Old 01-24-2013, 07:21 PM   #1
slovejoy08
Member#: 332405
2012 WRX Premium
Obsidian Black Pearl
Default 2012wrx data log
ok gurus.
I'm new here, and i did a little datalogging with my AP. I watched the video on cobb's website on what to do. Then i followed through with how to read the 5 most important things. but i still got confused.
I'm currently running a Perrin Stage 1 tune with the drop in filter. Also a Nameless performance muffler delete.
getting ready to go to a stage 2 cobb map after i install my invidia catted dp.
however, I wanna make sure that everything is looking good so far. so here's 2 datalogs if anyone wants to take a look.
https://docs.google.com/spreadsheet/...Ew5dC1Cc01TYUE
https://docs.google.com/spreadsheet/...XNUQlJIQ3VmbGc
let me know what you think.
slovejoy08 is offline   Reply With Quote
Old 01-24-2013, 09:25 PM   #2
veel86
Member#: 308550
2006 Wrx STi
You need to do your 3rd gear pulls at 2000rpm. Also I do see some Fbkc in your first log which isn't a good thing but it is minor. You'll need to do another pull if you can do so safely to see how your car is reacting.
veel86 is offline   Reply With Quote
Old 01-24-2013, 09:36 PM   #3
slovejoy08
Member#: 332405
2012 WRX Premium
Ok. I dont remember the Cobb video saying a gear. So I did a 2nd gear pull. I will do my best to get that up tomorrow. Thanks for the info!
Old 01-24-2013, 10:45 PM   #4
veel86
Member#: 308550
2006 Wrx STi
Yep no problem!
Old 01-25-2013, 08:34 AM   #5
Cobb Tuning
Member#: 4803
Originally Posted by slovejoy08 View Post
ok gurus.
As mentioned, if you can do so safely, try to get a 3rd gear only wide open throttle (WOT) run from around 2500 RPM on up. That will give us a better idea of how boost control looks as well as give an extended run that can check for knock.
Bill
Old 01-25-2013, 10:32 AM   #6
slovejoy08
Member#: 332405
2012 WRX Premium
tried to get a little data logging in before the snow hit southern wv this morning. here's some results.
https://docs.google.com/spreadsheet/...GdOUGVtS21CU3c
https://docs.google.com/spreadsheet/...k0xMmE5Mm9rOWc
Old 01-25-2013, 10:41 AM   #7
subiebosch
Member#: 155548
2015 2500 Dmax
2011 WRX TP STG2 COBB DP
Your boost levels seem pretty low for a stage 1 tune. I'm not sure how Perrins map run, if they are on the conservative side or not, but I only see 13.4 max psi. I run 18 psi on my stage 1 with a TP map and had 16 psi with a COBB OTS map for Stage 1.
You also have some FKL but that could be just noise or the type of gas thats in there now.
subiebosch is offline   Reply With Quote
Old 01-25-2013, 10:46 AM   #8
slovejoy08
Member#: 332405
2012 WRX Premium
i always run 93 octane gas and most of the time it's from the local 7-11 which carries BP gas (i'm pretty sure).
i do know that my target boost is set to 15.5 (saw it on the info for the map). and i noticed i didnt see that on any of the data logs. however, with the AP set to show real time boost, i've seen it hit 16-16.2 some.
but like i've said, i'm not real familar with all of this yet
Old 01-25-2013, 01:00 PM   #9
subiebosch
Member#: 155548
2015 2500 Dmax
I'm not familiar with the Perrin but if you see target boost at 15.5 then that's fine. Although on your 3rd gear pulls it only gets to 13.4, so there is a lot of room for improvement. What's your altitude? this is a factor in the boost you are seeing.
As for the gas, its a long drawn out debate...I've had slight FBL with shell 93, switched to Marathon 93, nothing, then baclto shell and nothing....it really all depends.
Old 01-25-2013, 01:06 PM   #10
Cobb Tuning
Member#: 4803
Map looks like it is targeting about 17.x psi peak boost which you are pretty far off from. I would make sure you do not have their stage 2 map reflashed( that you reflashed a stage 1 map). Boost control is going to be different enough when you finally go stage 2, so it may just be prudent to go stage 2 now (install downpipe) and reflash stage 2 map and see how things look (assuming you do not suspect a boost leak or other issue).
