#101 |
Member#: 237008
E. Canada
Vehicle:2010 WRX STI Satin White Pearl |
I'm aware of this. I used "locking" colloquially when I really meant "coupling".
#102 | |
Member#: 319157
Vehicle:2012 Impreza 4DR 5MT |
You've been arguing with several people on here about what a car they own and drive every day, should or should not do. I suggest driving your friend's 5MT before deciding how capable it is. I think you might be surprised. |
#103 |
Member#: 328414
Vehicle:2012 Impreza SP 5MT obsidian pearl black |
Relating to the wet parking lot donuts -
What are the main signs of a "bad" center diff? Clunking and banging of the drivetrain during slow tight turns when the transmission is warmed up seem to be the most common sign. What are the main causes of diff failure? Doughnuts or driving the car with mismatched tires (different levels of tread or brands). These two problems are responsible for overheating the differential How do those things cause the diff to fail? When the front and rear wheels are spinning at different speeds, the fluid inside the diff heats up. If it overheats, this fluid will break down and wear out. The clunking and binding is a result of worn fluid trying to do it's job, and then failing and releasing. It grabs, slips, grabs again, and slips. http://www.subaruforester.org/vbulle...ce-them-46979/ |
#104 |
Member#: 319157
Donuts are definitely bad.
A quick turn into a parking space won't get close to overheating the fluid. |
#105 | |
Member#: 237008
E. Canada
Again, my only contention was the the VCU used was bad. It wasn't even that all VCUs are bad; only the 4kg one that Subaru uses. |
#106 | |
Member#: 319157
Drive your friend's car and let us know what you think. |
#107 |
Member#: 324017
Vehicle:2012 Impreza 2.0i Ice Silver Metallic |
Imma check into this discussion briefly...
I live in southeastern PA. We don't get all that much nasty conditions here, around 20 inches of snow/year on average. I do make frequent trips to upstate NY, sometimes in inclement weather in the winter, to a town that averages about 60 inches of snow/year. Nobody's disputing your claim that the STI has a better AWD system that the Impreza, or that there are a variety of other cars that can also outperform an Impreza in inclement conditions. The typical small-car buyer is not looking at a $35K+ STI. They're looking at a $20K impreza, or a civic, or an elantra, or a corolla, or a mazda3, etc. This is reflected in the cars that I see on the roads, both at home and in upstate NY. Compared to those other cars, the impreza does damn well in slippery conditions. Nobody's ever been shopping for a $17K civic, decided they'd like AWD, and gotten an Audi S4 for $52K. They're just entirely different classes of vehicles. Nobody cross-shops between them. Among cars available in the USA, in a price and size range comparable to an impreza, it's tough to find something that can outperform the impreza in most inclement conditions. |
#108 |
Member#: 319157
The STI's AWD system would noticeably outperform the Impreza's in situations that nobody buys an Impreza for.
#109 |
Member#: 299286
Vehicle:2012 Sport 5MT Green/Silver |
Not to twist the screw any deeper, but a car with narrower tires, and even the 'crappy' AWD found in the Impreza, probably performs as well or equal to the superior STI AWD system in most winter driving conditions found on paved roads.
There is such a thing as too much power to be useful, and wide makes for great snow shoes, but not road traction, which is why the tire warehouse suggests downsizing the winter wheel/tire combo. |
#110 |
Member#: 329526
SWIC
Vehicle:2013 Impreza Spt cvt Silver |
#111 | |
Member#: 319157
#112 | |
Member#: 340297
Vehicle:2013 Impreza 5sp Prm Ice Silver |
#113 | |
Member#: 338666
Vehicle:2013 Impreza Premium Dark Grey Metalic CVT |
Most of the time, NOT slipping and sliding is the goal. Parking lots are a place to play once in a while. For that, the '03 wins! But for getting safely and easily from A to B, the '13 uses a good system. John edit: BTW, I agree with your statement. Few will ever exploit the STI to its full potential, or a WRX for that matter. Last edited by Guzzi 1; 01-25-2013 at 06:43 AM. |
#114 |
Member#: 344894
I fully agree my 03 Wrx is amazing and can turn like no other.
