#1 |
Member#: 26933
BAIC
Vehicle:2006 STI CGM |
It's always fun when a customer comes in and tells me to push the setup to the limits and beyond without caring about engine longevity. After discussing the risks and plans, this customer asked me to push 24psi on this setup. The stock engine has nearly 100k miles on it with the last ~30k running this setup at about 20psi. It was still running strong but he is planning on building it soon anyway so he wanted to see what was possible with a very aggressive tune on California 91 Octane. We went ahead with the tune and the results are pretty awesome.
Event: Custom Tune/Dyno Location: Equilibrium Tuning - Fairfield, CA Ambient Temp: 70 degrees Fahrenheit Elevation: ~100ft above sea level Car: 2006 Subaru STI Tuner: ED @ Equilibrium Tuning Peak HP at RPM: 350whp @ 5900RPM Peak Torque at RPM: 380ft-lbs @ 4500RPM Target Boost: 24psi peak tapering to 20psi Fuel: Cali 91 Octane Engine/Power Modifications: Catless TBE EL Headers KSTech 73mm Intake TMIC Five-O 850cc Injectors EWG Hallman MBC Custom Tune ![]() *** Standard Dyno Chart Disclaimer *** This dyno reads low and should be compared to the lower reading mustang dynos. Here are some proven numbers and trap speeds for reference: Stock 02-05 WRX - 155-165whp Stock 04-07 STI - 210-220whp Stock 08-11 STI - 195-205whp 265-275whp - 107-108mph traps 300-310whp - 112-113mph traps 325-335whp - 115-116mph traps Thanks -- Ed
#2 |
Member#: 266880
International
Vehicle:2004 WRX STi WRB on gold |
Those are great numbers for that setup and 91 Oct. Your customer doesn't want to run meth? I hope the engine lasts...
#3 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
he realizes that blowing the motor could possibly cost him thousands and thousands more than if he were to build it right now?
#4 | |
Member#: 26933
BAIC
-- Ed |
#5 |
Member#: 26933
BAIC
#6 |
Member#: 36033
SCIC
send him to the track i wanna see some 118mph traps on a 91 oct 20g!
#7 |
Member#: 212576
SWIC
Vehicle:2007 impreza wrx sti pearl white |
Which 20g is this?
#8 | |
Member#: 266880
International
#9 |
Member#: 60142
Vehicle:2011 WRX Grey |
#10 |
Member#: 297902
BAIC
What's the afr looking like
#11 |
Member#: 26933
BAIC
#12 |
Member#: 125586
BAIC
Vehicle:2004 WRX STi Platinum Silver Metalic |
I'll be visiting you guys soon. But I want mine to last
#13 |
Member#: 285777
MWSOC
Vehicle:2004 STi- |
Wow great numbers Ed, Id like to see the timing tables to see how much ur holding out till redline..and how quick did you see the boost taper down to 20psi? It looks like it dropped out pretty quick, what TMIC did the customer have on?
What will go first @ 24psi and 100k+ miles, Turbo or motor? |
#14 |
Member#: 127704
TXIC
Vehicle:2013 Leggy Scooby no4 - huntin for 5 |
Great result on piss water, must have a really smart timing curve to hold that boost initially, clever tuning, bet it rips
#15 |
Member#: 145243
SCIC
Vehicle:2006 wrx wagon Urban Gray Metallic |
20G's are great.. I hear the Synergy turbo 20g-8cm turbos make that type of power off pump gas.
#16 |
Member#: 285777
MWSOC
Vehicle:2004 STi- |
Is this on a 20g turbo? I must have missed that post I thought this was a aggressive stock turbo tune
#17 |
Member#: 36033
SCIC
Read title of thread
#18 |
Member#: 210777
SCIC
Vehicle:.. Don't worry bout' it Brah |
how much power was it making off the first 20psi tune?
#19 |
Member#: 26933
BAIC
#20 |
Member#: 26933
BAIC
#21 |
Member#: 285777
MWSOC
Vehicle:2004 STi- |
Yeah sorry need to read the title much more closely...I knew something wasnt right when I asked the first time
#22 |
Member#: 100218
Vehicle:04 AW STI 04 WW EVO 8 RS |
Any updates? Has this thing gone to the track yet?
#23 |
Member#: 26933
BAIC
#24 | |
Member#: 207923
Vehicle:2006 STI paperweight WRB |
Any updates? Hope this guy had better luck than me lol. A few years ago i installed a 35r/supporting mods on my 06 sti(stock longblock). Drove to CO on a limo map and dynoed 425/380 on 91. About a month later piston #3 exploded; broke through the cylinder wall, bent valves and chunks of piston in the turbo. Look me up in ppb to see pics of the carnage. Its back up and running now with a donor motor and a 20g. Can you do an open source tune via email? Thanks Paul |
#25 |
Member#: 139320
BAIC
Vehicle:2006 RA 1-4 5mt wrx obp needs a e85 tune |
Op sold the car last year shortly after. Last word on the forums its still running strong with new owner; as of a few months ago
| Thread Tools | |
| Display Modes | |
| Safety benefit of non aggressive 91 octane map vs stock tune? | pharmamatt | AccessPort | 4 | 02-13-2012 09:08 PM |
| 93 octane on stage 1 91 octane tune | jmikeumo | AccessPort | 3 | 10-19-2011 08:31 AM |
| EQ - 2006 WRX, OG FP Green, 91 Octane - 333whp, 325ft-lbs | Equilibrium Tuning | Proven Power Bragging | 11 | 05-13-2011 10:10 AM |
| EQ - 06 STI, EQ FMIC, EQ EL Headers, ATP GT3076 - 343whp/345ft-lbs w/ in car VIDEO! | Equilibrium Tuning | Proven Power Bragging | 34 | 11-05-2010 10:41 PM |
| 91 octane tune effective for 93 octane? | relliMmoT | Engine Management & Tuning | 8 | 06-26-2009 11:17 AM |
