Old 12-18-2012, 04:01 PM   #26
jburke311
Member#: 317060
very nicely done man
jburke311 is offline   Reply With Quote
Old 12-21-2012, 09:46 PM   #27
DohcEj22e
Member#: 289011
Thank you!
DohcEj22e is offline   Reply With Quote
Old 12-22-2012, 10:09 PM   #28
NordiX
Member#: 33439
WR Pearl Blue
I'm posting so I can subscribe to the thread and easily find it forever. Kudos on a really smart build. I am considering a similar turbo hybrid using a 22e and my 03's EJ20. Your project is very inspiring to say the least.
NordiX is offline   Reply With Quote
Old 12-25-2012, 08:09 PM   #29
DohcEj22e
Member#: 289011
Thank you!
Your 205 heads on the 22e block will induce lots of smiling since you'll be gaining low-end tq w/the increased displacement.
The DOHC 2.2 hybrid is a generally smooth & reliable build.
I've not experienced any issues caused by the engine & it remains reliable & ready to work every time I turn the key.
Old 01-11-2013, 05:43 PM   #30
DohcEj22e
Member#: 289011
Update on how it currently looks.
Old 01-31-2013, 11:41 AM   #31
DohcEj22e
Member#: 289011
The engine is going on 8k miles of use (108k on the 22E block & 173k on the heads) & it hasn't given me a single problem in a long while.
The low-end could use some touching up, which has me looking into cams & stiff 257 valve springs.
I haven't gotten bored of it but because of it's midrange power, I find myself staying there a lot of the time.
With power mode switched on, this becomes a very responsive, fun little car that's good to drive because you can fling it around in the snow, corners, & rev the hell out of it.
From what I've personally experienced, I'd place the power order like this (from weakest to strongest):
SOHC 22E.
DOHC 22E.
SOHC 22T.
DOHC 25D.
SOHC 25D.
DOHC 22T.
Also, I have gotten the JDM side marker lights & I will install them once I get the wiring needed to do so.
It's going to take me a while to turbocharge the engine because I'm going to focus on my mod list & start at the top, which are brakes & suspension, then transmission & differentials, & then lastly, the engine.
Message Board Statistics All times are GMT -4. The time now is 03:10 AM.
