Old 01-08-2013, 11:00 AM   #101
CO11WRX
Member#: 304018
2011 WRX Sedan
For those interested in ordering the green spring: When I placed my order I assumed it would be shipped from the UK and, as a result, additional customs charges MIGHT be applied to my order. Based on the UPS tracking info I received yesterday, it looks like the part was shipped from Forge's Florida location. I should have the spring by Friday afternoon. Just FYI...
CO11WRX is offline   Reply With Quote
Old 01-08-2013, 09:22 PM   #102
ResidentR
Member#: 281656
2011 WRX Limited
Mine should be here Friday as well. Shipping was 12$ for an 8$ spring so I sure as hell hope it comes from overseas, haha.
ResidentR is offline   Reply With Quote
Old 01-09-2013, 10:45 AM   #103
CO11WRX
Member#: 304018
2011 WRX Sedan
That is exactly what I paid for shipping. I bet it comes from Florida like mine. (I just checked my tracking # ; the package is in Missouri now; its about half way here lol)
Old 01-09-2013, 04:57 PM   #104
ResidentR
Member#: 281656
2011 WRX Limited
Got mine today. Package did come from Florida, but it also came with a pretty awesome bottle opener that I am sure costs several times more to manufacture than what the spring did.
Will throw it in the car this evening and check it out.
Old 01-09-2013, 05:48 PM   #105
CO11WRX
Member#: 304018
2011 WRX Sedan
Nice! I hope I get one as well! It is pretty amusing that the shipping costs more than the product itself.
Old 01-11-2013, 03:28 PM   #106
CO11WRX
Member#: 304018
2011 WRX Sedan
How is your car running with the green? I just got mine in the mail (no bottle opener though ). I have not thrown mine in yet (I will probably do it tomorrow since its starting to snow like a bi**h here).
Old 01-12-2013, 04:58 AM   #107
ResidentR
Member#: 281656
2011 WRX Limited
Seems to be a little smoother now, give me a few more days to drive it before I really say anything. Could all just be in my head.
Still worth it to me though.
Old 01-13-2013, 07:12 PM   #108
CO11WRX
Member#: 304018
2011 WRX Sedan
I just put mine on a few hours ago. The flutter noise is gone, but now it seems like the valve is opening when it shouldnt. I will be in second gear with just a little throttle and I can hear what sounds like the BPV opening. I havent gone WOT yet since our roads are pretty icy. I think I am going to experiment with using the shims to see if I can figure this out. Not sure what exactly is happening at the moment.
Old 01-13-2013, 08:38 PM   #109
dangyo
Member#: 289786
2011 WRX Hatch
ive been running my forge bpv with the yellow spring and one shim for quite a few months now and seems to be perfect to me. no problems, im stage 2 + sf intake
dangyo is offline   Reply With Quote
Old 01-13-2013, 10:08 PM   #110
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
I run the yellow spring as well at stage 2 and have no issues. 19 psi and holds great.
HeroCrank is online now   Reply With Quote
Old 01-14-2013, 12:41 AM   #111
CO11WRX
Member#: 304018
2011 WRX Sedan
Honestly, I think it may just be how I am driving. I've been testing with the green spring for a bit and I believe I may just be letting off the throttle just a tiny bit, causing the BPV to open (even though the RPM's continue to climb). With the green spring, the valve seems to open much easier than with the yellow (which is to be expected). I think what I am doing is easing off the throttle just a tiny bit a few seconds before I shift into the next gear causing the BPV to vent. I was most likely doing the same thing when the yellow spring was installed but due to the heavier spring, the BPV was not venting as easily. I will know for sure tomorrow after doing some additional data logging.
Old 01-14-2013, 06:52 AM   #112
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Nice, keep us updated.
Old 01-15-2013, 01:21 AM   #113
CO11WRX
Member#: 304018
2011 WRX Sedan
Alright, here is what I found when using the green spring (w/o shims). I was using my Cobb AP to monitor boost pressure during this test. Whenever the AP shows a negative PSI (I assume this represents vacuum) I can hear what sounds like air being vented through the BPV. This only occurs if I am very light on the throttle and allow the RPM's to slowly increase. As soon as the AP reports 0.00 PSI or above, I can hear what sounds like the BPV closing, followed by the turbo begin to spool. I assume this is not what I should be hearing (in terms of performance, the car didn't really feel any better or worse than it did when using the yellow spring). I think the green spring may be just a little too light for my application (switching back to the yellow eliminates this specific noise). I will say the green spring definitely seemed to eliminate the fluttering sound at partial throttle. I am going to try the green spring + 1 shim tomorrow.
