Welcome to the North American Subaru Impreza Owners Club Thursday December 8, 2016
Old 01-30-2013, 12:35 PM   #1
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Default Borg Warner EFR9180-2006 WRX Wagon [email protected] 5300' elevation
Post 153 for track times
Event: Dyno Tune
Ambient Temp: 50
Elevation: 5400'
Weather: cloudy
Tires: Bridgestone RE090's- then again on BFG G force drag radials
Car: 2006 WRX Limited Wagon
Tuner: Myself
Dyno Info: Dynojet
Transmission: 2005 STi 6MT with rallispec long gear set
Gear: 3rd
Peak HP at RPM: 823 at 6700
Peak Torque at RPM: 667 at 6200
Baseline hp/tq for a stock STi: 245-255hp/250-260tq
Target Boost: 33
Target AFR: 11.3
Fuel: E70 (winter blend)
Engine/Power Modifications:
AEM EMS V1
2005 EJ257 Block sleeved by Benson
CP Pistons 99.5mm (moly coated skirts, ceramic crowns)
Carrillo Pro H beam rods, Carrillo bolts
Heat treated oem crank
King bearings
2006 Sti AVCS heads, ported
GSC Stage 2 cams (272, AVCS)
BC +1mm intake/exhaust valves
BC springs, titanium retainers
ARP L19 Studs
08 Sti oil pump, 11mm
TGV deletes
AP Fuel rails
Aeromotive FPR
ID2200cc injectors
Integrated Engineering Surge tank with Dual bosch 044 pumps
Cosworth Intake manifold (reverse mount)
Treadstone fmic core
Full Race Twinscroll T4 rotated turbo kit
BorgWarner EFR 9180 EWG 1.05 T4
Finally got to put the EFR through it's paces. I had previously run the S300SX 91-79 .91 AR on the car and was pretty happy with it.
I am AMAZED that a 94lb/min turbo is spooling 400-500rpm sooner than the older 82lb/min turbo.
On the first trip to the dyno last week I ran my 2007 STi RE090 tires which have good tread but are very dry. The car made 805/636 SAE at 33psi, but I suspected the tires were spinning. Here's a graph of those pulls:
And a graph vs the old 91-79- The 91-79 was at 34psi.
I decided to try the dyno again yesterday, this time with my drag radials. The results were that the car held traction better to about 6500rpm, then let go hard. The tune and boost were untouched from the previous dyno.
Now, SAE numbers are great for bragging rights, but we are at 5400' and our correction factor is pretty high. Here is the uncorrected graph, which in my opinion is still a lot of power for this altitude, at only 33psi ( I want to run 37-38 but need traction). A stage 2 STi only makes 250 uncorrected on this dyno.
Someone want to help me embed these?
https://www.youtube.com/watch?v=ncnswSPEq4M
https://www.youtube.com/watch?v=4u0JHvsxEZc
low quality phone vid of the 823 pull
https://www.youtube.com/watch?v=CViAUFZeBwk
06rexwagon is offline   Reply With Quote
Old 01-30-2013, 12:36 PM   #2
stanghater
Member#: 69381
2005 Legacy GT Wagon
2002 hta green WRX
congrats dude, you da man
stanghater is offline   Reply With Quote
Old 01-30-2013, 12:58 PM   #3
jasonlee4180
Member#: 152819
06 STI
Flatout Bananas
Congrats!!
jasonlee4180 is offline   Reply With Quote
Old 01-30-2013, 01:02 PM   #4
NF Performance
Member#: 345246
Congratulations Cam
-NF
NF Performance is offline   Reply With Quote
Old 01-30-2013, 01:04 PM   #5
tmacs29
Member#: 232555
03 WRX
Good job cam!
tmacs29 is offline   Reply With Quote
Old 01-30-2013, 01:09 PM   #6
Cefaln452
Member#: 255736
2004 STi
JavaBlackPearl
beautiful
Cefaln452 is offline   Reply With Quote
Old 01-30-2013, 01:13 PM   #7
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
Nice car!
This is making me anxious to get my Borg up and running, your car makes me think I might have actually been under-estimating the power band my S400SX is going to end up with.
RexFTW is offline   Reply With Quote
Old 01-30-2013, 01:17 PM   #8
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Wow! Looks great! Love the top end. Any plans to rev it higher? Maybe do some road tuning if you can't get it to stick on the dyno?
