Old 01-23-2013, 05:38 PM   #26
Mach V Dan
Member#: 12029
Originally Posted by tazswing View Post
Dan:
Could you print out the templates for Stoptech, and maybe Brembo for their 6-pot brake caliper and see if these will fit under the 18x9.5 and then report back to us? This is the motor sports thread afterall
Sure. Got a hyperlink to that?
--Dan
Mach V
FastWRX.com
Old 01-23-2013, 11:21 PM   #27
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Ok.
For AP racing try this link and then go to downloads for the PDF:
http://www.apracing.com/product_deta...32mm_disc.aspx
Here is the link for Stoptech. Same thing, look for the PDF link. I can also email you the PDF files.
http://stoptech.com/Search/Product-D...Ti/BigBrakeKit
I can't dig out a template for Brembo yet. Same thing with Willowood.
tazswing is offline   Reply With Quote
Old 01-24-2013, 01:07 AM   #28
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Dan. You sell the Brembo GT 6-pot, do you have them around to test fit?
Old 01-24-2013, 11:17 AM   #29
Mach V Dan
Member#: 12029
Ok.
For AP racing try this link and then go to downloads for the PDF:...
Here is the link for Stoptech....
The AP and Stoptech 355mm six-pot kits fit the 18x9.5" Wicked Awesome.
They do not fit inside the 17x9 Awesome wheel.
Sorry, I don't keep those laying around.
--Dan
Mach V
FastWRX.com
Old 01-24-2013, 11:51 AM   #30
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Dan:
Thank you so much for taking the time to measure those out! That rules. What a nice set-up that would be, eh?
So, now my goal is: 18x9.5 with the great 42+ off-set to keep inner clearance the same for my year STi. Then run a 275/35 with a 6-pot front and 4-pot rear set-up. Also, looking say at the Toyo R888, the ideal wheel size for the 275/35 is indeed a 9.5 with a range of 9-11.
Thanks again, Dan.
PS-maybe post up this information in the Wheel/Tire forum, too. I know there are others that like to/want to run a 6-pot up front.
Old 01-30-2013, 09:15 AM   #31
Mach V Dan
Member#: 12029
In general, the ideal size for any 275/35R18 is going to be 9.5".
Looks like this!
Good idea. Done.
--Dan
Mach V
FastWRX.com
Old 01-30-2013, 10:47 AM   #32
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
Very cool. And if people are clever and do the math, at least for the GR STi, they will see the height of a 245/40R18 and 275/35R18 is nearly identical (25.6" vs. 25.7" diameter). Why does this matter? Well, for me who runs a daily driver wheels and track set-up it means I don't have to think much about suspension height/alignment going from one set-up to the other. I just commit to an alignment and accept what that will do to daily driven tires and go. Can't ask for much more from a weekend track warrior.
Well, I am saving my money and hope to spring on some of these soon...in black...b/c race pads dust bad
-Taz
Old 09-19-2013, 05:47 PM   #33
Mach V Dan
Member#: 12029
18x9.5" now available in gold. Not that we Motorsports-y people care about appearances...
--Dan
Mach V
FastWRX.com
Old 09-19-2013, 09:04 PM   #34
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Originally Posted by mccanixx View Post
18x11 +22 5x100 perfect for 315's??????? I know, I know. I'm the only one who wants a set. Calling CCW
Originally Posted by subydude View Post
Actually Greg, I'd love a set of 18x11 +22 in 5x114.3. The only ones I've found that are reasonable and light are the Forgestar F14's. If someone wanted to make one that was around 20 lbs though, I'd be down (assuming less than Volk prices).
Any comments on this, or possibilities of something being made?
subydude is offline   Reply With Quote
Old 09-19-2013, 09:05 PM   #35
delongedoug
Member#: 124113
and beyond!
Poop brown or nothing!
delongedoug is offline   Reply With Quote
Old 09-19-2013, 11:29 PM   #36
Splash
Member#: 55936
04 WRX STi
So, why do the 18x9.5 in 5x114 have 73mm center bores, but the 5x100's have 56mm? Any way to get the 5x100's in 73mm center bore?
