Old 02-01-2013, 12:39 AM   #151
flk
Member#: 280838
2016 S4/GT4
^Don't forget with slightly bigger tires you will get a height gain too. For example i'm going from factory 235/45/17 to 245/40R18 and I will be gaining 5 mm in ride height from that alone. Arch wheel gap will also effectively decrease by 5 mm so that affords the look of being lower while actually raising ground clearance.
flk is offline   Reply With Quote
Old 02-01-2013, 05:57 PM   #152
mrkyle3
Member#: 272675
2004 Miata
I wouldn't do that with the 5 speed. Slightly smaller wheel will be better with the gearing.
mrkyle3 is offline   Reply With Quote
Old 02-01-2013, 11:21 PM   #153
flk
Member#: 280838
2016 S4/GT4
^I know I won't have the gearing advantage, but it's my winter A/S setup, not my summers.
Old 02-02-2013, 09:24 PM   #154
mrkyle3
Member#: 272675
2004 Miata
Why would you get 18s for winter?
Old 02-02-2013, 10:00 PM   #155
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
That's a good question. Even with slightly tall tires, you would have way more sidewall with a 17, or even a 16 if one clears your brakes.
Counterfit is online now   Reply With Quote
Old 02-02-2013, 10:32 PM   #156
garudatwo
Member#: 322385
16's will, I'm actually looking for a set of 15" Braids for winter.
garudatwo is offline   Reply With Quote
Old 02-03-2013, 07:31 PM   #157
GregOrz
Member#: 339148
Before: OEM shocks and springs...
After: Bilstein shocks and yellow springs, Rear set to top circlip, car has fully settled, before alignment...
GregOrz is offline   Reply With Quote
Old 02-03-2013, 09:08 PM   #158
boost-o-matic
Member#: 248364
2010 Huevos grandes
WRX Dom 1.5XTR E85 silver
People, I know some of you may not want a stiff ride, but I am willing to guarantee that the yellows with the Bils are NOT going to give you a rough ride. It is still relatively plush to me. And yeah, the drop is minimal, I'd believe 15-20mm. But I didn't measure before I swapped them. I am running the rear 5mm up to compensate for my 2 kids in the car. I wouldn't want to go any lower. I like susp travel and not having to slow down for everything.
IMO, this is a great "set it and forget it" setup for someone who wants a no-hassle susp upgrade.
And btw, I have never had any passenger in the last 15 months comment that my car rode stiff or rough, etc with the RCE yellow/Bils.
boost-o-matic is offline   Reply With Quote
Old 02-04-2013, 07:57 PM   #159
flk
Member#: 280838
2016 S4/GT4
My Blacks with the revalved Bilsteins have settled. Too bad for lake effect snow though. Will take better pictures when I see the sun again!
Rears are at +5mm. This retains the factory rake, but honestly I think +10mm would be better. I will change it when the weather warms up.
Ride is good, a bit stiffer than my GSR Evo X but not harsh.
My alignment is:
-1.8 camber FL/FR
0 toe FL/FR
-1.3 camber RL/RR
0.05 toe in RL/RR
I actually wanted less camber in the rear for rotation but due to compression even with rolled rear fenders it was safer with current settings.
Old 02-04-2013, 08:04 PM   #160
garudatwo
Member#: 322385
Good job doing it the right way and getting those bils revalved!
Old 02-04-2013, 08:45 PM   #161
flk
Member#: 280838
2016 S4/GT4
Thanks! There doesnt seem to be any evidence of the revalve as far as serial #'s go. Unless Myles wants to chime in and let me know how I can tell. Can everyone who has either Yellows/Blacks post their hub to fender distance?
Old 02-04-2013, 08:56 PM   #162
garudatwo
Member#: 322385
Check out earlier in the thread, everything should be posted somewhere.
Old 03-29-2013, 03:44 PM   #163
NYInk
Member#: 329681
I'm leaning towards the GTWorx kit with the black springs for my '12 sedan. Does anyone have any more pics they can post up. It's kind of hard to see the drop on most of these pics. Also, do you guys recommend having the bils re-valved for the black springs? Does that cost anything extra?
NYInk is offline   Reply With Quote
Old 03-29-2013, 04:40 PM   #164
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
Overland just posted some pictures in his thread, mkvaron has some too. I was told by RCE that you wouldn't need to have anything re-valves to use the blacks. I can't comment first hand since I haven't installed mine yet.
jester8798 is offline   Reply With Quote
Old 03-29-2013, 04:41 PM   #165
jester8798
Member#: 277915
2011 WRX Premium
SWP, TP Stage 2
Overland just posted some pictures in his thread, mkvaron has some too. I was told by RCE that you wouldn't need to have anything re-valved to use the blacks. I can't comment first hand since I haven't installed mine yet.
Old 03-30-2013, 08:28 PM   #166
flk
Member#: 280838
2016 S4/GT4
Heres 2 pics showing the drop with a slightly larger ratio tire (245/40R18):
Camber is F-1.8 R -1.5
Old 04-04-2013, 01:44 PM   #167
mkvaron
Member#: 326317
2011 WRX hatch
SSM
I never saw this thread previously, but after going through it there was alot of misinformation (assumptions) I saw so I thought I would post the link to my review comparing the yellows and blacks.
http://forums.nasioc.com/forums/show...t=rce+bilstein
Not sure where anyone got an idea that the blacks are bad on the track, but I assure you they aren't with adjustable sway bars. Certainly the yellows are better & if you want a dedicated track car its the right setup (for not fully adjustable), but if you want your car to not be uncomfortable through snow and rough roads which I deal with for work I would highly reccomend the blacks having used both in all situations. Just my .02...
Also I didn't revalve mine when switching springs after consulting with my local alignment shop and RCE. Absolutely no issues, 15K miles and 3 track days on them...
mkvaron is offline   Reply With Quote
