Old 01-24-2013, 11:40 AM   #326
sabregen
Member#: 338852
2013 WRX Premium
WR Blue
Originally Posted by cm26484 View Post
I have my nexus 7 temporarily installed on my dash until I get the rest of the parts in the mail. I noticed a problem for me. When my tablet is in landscape mode and I am wearing my polarized sunglasses I can not see the screen. Being that I live in Florida this is a big problem. I guess I will have to get different sunglasses that are not polarized, or if I do, they must be at a different angle than the nexus 7.
Not sure if this is an issue with anyone else, but wanted to bring it up.
i have the exact same issue here in Phoenix with my Oakley FastJackets. i had to switch back to my Smith's for the WRX driving and keep my Oakleys for the 911.
sabregen is offline   Reply With Quote
Old 01-24-2013, 02:29 PM   #327
cm26484
Member#: 284582
Dark Grey Metallic
So i had a thought last night and I got to working on an animation that plays everytime I start my car. I set up tasker to play a video that I made so it appears as if the Nexus 7 is booting up when the car starts.
Here is a screenshot of the animation.
cm26484 is offline   Reply With Quote
Old 01-24-2013, 02:50 PM   #328
leed
Member#: 336303
2009 OBS
Blue/Silver
I didn't read through all the pages in this thread, but I thought I'd mention.. For those of you who are retrofitting 12V sockets and using car chargers as charging options but have the issue of the limitation of charging amperage, if you short the two data pins (solder works best) on the charger Android devices will recognize the charger as AC, and will allow for more current. The data pins are the two middle pins on the typical USB A plugs/outlets.
leed is offline   Reply With Quote
Old 01-24-2013, 02:54 PM   #329
zedix
Member#: 336913
2010 Impreza Ltd
Evidence over at XDA developers show that shorting the pins makes no impact to the amount of current that the Nexus 7 will draw. It only affects whether the tablet shows "AC" or "USB". For what it's worth, I tried shorting the 2 pins on my USB charger and it had no impact.
zedix is offline   Reply With Quote
Old 01-24-2013, 03:59 PM   #330
onsit
Member#: 292225
08 VF52 WRX
I was able to get a larger charge after switching to an OTG usb adapter, a Y connector, and running the custom Charging OTG Kernel.
Charging is now at close to 900mA under heavy usage. Not to mention the benefits of running a 5 port hub.
Zedix. Have you seen that other guy, that made the sweet plexiglass backing + reusing a holding case.
onsit is online now   Reply With Quote
Old 01-24-2013, 04:04 PM   #331
zedix
Member#: 336913
2010 Impreza Ltd
Absolutely, posted in his thread. Awesome worksmanship. Major difference is that his audio runs through BT and a Parrott device as opposed to a full HU.
Old 01-24-2013, 08:29 PM   #332
leed
Member#: 336303
2009 OBS
Blue/Silver
Interesting! I actually only use it for my Galaxy Nexus phone but it keeps me in the positive. Before it I was getting minimal (no where near 1A) charge. Thatasaid, perhaps it is quite different for the Tablet since the battery capacity and rate of consumption/charge is vastly different. I was also kind of surprised that it charges through USB alone as well, since some of the older (albeit larger) tablets go through a standard coax power connector.
Old 01-25-2013, 02:45 AM   #333
Andrew025
Member#: 303408
04 STi
Originally Posted by xjamit View Post
how you get wifi going down the highway???
Use phone for hot spot.
Andrew025 is offline   Reply With Quote
Old 01-25-2013, 07:40 AM   #334
onsit
Member#: 292225
08 VF52 WRX
Battery finally was 100% dead when I started my car.
The bootloader fix worked perfectly, once it detected USB power it took care of the reboot process.
Old 01-26-2013, 05:36 PM   #335
rkl303
Member#: 171314
2008 STI
Found this for those of us who are waiting for something with an external sd card (although I hear samsung is cancelling their plans on another 7") and use spotify (since those ass hats took away our external sd storage option about a year ago)
http://forum.xda-developers.com/show....php?t=2027834
rkl303 is offline   Reply With Quote
Old 01-27-2013, 01:37 PM   #336
sabregen
Member#: 338852
2013 WRX Premium
WR Blue
checked out the Samsung galaxy Tab 7" at Costco for like $185 for the 8GB version. no additional charging port, but had a microSD slot for storage and the profile appears to be nearly identical to the Nexus7. that's a cheaper option and entry price for those of you thinking about doing this. microSD cards a much cheaper option than the Kingston Wi-Drive that I bought to expand my storage.
sidebar - ordered BT OBD2 adapter, 1ft microUSB right angle cable (to help with charging) and also going to have a high amperage cigarette lighter adapter ready to be wired in should the need arise. since i haven't totally nailed down the mounting yet, i may also yank the wiring harness that i did and clean up the connections now that i have sleeving and an assortment of heat shrink tubing, make it a little cleaner in there.
also returning my 32GB Wi-Drive and have a 128GB one on the way.
Old 01-27-2013, 02:01 PM   #337
sabregen
Member#: 338852
2013 WRX Premium
WR Blue
That's pretty awesome. Any chance you have a host for that file so we can all (looks around)... uhh... borrow it?
