Old 01-26-2013, 11:40 PM   #151
ckyguy68
Member#: 316296
2006 STIROID
[email protected] on 29psi
Originally Posted by Kas Type R View Post
Awesome build thread & very nice Subaru. I know its not been updated for a while, however I just wanted to know if you are running spacers on your wheels, if so whats the size?
Thanks for the compliment! The car is under-going a few changes right now and updates will come soon. No spacers on the wheels! The tires have a meaty look and it gives them a wider look.
Old 01-30-2013, 02:14 AM   #152
Andor
Member#: 251890
2007 STI
UGM
WoW amazing build and the 37 just screams!!! Using the high revs is def. helping you make up for the 06 tranny. I am currently getting my bottom end built but after this, gonna be straight broke! Slowly gonna start getting closer to the 500 range. Inspiration! Def keep updating with pics and video's! Sub.!
Andor is offline   Reply With Quote
Old 01-30-2013, 03:44 PM   #153
Kas Type R
Member#: 231425
2003 STi
I watched all your vids on youtube & glad I found this thread showing the full spec & work put in.
Check my username out on youtube Invader442
Kas Type R is offline   Reply With Quote
Old 01-30-2013, 06:47 PM   #154
ckyguy68
Member#: 316296
2006 STIROID
Thanks guys. Glad I'm able to pass on the enjoyment of the car to people. Stay tuned to the thread, I am putting together a fresh engine for the car very soon, just waiting on Darton East and some free time. My partner and I just got a shop and we have a few projects going on simultaneously.
Old 02-06-2013, 11:18 AM   #155
Kas Type R
Member#: 231425
2003 STi
What happened to the previous engine or is it just a better build your going for?
Old 02-06-2013, 09:35 PM   #156
ckyguy68
Member#: 316296
2006 STIROID
Just wanted to start over fresh, the previous engine from the previous owner had been rebuild a quite few times and it was just a tired block. I did not like the bore size and custom piston size and the machine work done to the block had brought the deck height down to the point where I had to run .060 head gaskets to keep things safe.
I'm very excited to be working with a fresh sleeved and o-ringed 99.5 bore with all fresh parts! The car is at my shop right now and the case halves are almost complete at Darton! I will be starting the new build once I get a pile of parts going but I plan on adding quite a few new features!
Oh, and I'm going E85
Old 02-07-2013, 11:51 PM   #157
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Do it . Yeah I can't wait to get a benson sleeved block and see what I think about one of those
Old 02-19-2013, 06:39 PM   #158
glyne
Member#: 196686
2008 wrx sti
metalic gray
Man that looks awesome!!!
glyne is offline   Reply With Quote
Old 04-04-2013, 08:51 PM   #159
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
DD time!
Old 04-04-2013, 11:08 PM   #160
ckyguy68
Member#: 316296
2006 STIROID
Originally Posted by FuJi K View Post
DD time!
Fresh shortblock, all new parts, shaving off over 100 grams per cylinder... DD head porting by the *FAMOUS* Fuji K .... stay tuned for updates!
Old 04-16-2013, 09:56 PM   #161
c bear 199
Member#: 352614
Default Nice.
Man i love your car. Im located Northwest Ohio, if your ever in the area I need a ride in this thing.
c bear 199 is offline   Reply With Quote
Old 04-23-2013, 01:40 PM   #162
0to115in11
Member#: 140832
What size reducer fitting are you running for the oil feed on that turbo?
0to115in11 is offline   Reply With Quote
Old 04-26-2013, 09:08 AM   #163
kaleonearth
Member#: 274436
2011 STI
Unobtanium Grey
Incredible build. Very nice on the attention to detail!
kaleonearth is offline   Reply With Quote
Old 04-26-2013, 03:34 PM   #164
ckyguy68
Member#: 316296
2006 STIROID
Let me check when I am over at the shop this weekend.
Thank you very much... My next build will begin in a week or so, That will be even cleaner!
Old 05-20-2013, 11:30 AM   #165
PSBeachBum
Member#: 279870
2005 WRX Wagon
think you can give me $1500? im not greedy lol. Gawd I wish I had money to do something big to my car besides basic power mods and tuning
PSBeachBum is offline   Reply With Quote
Old 05-20-2013, 11:33 AM   #166
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Me too man
Old 06-03-2013, 05:47 PM   #167
ckyguy68
Member#: 316296
2006 STIROID
Default Update!!
After running the engine hard last fall and having a few discrepancies with the 4x rebuilt block, we decided to tear it down and part it out... only to start over with a fresh setup!
I'm shaving over 130 grams per cylinder with the new rotating assembly!
Another Darton-Sleeved EJ25 w/ mild oil galley porting
99.5 Stock bore
Wiseco Custom-Spec 8.3:1 pistons
Carrillo Pro H Beam rods w/ CARR 3/8" Bolts
OEM Induction hardened crankshaft
OEM 10mm Oil Pump
Killer B Oil Pan, windage tray, and pickup (parts look GREAT, Chris)
Rotating assembly is balanced and blueprinted.
Main clearance- .0017"-.0019"
Rod clearance- .0019-.0021"
Heads by FUJI K.... "DDs yo!"
+1 Inconel Supertech exhaust valves
SS Supertech Intake valves
Brian Crower S3 280* cams (worked awesome last year)
2.5 N/A Intake manifold
Switching to E85...
ID 2000s
Twin Walbro 460s
-8 feed -6 return
Exedy Triple Disc Cerametallic w/ HD cover
Mostly the same components as last year as far as turbo and exhaust
Updating with pics soon!
Old 06-03-2013, 05:47 PM   #168
ckyguy68
Member#: 316296
2006 STIROID
Ready for clearances!
Main clearances
So nice
All Clean
Stretching the Rod bolts
Old 06-03-2013, 05:47 PM   #169
ckyguy68
Member#: 316296
2006 STIROID
Ever wonder why Evos make such high numbers? Take a look at the crank comparison. Journal size, and oiling holes
If you Don't have one of these..... buy one!!!
Decided to put the pan on since I don't have my heads yet.
Old 06-03-2013, 05:48 PM   #170
ckyguy68
Member#: 316296
2006 STIROID
one more reserve
Old 06-03-2013, 06:46 PM   #171
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Looking good man.
Might end up running one of the 460's on a pressure switch if it gives you problems idling and stuff and if your not already doing that!
Old 06-03-2013, 08:31 PM   #172
ckyguy68
Member#: 316296
2006 STIROID
Originally Posted by stretchedk7 View Post
Looking good man.
Thanks. I was thinking about running the pressure switch, have you incorporated any failsafe into one?
Old 06-03-2013, 09:36 PM   #173
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
I personally havent. Thats one of the reasons I ended up just using one big pump. If your on an aftermarket ecu though you could setup some fail safe strategies. They are pretty reliable though
Old 07-27-2013, 06:29 PM   #174
What v8
Member#: 254718
sweet build man, mine will be done here soon. Hoping for high 5s to low 6s. im on a gtx3582 but im probably gunna go biggeer next season to try to get it in the 9s.
What v8 is offline   Reply With Quote
Old 07-30-2013, 03:58 PM   #175
Bones Malone
Member#: 301509
How hard is it to set up twin 460's?
Bones Malone is offline   Reply With Quote