Bill
Old 01-25-2013, 01:43 PM   #11
slovejoy08
Member#: 332405
2012 WRX Premium
it looks like an approximate altitude is around 1300 ft (some quick googling)
i defnitely don't have their stage 2 flashed. they "customized" that map for me when i did my AP from them. it's all part of their stage 1 power kit.
i do have my downpipe on it's way, and plan on using just a the cobb stage 2 ots map with it for now. do you all think i should try flashing the cobb stage 1 ots map and see how it does?
Old 01-25-2013, 10:38 PM   #12
subiebosch
Member#: 155548
2015 2500 Dmax
I would say try it, no harm in trying...but..I don't know if the drop in filter will make cause any issues. COBB's OTS maps are generally really nice...I ran with it for about 8k miles or so.
if you do flash it, get a 3rd gear log, or just wait for the downpipe, install it, and then do a 3rd gear log with the map from COBB.
Your choice, just keep us posted
Old 01-25-2013, 11:28 PM   #13
slovejoy08
Member#: 332405
2012 WRX Premium
If my downpipe isn't in by the time the snow clears away, then ill probably flash cobbs stage 1 and see how it goes.
Hopefully by then, Cobb with chime in about the drop in filter
Old 01-26-2013, 09:20 AM   #14
Cobb Tuning
Member#: 4803
You can give our OTS map a try. We also have high wastegate (HWG) maps for cars that are underboosting that are available in the maps section at cobbtuning.com. But, if you are going to try our maps, try the normal wastegate map first and get a data log. You can also check with Perrin to see if they have a HWG version of their map.
Bill
Old 01-26-2013, 10:38 AM   #15
slovejoy08
Member#: 332405
2012 WRX Premium
Thanks! Ill give it a try!
Old 01-28-2013, 01:51 PM   #16
slovejoy08
Member#: 332405
2012 WRX Premium
haven't had a chance to data log again or go stage 2 yet; however, i did get my downpipe in this morning.
just curious though if cobb's OTS stage 2 map will work with perrin's CAI? i know that it says it's set up for cobb's intake and the AEM intake, just not sure about the perrin.
i know they also have the stock intake maps, but i was going to do a perrin intake with my downpipe
Old 01-29-2013, 09:45 AM   #17
Cobb Tuning
Member#: 4803
You must use only the exact intakes that are designated by the map. Using an intake that the map is not calibrated for can cause fueling and timing errors and potential engine damage. However, you can get a custom tune for a different intake through a protuner for the Accessport. Also, I believe that Perrin sells their own OTS maps that will work with their intake.
Bill
Old 01-29-2013, 07:52 PM   #18
slovejoy08
Member#: 332405
2012 WRX Premium
Update:
I contacted Perrin today, told them what I had and what is on its way. They sent me a stage 2 map (with the jntake) and told me to datalog after I get it all installed. And send it to them.
They were very pleasant. Ill definitely keep everyone posted and I will post the datalogs after I get them.
Just wanted to say thanks for the info too
Old 01-29-2013, 10:05 PM   #19
subiebosch
Member#: 155548
2015 2500 Dmax
Awesome! Please keep us posted, I would love to see what the subie does with a Perrin stage 2 intake and your set up.
Old 01-29-2013, 10:14 PM   #20
slovejoy08
Member#: 332405
2012 WRX Premium
I realized that I haven't given a full list of what's going to be on the car yet.
It's not much. But it's definitely a good start.
Cobb ap (will be running a stage 2 Perrin map)
Perrin cai (silver)
Invidia catted dp
Grimmspeed adapter for exhaust
Nameless performance axle back muffler delete
Crawford AOS
Old 01-29-2013, 10:17 PM   #21
slovejoy08
Member#: 332405
2012 WRX Premium
A few other non performance parts
Perrin pulley cover (silver)
Grimmspeed radiator shroud (black)
Cobb heatshield
Heat wrap for the downpipe
Old 02-27-2013, 10:31 PM   #22
slovejoy08
Member#: 332405
2012 WRX Premium
ok ladies and gentlemen, i'm sorry it has been so long. the car ended up taking a large rock to the driver's rear door. So it was in the shop getting repaired.
I did get everything installed now and have it up and running.
attached are 2 stage 2 datalogs from today.
my target boost is 17.5 and i'm not getting it. i have emailed Perrin about it and they haven't gotten back to me yet (they were probably out of the office by the time i emailed it).
They seem to have excellent customer service so i'm sure they'll be back to me in no time.
but until then...
ENJOY!!
https://docs.google.com/file/d/0B5_N...it?usp=sharing
Old 02-27-2013, 11:01 PM   #23
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
aside from not hitting target boost, everything else looks fine
BigRob74 is offline   Reply With Quote