EDIT: I forgot to ask, when adding the shims I believe you are supposed to place them at the bottom of the spring correct (i.e. between the spring and the piston)? A few weeks ago I could have sworn I found a thread that answered this question but I can't seem to find it.
Old 01-30-2013, 01:34 PM   #114
Itoen
Member#: 133624
2013 WRX Hatch
Thanks for the share xluben I found this during my research, it seems like they now offer the FMWRX3 in adonized black which is what I was hoping for.
EDIT : Ordering mine from OAKOS
Itoen is offline   Reply With Quote
Old 01-30-2013, 01:52 PM   #115
xluben
Member#: 261612
2011 WRX 5 Door
NF Performance Stage 1
Yep, that's what I have on my car now!
Old 01-30-2013, 02:52 PM   #116
Itoen
Member#: 133624
2013 WRX Hatch
Ah not the plasti dipped shiny one then huh, According to your last posts you said your still running the green spring correct? How do you like it so far?
Old 01-30-2013, 02:54 PM   #117
xluben
Member#: 261612
2011 WRX 5 Door
I swapped around many different BPV's and now have a TurboSmart Dual Port 50/50 and the Forge Recirculating BPV. I have been running the green spring in all of the Forge vales. No issues at all. I peak around 27-28psi. I haven't really tested around 0psi like CO11WRX did, but overall I don't see any issues at all. And no flutter on throttle lift.
Old 01-30-2013, 03:02 PM   #118
Itoen
Member#: 133624
2013 WRX Hatch
That was a big help, thanks for the info and for your other reviews!
Old 01-31-2013, 06:45 PM   #119
BigRob74
Member#: 305107
2012 wrx/TP Stage 2
satin white pearl
I don't know how many times I can say this but the spring does not depend on what boost level you run! You really just want the lightest one for the best response.
EDIT: but running the yellow with a little audible flutter is perfectly fine.
just to be sure, mine arrived today and from what i read, i should run the yellow spring, assuming it doesnt come with the green one. is this correct?
stage 2 car, 19psi
Old 01-31-2013, 07:34 PM   #120
424wrx
Member#: 171948
08 wrx prem sedan
vf52 swap. bilstein susp
stage 2 car, 19psi
yeah the yellow. the green is special order. i use the yellow with 22psi stage vf52 swap setup. no issues and no flutter.
Old 01-31-2013, 10:06 PM   #121
xluben
Member#: 261612
2011 WRX 5 Door
Yep, yellow is good. No need to go heavier.
Old 02-06-2013, 06:00 PM   #122
CO11WRX
Member#: 304018
2011 WRX Sedan
I picked up some Mobil 1 Synthetic grease today so I can re-lube my Forge. I found some cleaning instructions on Forge's website, but it was for another valve entirely. For those of you that have cleaned/re-lubed your Forge BPV, did you put grease over all of the o-rings or just the piston?
Old 02-06-2013, 08:28 PM   #123
xluben
Member#: 261612
2011 WRX 5 Door
Just clean it well and put some lube on the o-rings and maybe a little on the outside of the piston. You don't need to lube the top or bottom of the piston.
Old 02-06-2013, 10:17 PM   #124
BigRob74
Member#: 305107
2012 wrx/TP Stage 2
satin white pearl
are these silver spacers supposed to be used for anything? when i got mine, i just pulled out the spring inside, and put the yellow one in, what are these things for?
Old 02-06-2013, 10:22 PM   #125
xluben
Member#: 261612
2011 WRX 5 Door
They're just so that you can adjust for tension slightly between the springs. No need to use them.
FS : forge bpv for sale!!!08+sti-02-07 wrx and sti!! bad mutha South East Region Private Classifieds 2 01-25-2011 08:58 PM
FS : JNA front lip for 08+ wrx's, brand new jonnylin1 NWIC Private Classifieds 9 10-11-2010 02:12 AM
Forge BPV for sale DohcVtec NESIC Private Classifieds 7 04-21-2008 02:10 PM
WTT: Forge BPV for a BOV o2sys Engine/Power/Exhaust 11 05-05-2007 10:59 AM
Forge BPV for sale Adrenalin Rush Private 'For Sale' Classifieds 2 06-22-2006 12:56 PM
Message Board Statistics All times are GMT -4. The time now is 07:48 AM.
