Old 01-26-2013, 12:09 AM   #1
cbazq271
Member#: 330175
Default 2005 sti rear wing removal?
I am getting my 05 sti wrapped. I want to remove the rear wing to make it easier to wrap. I have removed all the nuts, even the ones under the rubber feet, from the inside of the trunk lid. I still can't remove the wing. When I pull on the wing, the ends lift up alittle, but the center will not budge. The area were the third brake light is seems still bolted or something. Any help would be great.
cbazq271 is offline   Reply With Quote
Old 01-26-2013, 09:59 PM   #2
cbazq271
Member#: 330175
Old 01-26-2013, 10:16 PM   #3
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
There's plastic clips that hold the wing on, you just have to give it a little muscle and it'll pop off.
Just make sure all the nuts are off before you break something
brett192 is offline   Reply With Quote
Old 01-28-2013, 04:34 PM   #4
OA5599
Member#: 47050
2004 STi
aspen white
and don't forget to unplug the center brakelight harness
OA5599 is offline   Reply With Quote
