higher displacement on a street car. If you properly balance and assemble a 2.5L it can handle 9k with some amount of reliability. NF's Speeding Bullet is a street car with a much larger turbo than the MP/Dom car. It has TONS of top end potential, but it still quite usable even off the track.
Here's what I get looking at my most recent logs:
Code:
Tranny	Gear	[email protected]	[email protected]
5MT	3	3500		3900
6MT	3	3500		4000
6MT	4	3100		3400
Old 01-27-2013, 08:50 PM   #4566
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
What you're saying is basically true but there are some other things to consider. It's the distribution of the weight that really matters. If the CF shaft were large enough diameter, and hollow (all the weight at the perimeter) it could actually be harder to turn that a smaller, solid, heavier shaft. This would all depend on the actual weights and measurements though. In general the CF shaft would almost always end up being easier to turn.
The distribution of weight basically is the polar moment of inertia, and the aluminum shafts are hollow, just like the CF. The aluminum ones are often bigger that the CF ones just for the sake of torsional stiffness, since aluminum has only 1/3rd the stiffness of steel.
I have no idea how much the inertia difference really translates into real-world difference, but on paper, in concept, it certainly begs one to look at more than just the weight.
To be honest, I'm really most interested in any one-piece DS just for the sake of ditching the two-piece design that bucks like crazy sometimes. I'd say your car definitely deserves a CF DS.
blehhh is offline   Reply With Quote
Old 01-27-2013, 08:53 PM   #4567
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, that middle section of the 2 piece has so much play. With all the upgraded mounts it does seem much less though. Is installation more difficult with the 1 piece? Or does the u-joint at the rear end make it pretty easy to get it all lined up?
Old 01-27-2013, 09:00 PM   #4568
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
I don't have one yet, but I hear it's easy as hell to do. The bolted end just drops down flush. No need to move it forward or back at all. I've spent most of my modding budget trying to just tighten up the drivetrain and make DDing a little less wonky, but I think that's still my next big mod. I want better clutch-feel, smoother downshifts and a larger margin of error with rev matching. I hear a one-piece delivers on all accounts.
Old 01-27-2013, 09:06 PM   #4569
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I've had the OEM driveshaft on and off many times, and it's really easy. The only thing that I'm worried about with the 1 piece is how do you slide it into the tranny if you can't line it up straight, due to it hitting the rear diff. Maybe there is enough wiggle room that it works, I'm not sure. Worst case you could pull the rear diff, install the driveshaft, and then put the rear diff back on, but that's a lot more work.
Old 01-27-2013, 09:30 PM   #4570
Android287
Member#: 180861
There is a universal joint at each end. I think you just insert one end into the transmission and then lift the opposite end until it matches up with the bolts on the diff. Once in the transmission there is enough play to move it forward or back to get the rear diff bolts lined up. Been looking at and reading reviews on the carbon fiber ones for a while now. Haven't read any thing bad about them yet
Old 01-27-2013, 09:50 PM   #4571
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Duh. You're right. I forgot about the u-joint on the tranny end. There shouldn't be any problem with install. Seems like a good way to go as long as they hold up. The CF ones are really spendy though.
Old 01-27-2013, 09:51 PM   #4572
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
Vibration, more-so with the aluminum ones, seems to be the only concern, and even then, you just undo the bolts, rotate it 90 degrees and try again. One out of the 4 orientations should be perfectly balanced.
I hear lots of people saying it just improves the driveability tremendously.
Old 01-27-2013, 10:36 PM   #4573
Android287
Member#: 180861
Expensive but proven to put more power to the wheels on a dyno. I've have seen dyno charts giving 10 to 15 more hp/Tq. But people say the smoothness and better drivability make it worth it alone.
Old 01-27-2013, 10:39 PM   #4574
INKMAN
Member#: 267837
2014 Focus ST (ST3)
Tuxedo Black
I'll be waiting for the next cell phone shot of a piece of carbon fiber.
INKMAN is offline   Reply With Quote
Old 01-27-2013, 10:41 PM   #4575
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I guess I'd kind of think about it, but it's not high on my list. $1000 for 10HP and a little smoother drive doesn't seem like a lot of bang for your buck.
xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch xluben Car Part Reviews 26 11-08-2012 07:55 PM
My first post and my first Subaru, a 2011 WRX 5 door in white. Decade240 Newbies & FAQs 25 06-20-2012 02:48 PM
2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? BretCutler Tire & Wheel 4 01-14-2011 09:05 AM
2011 WRX 5 Door Ruz4life General Community 55 10-14-2010 12:37 AM
2011 WRX 5 Door Ruz4life General Community 10 10-04-2010 05:02 PM
