Old 01-25-2013, 12:09 AM   #1
bigyak16
Member#: 299743
2008 WRX
Gunmetal Gray
Default "limp mode" and how can i avoid it
I have a 2008 wrx and i recently put on my cobb intake and iv have my AP for some time trying to learn tuning one step at a time. working on my AFR's but i did a 3rd gear pull today and it tossed my car into "limp mode" and im not sure why i wasnt logging at the time so im not sure where the error occured but was wondering if anyone happened to have the same problems and if there is somewthing i can change so i dont hurt my car.
bigyak16 is offline   Reply With Quote
Old 01-25-2013, 02:58 AM   #2
Andrewxxcarlson
Member#: 316415
2006 WRX
Did it throw a code?
Andrewxxcarlson is offline   Reply With Quote
Old 01-25-2013, 08:37 AM   #3
Cobb Tuning
Member#: 4803
Depends on what you mean by "limp mode". There's a limp mode when you hit the overboost fuel cut, which will enable the P0244 check engine light. If you have a check engine light, you should definitely read the code (via troubleshooting menu on Accessport). Then there's a limp mode of sorts that disables boost control with excessive knock that drops the dynamic advance multiplier (DAM) below a low threshold. In that case, it does not throw a check engine light.
Bill
Old 01-28-2013, 03:21 PM   #4
bigyak16
Member#: 299743
2008 WRX
Gunmetal Gray
yea its making the car throw the "check engine- traction control- flashing cruise control light " ... so should i pull down the boost
Old 01-28-2013, 03:23 PM   #5
bigyak16
Member#: 299743
2008 WRX
Gunmetal Gray
im using a off the shelf map from cobb for a stage 1 intake only... i dont know if its because i live in ohio and its been under 10 degrees for the past 3 weeks and the car just cant adjust to it?
Old 01-28-2013, 04:28 PM   #6
r8r4life
Member#: 101464
So you say in your first post you are trying to learn to tune then your last post you say off the shelf.Wich one is it?
If you have no idea what you are doing either take a tuning class or pay somebody to do it for you.Either of those two suggestions will help you keep your car from going into limp mode because you changed something you didn't know what you were doing.
r8r4life is offline   Reply With Quote
Old 01-29-2013, 09:52 AM   #7
Cobb Tuning
Member#: 4803
You'll want to use the Accessport's trouble code reader function which can be found in the troubleshooting menu of the Accessport. You want to make sure this is actually the overboosting code (P0244) and not some other code (or combination of codes).
If it is P0244, then you will want to download the low wastegate (LWG) version of your map from the maps section at cobbtuning.com. Then use the Accessport Manager software to transfer the map from your computer to the Accessport. You then want to reflash the map using the "Tune" -> "Change Map" function.
Bill
