Old 01-27-2013, 09:54 PM   #1
tyrel.boyce
Member#: 270178
2002 Subaru
WRB HTA68 ported
Default Speed Density
I know recently that cobb just came out with speed density for the wrxs and i am curiouse if anyone has dne this setup yet? i need to know what is all needed to run speed density ther than getting rid of your stock MAF.
tyrel.boyce is offline   Reply With Quote
Old 01-27-2013, 10:30 PM   #2
wrxsubiemod
Member#: 165104
E85 bug-i sti swap
Phatron tuned
Searching brought up nothing.
wrxsubiemod is offline   Reply With Quote
Old 01-27-2013, 11:17 PM   #3
the suicidal eggroll
Member#: 51961
2005 STi
Nothing extra is needed to run SD on a typical setup. High boost setups will require a MAP sensor that can read up to their target boost, but that's it. You do NOT want to get rid of your MAF sensor either, since SD is heavily dependent on IAT, which is integrated with your MAF. In fact you will want to re-locate your MAF sensor so that it is between the intercooler and the throttle body (if it isn't already) unless you've already installed an aftermarket IAT sensor in the manifold.
the suicidal eggroll is online now   Reply With Quote
Old 01-27-2013, 11:31 PM   #4
rocketperson7
Member#: 283968
MBP
why somebody who owns an '02 would want Cobb's SD instead of the Carberry ROM baffles me
Old 01-27-2013, 11:34 PM   #5
scby rex
Member#: 104878
02 wrxbastardchild
aw, 1,000,000 whp 2 aw tq
you can wire the iat sensor into the maf wiring and ditch the maf sensor. Hello 4inch intake.
btw, probably should have this in the tuning section.
Old 01-28-2013, 08:29 AM   #6
Nuke209
Member#: 108089
NF Performance
Live tuning
Supported by many tuners (who tunes using cobb)
Old 01-28-2013, 01:32 PM   #7
kellygnsd
Member#: 32669
2007 FR TS EFR 7670
LINK G4 hybrid STi
Originally Posted by Nuke209 View Post
Live tuningSupported by many tuners (who tunes using cobb)
That makes tuning SD a breeze.
kellygnsd is online now   Reply With Quote
Old 01-28-2013, 03:22 PM   #8
belaud
Member#: 224449
2012 CS-STI
さくら
Having your IAT as close as possible to your throttle body is the way to go, you'll have very inaccurate temperature readings using the MAF situated right in front of your filter, best way to go if to find a P&P IAT, or re-wire in an IAT with the MAF harness.
You will also want to get a new MAP sensor that is much more capable than your stock one.
From what I understand, Cobb's SD also has a hybrid function where idling uses MAF, while x+ RPM uses SD, might want to contact them on how it works on further detail.
belaud is offline   Reply With Quote
Old 01-28-2013, 06:46 PM   #9
...CHUCKLES...
Member#: 149674
2006 LimitLess STI
SGM
You could buy a used V1 AEM standalone for around 500 bucks, map sensor 60 bucks and an AIT kit 60. Then you'll be set to do damn near anything you want. OR find out what your local tuner prefers to use.
But all that is needed to be speed density is : MAP, AIT, and Wideband o2 sensors.
I run nothing, but standalone's so I am bias. (I personally don't like the AP, but that's just me)
...CHUCKLES... is offline   Reply With Quote
Old 01-28-2013, 08:16 PM   #10
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
Position your IAT like this ......
binjoau is offline   Reply With Quote
Old 01-29-2013, 12:57 AM   #11
tyrel.boyce
Member#: 270178
2002 Subaru
WRB HTA68 ported
okay thanx guys
Old 01-29-2013, 12:46 PM   #12
scby rex
Member#: 104878
02 wrxbastardchild
My tuner wanted the iat right after the I/c. Might want to contact the tuner you going to use.
Old 01-29-2013, 03:44 PM   #13
abrumlev
Member#: 197920
2005 Legacy GT
ABP
Binjoau was tuned by MPS. I'd say it's probably there for a reason lol.
Wishing someone would get opensource SD on 32 bit ECU's so I don't have to drop 500 on a AP
abrumlev is offline   Reply With Quote
Old 01-29-2013, 03:48 PM   #14
Member#: 51961
2005 STi
You mean like this?
http://romraider.com/forum/viewforum.php?f=37
I've been running it for a while now on my 05 STi, works great. Looks like support for the 05 LGT was added in November 2011.
Old 01-29-2013, 04:10 PM   #15
abrumlev
Member#: 197920
2005 Legacy GT
ABP
*Climbs out from under rock*
Thanks dude ill read into it!!
Message Board Statistics All times are GMT -4. The time now is 11:28 AM.
