01-29-2013, 06:36 PM | #1 |
Member#: 332204
08 2.5i lightweight crank pulley
I was wondering if it was alright to install a light weight crank pulley on my 08 2.5i hatch? Am I gona need a special tool to get the old pulley off?
01-29-2013, 08:28 PM | #2 |
Member#: 271928
Vehicle:2014 WRX Limited Crystal Black Silica |
I don't think you'll need a special tool, a few of my friends have them and have mixed feelings, the rpms drop a lot faster with a light weight it seems like
01-29-2013, 11:00 PM | #3 |
Member#: 124254
Vehicle:2006 06 SGM Slowbaru "The Scoobinator" |
No special tool needed, just a big breaker bar and someone holding the brakes.
01-30-2013, 02:32 AM | #4 |
Member#: 204277
Vehicle:2016 Legacy |
I am on my mobile so I can't see your profile. Automatic or Standard transmission?
01-30-2013, 02:59 AM | #5 |
Member#: 294461
Vehicle:2006 San Remo Wagon Under construction |
Break crank nut loose
Loosen alt and ac tensioners Remove belts Remove stock pulley by wiggling Replace with LW pulley Replace belts Retension belts Torque crank nut to 132 ft/lbs |
01-30-2013, 07:35 PM | #6 |
Member#: 332204
01-31-2013, 12:25 AM | #7 |
Member#: 194990
Vehicle:2008 OBS Steel Silver/Spark Silver |
No special tools needed, and you honestly dont need another person to hold the brakes. I just put it in 5th and jammed a 2x4 on the brake when I did mine. the breaker bar is an ABSOLUTE must though!
01-31-2013, 02:03 AM | #8 |
Member#: 165121
VIC
Vehicle:15 500 White |
it's a stretch fit ac belt on the 08+ so no tensioner. i got my crank pulley off without putting anything to hold the brakes, just had it in 3rd gear with a long breaker bar
02-01-2013, 01:58 AM | #9 |
Member#: 280689
SWIC
Vehicle:0287 OBS/GL10 Dark blue and silver |
Which pully did you use? I'm planning to put one in when I do my timing belt kit and head gaskets in a few months. I have been looking at grimmspeed and perrin.
02-01-2013, 10:08 PM | #10 |
Member#: 165121
VIC
I just took my pulley off to do my timing belt. Might consider getting an lwp down the road
