#1 |
Member#: 290623
MWSOC
Vehicle:2007 Wrx pearl white |
I have a 2007 subaru wrx with 87,000 miles in it. After a long drive across my state I parked it and turned off the car. There is a high pitched whistling or beep coming from the engine bay, it sounds like that annoying mosquito sound or that ringing in your ear after a loud concert. It's been 10 minutes and its still going on.
No strange smells, no smoke, engine temperature was fine, no obvious signs of something broken.
#2 |
Member#: 311923
VIC
Vehicle:04 STi WRB |
Is the car in 'acc' when you hear it?
#3 |
Member#: 290623
MWSOC
no the keys are out as well
#4 |
Member#: 311622
Tri-State
Vehicle:2010 WRX STG 2 WRB |
Radiator cap rubber gasket?
#5 |
Member#: 290623
MWSOC
it seems to be an electrical problem because I unplugged the batter and the sound died away and once I plugged it back in the sound came right back up. Ill take it to my mechanic but the problem is that it won't be until Monday.
#6 |
Member#: 321409
SWIC
Vehicle:2011 WRX STi Sedan WRB Stage II T.P. tuned |
Possibly the module that makes the chirp when you use the keyless entry system:
http://www.clubwrx.net/forums/genera...ml#post2565887 |
#7 |
Member#: 343576
Vehicle:2005 Saab 9-2x Aero |
I believe that's what would be called a "turbocharger" :P
#8 | |
Member#: 248305
Vehicle:97 OBS my custom mixed silver |
#9 |
Member#: 340009
SWIC
Vehicle:2007 Impreza WRX STi Crystal Gray Metallic |
#10 |
Member#: 127834
Vehicle:2007 2.5i Wagon |
I have an 07 2.5i with an aftermarket alarm. I also had this very annoying high pitched whine. I was worried that it had something to do with the alarm, but after reading this thread, I went outside to take a look at the chirp unit. Low and behold, when I unclipped it, the pins were gone, so obviously it was fried. When I prodded at the chirp unit, it was making the same whine that I have been hearing this entire time. I left it unclipped, and taped up the connector. So far the whine has not returned.
#11 |
Member#: 290623
MWSOC
yea I've talked to a few people and they told me its my alarm system damaged from the rain so I will try to take a look when I get a chance to