Old 01-29-2013, 07:14 PM   #338
sabregen
Member#: 338852
2013 WRX Premium
WR Blue
128GB Wi-Drive received and up and running. 32GB returned. 1ft Star-Tech right angle Micro-USB received and charging MUCH better now. Also threw a screen protector/anti-glare filter/anti-smudge cover on the screen. looks MUCH better than the glossy finish, and is going to be great for this application of the Nexus 7.
Also got a micro ELM 327 adapter and downloaded Torque. Should be pretty nice!
Old 01-30-2013, 11:17 AM   #339
Rescuer
Member#: 176692
check out what i saw on lifehacker this morning
http://lifehacker.com/5980076/this-d...-road-with-you
Knight Rider Themed launcher! with car mounted nexus 7
Rescuer is offline   Reply With Quote
Old 01-30-2013, 11:55 AM   #340
Vater
Member#: 267354
2011 STI Limited
My in-car tablet theme would be
Vater is offline   Reply With Quote
Old 01-30-2013, 04:15 PM   #341
WREXMachina
Member#: 275929
02 WRX
Originally Posted by rkl303 View Post
Looks like the ebay charger is recognized as an AC unit which is great
http://www.ebay.com/itm/DC-Converter...1176956166%26#
Don't know why it says 4 amps though although my galaxy note 2 OEM AC unit is recognized as ~4amps as well even though it says 2 amps on the charger
You're not reading the graph correctly. Approximately 25% an hours on a 4Ah battery is 1A charging input. The only thing that says '4' there is the battery size.
WREXMachina is offline   Reply With Quote
Old 01-30-2013, 09:05 PM   #342
sabregen
Member#: 338852
2013 WRX Premium
WR Blue
shortened cable helped with charging. getting +~500mA now. haven't quite figured out Torque yet.
Old 01-30-2013, 09:10 PM   #343
chitownbugi
Member#: 344990
03 WRX Sedan
really cool! my friend had a setup like that in his TL but it was mounted in a lower spot instead of replacing the head unit!
chitownbugi is online now   Reply With Quote
Old 01-30-2013, 09:42 PM   #344
cm26484
Member#: 284582
Dark Grey Metallic
For anyone who would like the WRX animation, I can email it over. Feel free to PM me your email address for me to send it to. The video is under 5 MB.
I can also make an STi animation if anyone would like it.
Old 01-30-2013, 09:58 PM   #345
Andrew025
Member#: 303408
04 STi
Yes on the sti animation
Old 01-30-2013, 10:54 PM   #346
cm26484
Member#: 284582
Dark Grey Metallic
I will work on it tomorrow night. I am assuming you would like the sti to be red.
Old 01-30-2013, 11:55 PM   #347
fordskydog
Member#: 190937
2011 IMpreza WRX
Obsidian Black Pearl
Is that a start button on the console?
fordskydog is offline   Reply With Quote
Old 01-31-2013, 12:51 AM   #348
fordskydog
Member#: 190937
2011 IMpreza WRX
I found a deal on a Lenovo Thinkpad A1. Cool thing is it has an fm tuner built in. Bonus. I will relocate factory nav headunit (not very fond of it, or satellite radio) and run tablet audio to it. I will pair my phone with tab and factory unit so calls come through, and so the interwebs are shared. Already have Torque Pro set up with the obdii dongle.
software and solutions to find:
-good main ui. seen several around. KITT? probably
-how does fm tuner work on that thing?
-write macros if needed to automate all the wireless handshakes required.
-upgrade tab to 4.0x or cm7, mainly for better voice recognition/root. always on voice rec?
-pair sixaxis controller and setup some games, mainly to impress brother
-keyboard? dammit. do I need a keyboard in my car now? probably not... use phone as mini keyboard? that would be cool
-hey! I can use that traffic/camera/radar database now! sweet!
-it would be great to have a map/traffic/weather overlay going on
-set up rss feeds for weather and aggregate podcasts for the morning commute
-how bout use my wifi outside the house to grab feeds to cut down phone data usage
-app to let tab place calls on phone
-setup Five Guys app. sweet
pipe dreams:
-wireless charging mat for phone. theoretically possible. seen a diy
-wireless (hell, wired) openport interface. flash different tunes from the car! that'd be schweet
-wireless cam? be great to use the video/telemetry record on Torque. phone's camera on windshield mount?
-peep cams on bumpers
-drive car from phone/sixaxis
-50 more torqs
Old 01-31-2013, 08:48 AM   #349
dcwiker05
Member#: 227864
1995 Impreza L WRX
Aegean Blue Metallic
Originally Posted by fordskydog View Post
-50 more torqs
Just add A NOS sticker to get that! lmao
As for the rest of your list sounds like a bad ass set up if you can get it all worked out. I've gotta get my car running cuz i have tons of ideas for this too
dcwiker05 is offline   Reply With Quote
Old 01-31-2013, 09:46 PM   #350
cm26484
Member#: 284582
Dark Grey Metallic
sti animation is done. Anyone who would like it, PM me your email and I will send it to you. Under 5 MB file size.
Message Board Statistics All times are GMT -4. The time now is 01:29 PM.
