Old 01-28-2013, 12:49 PM   #126
Irv Weissmanhowerton
Member#: 278519
KBiz KeeganLB 30rSTI
phatron tuned
remembering on rons car when we used some hose clamps or t-bolt clamps on the part where it bends, to stiffen it up to prevent collapsing & keep it open smooth around the bend, that seemed to work pretty well, but yea, I def feel bad for those stock location guys and that kink
Old 01-31-2013, 08:33 AM   #127
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
FMIC is here
Old 01-31-2013, 09:15 AM   #128
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Nice, set 4-5 hours aside and install that thing and lets really see what this Fp Black can do.lol
Slimsti is offline   Reply With Quote
Old 01-31-2013, 11:47 AM   #129
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
well...i doubt juan will turn it up all the way...he's scared his rods will create a MUCH larger crank vent like my ET rods did ...just do it already...we all know that you aren't going to be satisfied with it until you do
Old 01-31-2013, 12:08 PM   #130
Subian
Member#: 202804
2002 PSM Sedan
20g/ewg/Phattbotti Tuned
Originally Posted by juanmedina View Post
FMIC is here
Do a back to back comparison and see if the FMIC adds any lag and flows more air with that black of yours.
Subian is offline   Reply With Quote
Old 01-31-2013, 12:23 PM   #131
Slimsti
Member#: 155696
on my dom 3 when i switched from a large tmic to my fmic i only added 300rpm of lag. It was basically unnoticable on the street and the power just felt "smoother"? I guess thats how i could explain it.
Old 01-31-2013, 12:30 PM   #132
Nuke209
Member#: 108089
NF Performance
30+ psi or bust
Old 01-31-2013, 12:55 PM   #133
juanmedina
Member#: 133146
07 FPgreen 7.37@95
I cannot turn it up because I am out of injector right now. I don't know when the 2200cc are going to go in. Some day I will turn it up . You guys have to realize that my car weights like 3050lbs with me in it, so it feels like a regular 550-560whp car every time I drive it .
I will. I am going to use the same map and try to keep all the parameters the same when I do test. I am expecting 250rpm of extra lag but I really hope to gain 10-20whp keeping everything the same. We will see
Old 01-31-2013, 12:55 PM   #134
juanmedina
Member#: 133146
07 FPgreen 7.37@95
Originally Posted by Nuke209 View Post
30+ psi or bust
you just want me blow my engine
Old 01-31-2013, 01:32 PM   #135
MMY MSL
Member#: 335135
2002 Forester S
Blue Ridge Pearl
Looking forward to the new graphs with the FMIC. Any ETA?
MMY MSL is offline   Reply With Quote
Old 01-31-2013, 01:48 PM   #136
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
30+ psi or bust
Haha!
07wrx84 is offline   Reply With Quote
Old 01-31-2013, 01:48 PM   #137
juanmedina
Member#: 133146
07 FPgreen 7.37@95
Maybe this weekend.
The FMIC came with a catch can/coolant overflow tank. I am going to relocate my coolant overflow tank and use the perrin tank as a catch can.
How should I route the lines?
Old 01-31-2013, 02:04 PM   #138
Nuke209
Member#: 108089
NF Performance
oh c'mon. i just want to see your car make power!...
Old 01-31-2013, 02:12 PM   #139
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
you can keep the parameters the same (boost, timing, afr), but you're not going to accomplish that using the same map.
If you put a fmic on a tmic map and just go do a wot pull, your boost isnt going to be where it was and your AFR is going to be 0.5-1.5 rich around peak boost.
for the catch cans, the easiest way is just to run new lines from the heads straight to the can....which is why people utilize 2 cans. so you dont have 10 ft of lines going from each head to one single can.
the problem doing this with the stock location turbo inlet is that you need to start plugging off the big ass holes.....
Old 01-31-2013, 02:25 PM   #140
juanmedina
Member#: 133146
07 FPgreen 7.37@95
Well is going to have to be adjust.... I send you the MAF tab later today.
Old 01-31-2013, 02:57 PM   #141
GT35RHybrid
Member#: 223237
For what it's worth I was boosting 30-31 psi on my last build. LOL
GT35RHybrid is offline   Reply With Quote
Old 01-31-2013, 03:14 PM   #142
Paul
Member#: 56203
00 RSTI Coupe
Ron is tuning the car?....I thought you were a tuner now Juan?
Old 01-31-2013, 03:14 PM   #143
juanmedina
Member#: 133146
07 FPgreen 7.37@95
According to you graph you made 527whp at 28psi and trapped 136mph . Mine should be somewhat lighter than your, we will see what I trap.
Old 01-31-2013, 03:16 PM   #144
juanmedina
Member#: 133146
07 FPgreen 7.37@95
lol I am not a tuner, I am an ethusiast.
Ron is tuning the car because that was the deal between FiveO and Phatbotti. I know I am in great hands
Old 01-31-2013, 03:55 PM   #145
juanmedina
Member#: 133146
07 FPgreen 7.37@95
Maybe this weekend.
So, output to what numbered nipple and input to what numbered nipple?
Old 01-31-2013, 06:43 PM   #146
Phatron
Member#: 36033
CEO PhatBottiTuning
man, you really need to find your leak before you start doing all this stuff.
we know your car has a leak right now. but if you go and put on teh fmic and 20ft of hoses, its going to make it much more of a pita to find it.
Old 02-03-2013, 10:15 PM   #147
juanmedina
Member#: 133146
07 FPgreen 7.37@95
almost done...
Old 02-04-2013, 09:13 PM   #148
wrxsubiemod
Member#: 165104
E85 bug-i sti swap
Phatron tuned
Looks like a power gain to me
wrxsubiemod is offline   Reply With Quote
Old 02-04-2013, 09:31 PM   #149
Phatron
Member#: 36033
CEO PhatBottiTuning
dual intercoolers ftw
Old 02-04-2013, 10:28 PM   #150
fastblueufo
Member#: 212154
02 bugeye, manley
ej257, pt5857, MBP on E85
Do what Ron said and just plug the holes. Run head vents to one catch can and run the two case breathers to another catch can. Then vent both to atmosphere using good mesh filters. That's the best way unless your motor has a lot of access crank case pressure. In that case your mesh filters will be oily all the time. Vent to atmoshere only if your speed density. If your on maf then you need to run back to turbo inlet.
fastblueufo is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 02:46 AM.
