South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 01-27-2013, 06:41 PM   #726
WhatTurboLag?
Member#: 243992
2006 WRX TR
WOW this is exactly what I would do if I didn't go with a "big power" build. and your making it happen.
why not just run the 2.5i manifold and kill 2 birds with one stone?
and is the cam sensor mod only necessary for the usdm cam install?
sorry I skimmed through fast because I need to poop and don't want to leave the pc lol
I have a question for you. which wire/how did you tap it on the 06 ecu for the tps sensor for the dccd pro. the one I tapped apparently was not correct and im stuck with just a manual controller for now
WhatTurboLag? is offline   Reply With Quote
Old 01-28-2013, 02:30 PM   #727
CJ68
Member#: 187419
2001 2.5RS
Sedona Red
This may have been asked already but I searched in this thread for "drive shaft" and "driveshaft" and only found two posts where it was mentioned. How did you have your one-piece shaft made? Did you just hand it off to a DS shop and say "make me this in one piece"? I have a pretty good feeling that I will need to do a little more hand holding with my local shop. I am attempting to figure out what others have done for the transmission slip yoke and the flange at the rear differential. I could have sworn I stumbled across someone saying that the Dana/Spicer part number for a slip yoke that works is but I can't find it again... It looks like the rear diff flange on your shaft is a fabricated piece. I am guessing that your local shop just made that based on the OEM unit? How much did the shaft cost you in the end? If you can share any info it would be a huge help.
CJ68 is offline   Reply With Quote
Old 02-03-2013, 11:34 PM   #728
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
the work you do and the way you go about it is amazing. Kudos!
arco is offline   Reply With Quote
Old 02-03-2013, 11:56 PM   #729
amroof
Member#: 211224
2005 Saabaru
Who knows
So are you still alive and kicking?
amroof is offline   Reply With Quote
Old 02-04-2013, 11:12 AM   #730
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Originally Posted by bluecloud View Post
Love the thread, so much time and work that makes all of our subies jealous.
Thanks. The whole project is a crazy waste of time and money, but it's entertaining and I enjoy posting up the projects on the forums.
Originally Posted by lukeskywrx View Post
Too bad it's a fake 207 Ken, only a crazy person would think you could make it work by swapping cams and a few sensors.
Originally Posted by KP View Post
This thread is so nerdy. I like it. I like it a lot.
Thanks. When are you coming by again?
Originally Posted by DerickRyoung View Post
I noticed you like the lime green accents. Paranoid fabrications in CA sells exhaust hangers in this color, same design as the Kartboy hangers. I am need to see this build in person hopefully at a meatz soon. Keep up the jamz brah
Thanks. It's technically not lime green. If you see it in person, it's much more green. Cameras seem to have a hard time capturing the green properly. I've seen some of Paranoid's stuff and I like it, but I have to stop buying parts for this car!
I wanted to do the USDM 2.5i manifold, but didn't take the time to pursue it on this round of mods. Really, I'm still bitter that they are going for so much money these days due to their popularity. When I first started looking into them, they were running around $40-50. Now it seems that everyone wants $150++. But when/if I come across one, I'm going to snap it up and start shaving it.
The sensor install/relocation is only needed to run the USDM cams in a USDM 32 bit car. The 16 bit cars can use the JDM ECU and custom AVCS wires and the JDM cams and sensors for AVCS. If I were to keep the JDM cams and sensors, the 32 bit ECU would throw errors as it could not read the cam position properly and AVCS would not work. So basically, I swapped the cams and sensors to keep AVCS working on the 32 bit ecu.
My local driveshaft shop was on point. They simply asked for the old STi DS to take measurements and less than 24 hours later, they called saying the shaft was done. The spline section was come off-the-shelf part that they can order and they can turn down the outer diameter in their in-house machine shop to meet the application. For the rear yoke, he said they have generic castings that are not drilled yet and they machine them to fit. The total price was about $275 if memory serves, but that might have been the price he quoted me if he made 10 at once. Either way, I'm positive it wasn't more than $325. I may have them check balance on it again when I get up and running again as I did have a bit of vibration in the car, but I can't tell if it's the rear diff, the tires, or the DS.
Thanks. I'm interested to see the progress on your swap and how it tunes out in the end.
I'm alive, but pretty busy. And lazy. I'm working on a new business idea and I'm afraid it's going to take a lot of my spare time (only so many hours in the day after work). I also signed up for two LONG bike races in May and June that I'm training for.
I'm really just waiting on the powder coating right now. Once that's complete, I'll throw the motor together and drop it in. Then there are just a few misc plumbing tasks (PS, Fuel, Oil cooler) and I'll be ready to rock.