Here are the embedded videos:
Old 01-30-2013, 01:23 PM   #9
06rexwagon
Member#: 114730
[email protected]
Video Link: http://www.youtube.com/watch?v=ncnswSPEq4M
Video Link: http://www.youtube.com/watch?v=4u0JHvsxEZc
Video Link: http://www.youtube.com/watch?v=CViAUFZeBwk
I will rev to 8500 and once it warms up I'll tune it on the road. The tires spun at 21psi yesterday because it was so cold.
Old 01-30-2013, 01:55 PM   #10
Layvon
Member#: 195711
STi 04/05/06/07
Holy wah
Old 01-30-2013, 02:23 PM   #11
dhunckyn
Member#: 98553
2013 WRX Hatch
over inflated high altitude dyno What are the uncorrected #s
dhunckyn is offline   Reply With Quote
Old 01-30-2013, 02:36 PM   #12
06rexwagon
Member#: 114730
[email protected]
Check the first post Brian, 711 uncorrected.
Old 01-30-2013, 03:21 PM   #13
dhunckyn
Member#: 98553
2013 WRX Hatch
that would require reading... not my strong point. When are you heading to the track?
Old 01-30-2013, 03:47 PM   #14
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
thats nuts!
Bariga is offline   Reply With Quote
Old 01-30-2013, 04:00 PM   #15
NoGraffix
Member#: 276209
I am Rub
Function>Form
bravo. Cant wait to see time slips
NoGraffix is offline   Reply With Quote
Old 01-30-2013, 04:09 PM   #16
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Evo's report an exhaust restriction at around 750whp when running a 3.5" diameter. What are you on, and do you think it plays a factor?
Edited because of Geoff's correction: THANKS!
Zee Biker is online now   Reply With Quote
Old 01-30-2013, 04:19 PM   #17
DevourU
Member#: 344344
2006 STi
Urban Grey
Hell yeah Congrats Cam! Now come pick me up so I can go for a ride hahahaha
DevourU is offline   Reply With Quote
Old 01-30-2013, 05:00 PM   #18
06rexwagon
Member#: 114730
[email protected]
Originally Posted by Zee Biker View Post
Evo's report an exhaust restriction at around 700whp when running a 3.5" diameter. What are you on, and do you think it plays a factor?
Seems like I'm fine with a 3" exhaust, egt is 1400. Still running a full TBE too, no cutout
Old 01-30-2013, 05:14 PM   #19
MMY MSL
Member#: 335135
2007 WRX
WRC blue
I hope this car goes to the dragstrip.
MMY MSL is offline   Reply With Quote
Old 01-30-2013, 07:18 PM   #20
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Cam does it again! Great work dude, I'm glad we have you in our neck of the woods. Incredible numbers for our altitude! I can't wait for you to hit the track! Congrats!
wgr73 is offline   Reply With Quote
Old 01-30-2013, 07:34 PM   #21
WagonGGA
Member#: 134481
08/4 Subaru
Legacy Spec B/Forester XT
Good job, cant wait to see what it does at the track. Good luck!
WagonGGA is offline   Reply With Quote
Old 01-30-2013, 07:35 PM   #22
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
awwww yeah cam!!! just threw this up on the FB page
disagree - 3" is perfect for up to 750WHP.
from 800->1000WHP 3.5" is the call.
for 1100+HP 4" is the way to go.
Full-Race Geoff is offline   Reply With Quote
Old 01-30-2013, 08:00 PM   #23
3MI Racing
Member#: 200987
^^^But Geoff, what should I do for 1000-1100? j/k
With all this wheelspin talk, did you log RPM vs. mph (or any type of speed on the dyno)? It'll let you know if you're spinning tires (or clutch or tire on rim). Most overlook tire on rim issues but you may want to mark. It is one issue we ran into on the Turn In Concepts time attack car last season and you're running more power here than we ever used on the track.
Awesome numbers! Should be great to see what it does at the strip.
3MI Racing is offline   Reply With Quote
Old 01-30-2013, 08:01 PM   #24
xdrian
Member#: 104200
000 WHP BUGEYE
Street Proven Performance
congrats guys, nice looking powerband. cant wait to see how fast these subies go this year!
xdrian is offline   Reply With Quote
Old 01-30-2013, 08:49 PM   #25
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Dayum!!! That's crazy power.
