Old 01-28-2013, 08:04 PM   #1
ScoobieRex2.0
Member#: 310009
03 WRX
MBP
Default Oil pooling on top of passenger side head
I have a pretty bad oil leak right under the intake manifold between the power steering pump and pcv. It is not turbo related. I replaced the crush washers to the oil feed and return line hose thinking that would be the problem. Still pools of oil on top of the passenger side block/head. The oil galley seems fine so does the PCV. No coolant in the oil or sludge, typical head gasket symptoms... The motor has about 200 miles on the rebuild. Pretty posotive head gaskets weren't put in backwards. Anywhere else it can b leaking?
***Fixed***
- Oil temp sender not tightened.
Currently facing another problem though. The car smokes like mad at idle. It's definitely oil and add cent amount is being consumed. The car doesn't seem to be making less power, but oil pressure seems a little low. I just want to know what causes burning oil and smoking at idle only.
ScoobieRex2.0 is offline   Reply With Quote
Old 01-28-2013, 08:26 PM   #2
woodys77
Member#: 192147
2007 STI EfiLogics
422whp 421wtq fpgreen
When I put my built engine in one of the rubber breather line couplers split when I slid it on the block and did the same thing your describing.
woodys77 is offline   Reply With Quote
Old 01-28-2013, 09:14 PM   #3
sidewayz
Member#: 5810
2001 S366 2.5RS
Ps pump leak. Rear housing orings die and piss all over the top of the head... Common. $30 gets a seal kit from Subaru
sidewayz is offline   Reply With Quote
Old 01-28-2013, 09:19 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
^^^ That's what I was thinking, too.
Old 01-28-2013, 09:44 PM   #5
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
Is it slightly in front of the intake manifold? If so check the stock oil pressure sending unit.
Md05STI is offline   Reply With Quote
Old 01-28-2013, 09:46 PM   #6
BoostLeak
Member#: 304696
Do you know the part number for this seal kit?
BoostLeak is offline   Reply With Quote
Old 01-28-2013, 09:53 PM   #7
ScoobieRex2.0
Member#: 310009
03 WRX
MBP
It's oil not PS fluid. It goes from the back of the block by the oil galley plug to the front between the ps pump and alternator. Where is the oil sending unit? In the front near the alternator? Trying to get a good idea where to look before I pull the intake manifold.
Old 01-28-2013, 09:59 PM   #8
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
Its kinda hidden behind the PS pump and in front of the intake manfiold. When mine leaked it ran all the way back down the backside of the block it was so bad.
Old 01-28-2013, 10:19 PM   #9
ScoobieRex2.0
Member#: 310009
03 WRX
MBP
Remove PS pump to access or will the manifold need to be lifted as well?
Old 01-28-2013, 10:34 PM   #10
sidewayz
Member#: 5810
2001 S366 2.5RS
You would be surprised how a p/s pump leak mimics an oil leak. How are you sure it's not ps fluid? Dirty ps fluid looks like oil...
Old 01-29-2013, 12:55 AM   #11
manys
Member#: 265277
1999 Outback
Legacy
clean the existing oil, start the car and look for the leak until you see where it's coming from.
Sounds stupid but it's better than guessing
manys is offline   Reply With Quote
Old 01-29-2013, 01:02 PM   #12
ScoobieRex2.0
Member#: 310009
03 WRX
MBP
Doesnt sound stupid... Its been cold as hell out and I didn't want to spend more time then I had to out there. Helps alot when you know where to look.
I believe I have found my leak... It was rather warm out today and decided to go out and check it out more thoroughly. Removed the alternator and sure enough I found the oil sender unit to be fairly loose. I moved quite freely with a crecent wrench. I tightened it up a bit and now crossing my fingers.
Thanks MD05STI for the help and advice
Old 01-29-2013, 01:23 PM   #13
matts
Member#: 322939
10 WRX
96 LSi
Has anyone had issues sealing the valve covers? I have an issue with the passenger side only. I am on the second gasket, and still have seepage all around the cover. Any pointers on getting this to stop would be greatly appreciated. It is an extremely small amount but it kinda stinks dripping on the uppipe . Im gonna pick up another gasket today.
matts is offline   Reply With Quote
Old 01-29-2013, 01:52 PM   #14
ScoobieRex2.0
Member#: 310009
03 WRX
MBP
Thanks for thread jacking
Make sure your mating surfaces are completely cleaned and free of oil. Apply light coat of specified gasket sealer. Make sure your half moons are not loose (if they are they should get gasket sealer as well). Try and use new bolt cover washers. I dont believe gasket sealer is neccessary for the spark plug o-rings. Lastly make sure your gaskets are on correctly
Old 01-29-2013, 02:05 PM   #15
matts
Member#: 322939
10 WRX
96 LSi
Sorry it looked like a good place to put it.
Thats what I tried to do last time. I dont believe my motor has the half moons you spoke of, and no washers. The bolts are flanged. I may have gotten a bad gasket twice . I tried with and without sealant. I will try again with. The manual says no sealant.
Thanks for the reply.
Old 02-02-2013, 01:43 PM   #16
Fatboy Walrus
Member#: 340333
1997 Impreza OBS 2.2
Is there a good chance the PS is leaking all the way to the back of the engine, passenger side?
Fatboy Walrus is offline   Reply With Quote