Splash is offline   Reply With Quote
Old 09-20-2013, 12:03 PM   #37
Mach V Dan
Member#: 12029
Because many 5x114 cars have larger centerbores than Subaru, but few 5x100 cars do. I don't even know if it is possible to have a 73mm centerbore on a 5x100 wheel -- the center would be getting awfully close to the lug holes.
What exactly are you trying to fit these on? The only other common 5x100 cars I know of are VW's, Neons (57.1mm bore), and some Toyotas, most of which have 54mm bore.
--Dan
Mach V
FastWRX.com
Old 09-20-2013, 01:41 PM   #38
Splash
Member#: 55936
04 WRX STi
'04 STI. My current 17" sets of wheels are all 5x100 with a 73mm CB. I use a higher offset (the same 42mm) and use longer studs/10mm spacers up front. Both sets of spacers I have are hub-centric at 56 and wheel centric at 73. I was looking at 18's because I need a 1-inch taller option and was looking to keep using my front spacers for the track width.
There are a few Rotas and a few Enkeis I can get in 18x9.5, 5x100, 73 CB, but it's nice to have options. I was just curious why the Awesomes had that limitation.
Old 09-20-2013, 02:08 PM   #39
Mach V Dan
Member#: 12029
I see.
I can't make the wheel bore larger, but I can sell you Mach V 10mm 56mm/56mm spacers.
--Dan
Mach V
FastWRX.com
Old 05-02-2016, 08:40 PM   #40
Steve Theodore
Member#: 3737
2007 WRX STi
Crystal Gray Metallic
Hey Dan,
I know this thread is literally YEARS old, but I just found it and it has my interest as I'm starting to shop around. Could you please confirm in the photo below that the colors are gunmetal, metal silver, and matte black in that order from left to right?
Thank you sir!
Steve Theodore
Hi all,
I thought I'd post over here about this because our new wheel has some of the properties track guys like, including:
- 17x9" size (+42 offset) -- nice and wide for stuffing some big rubber on
- Light weight at 17.8 pounds
- Flow-formed construction for high strength
- Dual-drilled so they'll fit that crazy hybrid car you built with 5x114 hubs on the front and 5x100 on the back.
- Subaru centerbore size, so no annoying hub rings needed
The wheel is called the Awesome. Okay, sales pitch over.
P.S. Hi, Paisan! Delete this post if you consider this too much advertising and not enough news-worthy...
--Dan
Mach V
FastWRX.com
Steve Theodore is offline   Reply With Quote
Old 05-05-2016, 09:35 PM   #41
metros
Member#: 111343
I'm sure Dan will chime in when he sees this. But there is a thread in the car gallery dedicated to thsee wheels and you can also find them at fastwrx.com. More pictures are always good when wheel shopping.
metros is offline   Reply With Quote
Old 05-06-2016, 09:34 AM   #42
Steve Theodore
Member#: 3737
2007 WRX STi
Thanks metros. I'm pretty sure it's exactly as I thought, but it's always nice to get full confirmation from the seller/creator.
Old 05-09-2016, 02:28 PM   #43
Mach V Dan
Member#: 12029
Yes.
--Dan
Mach V
FastWRX.com
Old 05-09-2016, 05:33 PM   #44
Steve Theodore
Member#: 3737
2007 WRX STi
Thanks Dan, much appreciated!
New wheel! The Awesome from Mach V Mach V Dan Wheels/Tires 69 05-23-2014 01:28 PM
New wheel! The Awesome for all Subaru, from Mach V Mach V Dan Vendor Announcements 53 12-04-2011 10:47 PM
Need parts brought up from Mach V magisimo Tri-State Area Forum 15 04-14-2005 07:48 PM
Pictures from Mach V open house-- webpage currently down saab90089 Tri-State Area Forum 0 03-28-2005 10:17 PM
Hi from Mach V Motorsports. Summer WRX meet? Mach V Dan Mid Atlantic Impreza Club -- MAIC 21 02-14-2002 09:58 PM