Old 02-05-2013, 08:53 AM   #731
amroof
Member#: 211224
2005 Saabaru
Who knows
Good I'm glad you will be able to finish it. I got worried someone might have beat you straight and you came to the realization that this engine isn't going to work. Hehe
Anyways I have a rs mani and they really aren't that hard to find. Loop holes on the models they came in ;-). And they aren't gonna be that much better than the jdm mani anyways minus the plenum size. The runners are the same size 150cc's of love.
Old 02-05-2013, 09:38 AM   #732
amroof
Member#: 211224
2005 Saabaru
Who knows
Btw I lied that's the 207 intake port size
Old 02-05-2013, 10:32 AM   #733
WhatTurboLag?
Member#: 243992
2006 WRX TR
okay awesome thanks!
and why is it I heard a new 2.5i manifold was like 90 bucks from the dealership?
Old 03-04-2013, 01:41 PM   #734
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
Hurry. Up.
KP is offline   Reply With Quote
Old 03-04-2013, 03:44 PM   #735
SaabaruMike
Member#: 113342
2014 WRX
That's what she said.
You're still working on this POS? J/K, I'm in awe of your skills man.
SaabaruMike is offline   Reply With Quote
Old 03-04-2013, 04:50 PM   #736
SedonaScooby
Member#: 143522
1987 Brat GL 4 Speed
98 Forester L (RIP)
did you use the DS shop next to FAT?
SedonaScooby is offline   Reply With Quote
Old 06-20-2013, 06:00 PM   #737
sleepysubie
Member#: 81069
1998 ej257 gm6 ewg
A/R .60 Rotated
Is This Car Running Yet?
sleepysubie is offline   Reply With Quote
Old 06-20-2013, 06:06 PM   #738
Evil Imports
Member#: 14732
+ 13 B8
Give you a hint
Evil Imports is offline   Reply With Quote
Old 06-20-2013, 06:08 PM   #739
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
Originally Posted by Evil Imports View Post
Give you a hint
Z0rr0 is offline   Reply With Quote
Old 06-21-2013, 12:47 AM   #740
sleepysubie
Member#: 81069
1998 ej257 gm6 ewg
A/R .60 Rotated
Give you a hint
What's the issue? Is it the engine or what?
Old 06-21-2013, 01:57 AM   #741
kpluiten
Member#: 120273
06 WRBWRXWGN
No, no problem with the build, I've simply been too busy to work on it. Between my day job and a business I'm starting on the side, I've had no spare time. Expect some progress in the next month or so.
I got your PM and I'll hit you up tomorrow or so.
Old 06-21-2013, 03:51 AM   #742
Evil Imports
Member#: 14732
+ 13 B8
progress in the next month or so? You told me you were going to push it outside and get that Red integra
Old 06-21-2013, 04:01 AM   #743
kpluiten
Member#: 120273
06 WRBWRXWGN
I didn't say what type of progress. That's still progress isn't it?
Old 06-21-2013, 04:27 AM   #744
Erik
Member#: 168774
Both of you quit making excuses and just put your cars together. So much for built not bought, now its "Bought all this **** and never built it."
Erik is offline   Reply With Quote
Old 06-21-2013, 11:21 AM   #745
Evil Imports
Member#: 14732
+ 13 B8
I "bought" a 05 sti and have to get that running , i just rebuilt the stock forester block for it, so its kinda like working on the forester in a way
Old 06-21-2013, 11:44 AM   #746
kpluiten
Member#: 120273
06 WRBWRXWGN
And I built an oven that's almost the size of a car so that sort of counts.
Old 06-21-2013, 11:50 AM   #747
Evil Imports
Member#: 14732
+ 13 B8
i guess, not really
Old 06-21-2013, 11:51 AM   #748
kpluiten
Member#: 120273
06 WRBWRXWGN
On a side note, I've put more mileage on my bicycles in the part year than my wagon.
Old 06-21-2013, 11:55 AM   #749
kpluiten
Member#: 120273
06 WRBWRXWGN
Why is "bought" in quotes. That sounds shifty...
Old 06-21-2013, 12:01 PM   #750
Psirene
Member#: 308506
2015 Legacy Limited
Crystal Black Silica
I do not have enough caffeine in my blood to make a proper joke out of shifty + manual transmission, but it's there, clearly.
Psirene is offline   Reply With Quote
I am master of Procrastination! subySerb Off-Topic 13 04-29-2008 03:29 AM
By Build Thread: 1991 Legacy Turbo with EJ20G Swap livestrong14 Member's Car Gallery 69 03-14-2007 08:59 PM
Some nice things can be borne out of procrastination [56k beware] sherifx Off-Topic 6 01-21-2007 09:18 PM
Tale of Two Cities: City of God and City of Lost Children Snoopy Off-Topic 7 11-07-2005 11:03 AM
Just sit right back and you'll hear a tale, A tale of a fateful nap... collegedropout Off-Topic 4 08-01-2004 09:36 AM
