Welcome to the North American Subaru Impreza Owners Club Saturday February 13, 2016
Old 02-08-2012, 07:18 PM   #1
Steel_pounder
Member#: 288966
02 wrx
red
Default 2.1l build, stock everything else
So I have been reading everything I can on here abot 2.1 strokers and have a few questions.
is it possible to run this engine with everthing stock but the shortblock? IE... turbo, manifold, injectors, ecm etc. I realise that I won't likely see any performance gains at this point and plan on upgrading later but this car has been down a long time and I need it running.
is an access port going to be better than a turbo xs for tuning?
What would be the best MT? 07 6 speed.
Steel_pounder is offline   Reply With Quote
Old 02-08-2012, 08:27 PM   #2
SomDong
Member#: 274776
You will see gains, lower end torque.
The powerband will shift to the left.
And A/P will suffice. And 6 spd is always a good thing over a USDM 5spd.
SomDong is offline   Reply With Quote
Old 02-08-2012, 09:04 PM   #3
Steel_pounder
Member#: 288966
02 wrx
red
thanks for the reply. Will I need the AP right off to compensate for the greater displacement or will the stock ecm do for breakin?
Old 02-09-2012, 01:26 AM   #4
mattxander12
Member#: 111067
2002 Old and
busted.
I'll jump in and say you'll need either a break in tune using either an AP or an Open Source tune. Your stock ECU map will be expecting 2.0L and not 2.1L and could cause problems.
mattxander12 is offline   Reply With Quote
Old 02-09-2012, 12:09 PM   #5
brutnus
Member#: 257195
2004 WRX
2.1L 12k miles strong
Use whatever software the tuner recommends. You want to use what the tuner is used to. Generally its an AP, opensource or standalone application. There quite a few vendors that do the 2.1L and give great advice.
brutnus is offline   Reply With Quote
Old 02-09-2012, 12:19 PM   #6
SomDong
Member#: 274776
The best thing to do is speak to the tuner like everyone said. They've probably done it before and will have a map for break-in etc.
Old 02-09-2012, 04:19 PM   #7
Steel_pounder
Member#: 288966
02 wrx
red
I know of no tuners here in the treasure valley. I asked a few of the subie owner's I have talked to and pretty much got there's not one. I was thinking of getting an AP and a Dom Tune. Just didn't know if I was gonna need it with everything stock but the shortblock.
Old 02-09-2012, 04:25 PM   #8
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
If you get the ap we can email you basemaps so you can drive your car to here (mps) and get it tuned.
NW2TONE is offline   Reply With Quote
Old 02-09-2012, 07:20 PM   #9
Steel_pounder
Member#: 288966
02 wrx
red
Thanks, this is the way I am leaning. Just trying to find out if I can go stock or if I should just bite the bullet now and put in injectors, fp, 16g or 18g etc.
Old 02-09-2012, 07:47 PM   #10
bzoli
Member#: 181759
2004 WRX Wagon
The fastest one
Tune would be required to when ecm goes open loop, that is clear - so some kind of engine management is needed. But can the stock ecm handle closed loop tasks? Idle, cruising, cold start without a problem?
bzoli is offline   Reply With Quote
Old 02-09-2012, 08:11 PM   #11
Nuke209
Member#: 108089
2003 WRX
NF Performance
Shouldn't have any problems with the stock ecu at all.
As long as your tuner knows what he/she is doing, you should be fine.
and yes the stock ecu can handle closed loop tasks
Nuke209 is offline   Reply With Quote
Old 02-10-2012, 11:37 PM   #12
Steel_pounder
Member#: 288966
02 wrx
red
thanks guys. I think I am going to go with the AP and a internet breakin tune from MPS. Then drive the car over and have Dom and his team tune it right after I have the break in done. the 600ish mile road trip being the last part of the breakin. just picked up an 18g and plan on ordering injectors next.
Old 01-29-2013, 02:07 AM   #13
AK-Saabaru
Member#: 337400
2005 SAAB 9-2x
Red
Steel,
Did you every run your 2.1L with the stock turbo and injectors or did you just go for a turbo upgrade? I'm at that same point in my build - wanting to keep the stock turbo for a while that is.
--Patrick
AK-Saabaru is offline   Reply With Quote
Have confusion about ej20 2.1L build.. I want to use the STI crank. glutetoot Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-02-2010 01:07 PM
2.5 build like everyone else PoZeR Built Motor Discussion 2 05-26-2010 06:50 PM
Build closed deck stroked 2.1L Cheap Texy32 Engine/Power/Exhaust 35 05-01-2010 08:57 PM
Intermediate pipe w/ stock everything else WRXSIG Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-20-2005 03:01 PM
Help! vf30 + up stock everything else burrito007 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-03-2004 02:49 PM
