Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2015
Old 09-10-2012, 07:45 PM   #1
DraXxus1549
Member#: 329943
2013 WRX
WR Blue
Default Front License Plate Mount
Hey guys I did some searching but couldnt find much for my situation.
I just became the proud owner of a 2013 WRX and I just got plates for it today, I am looking for a mount for the front plate. It looks like there are two squares in the bumper for something that a mount could go in. Are there any mounts available for this?
I would like to avoid drilling into the bumper if I can.
Thanks in advance.
DraXxus1549 is offline   Reply With Quote
Old 09-10-2012, 08:27 PM   #2
backseatwindowsup
Member#: 321212
there are cheap little plastic snap brackets that fit inside those squares. i tried them but the plate flew right off after i pulled with a little force. you might have better luck? I ended up getting holes drilled. You can also look into license plate relocation brackets and have it sit on the lower bumper off to one of the sides.
backseatwindowsup is offline   Reply With Quote
Old 09-10-2012, 08:30 PM   #3
DraXxus1549
Member#: 329943
2013 WRX
WR Blue
I tried the little squares as well they also fell right out.
Old 09-10-2012, 09:39 PM   #4
JSchell1309
Member#: 321321
'11 STI Hatchback
Dom 1.5XTR, E85
If you don't have holes predrilled and don't want to drill into a fresh bumper, I would recommend the Grimmspeed plate relocation kit. I bought mine from rallysportdirect here and couldn't be happier.
Old 09-10-2012, 09:54 PM   #5
SWP2011WRXinMN
Member#: 296039
2011 WRX Hatch Base
I got brackets from weathertech. They arent cheap but have held up well for a year now very well.
SWP2011WRXinMN is offline   Reply With Quote
Old 09-10-2012, 10:01 PM   #6
pleiad7
Member#: 71056
MY04 Forester XT
Pretty simple no-drill plate mount adapter: http://www.subaruforester.org/vbulle...46-post17.html
pleiad7 is offline   Reply With Quote
Old 09-10-2012, 10:07 PM   #7
BucketRX
Member#: 266606
2013 WRX LTD 5-Door
Grim speed plate mount, uses the tow hook spot, looks great leaves your bumper perfect.
http://www.grimmspeed.com/catalog/pr...roducts_id=218
BucketRX is offline   Reply With Quote
Old 09-10-2012, 10:45 PM   #8
SawksFan562
Member#: 292352
2011 Impreza WRX
Google Totsubo license plate bracket. $35 for 2 pieces of metal but aesthetically the best bracket out there. I've had them for over a year with no issues.
SawksFan562 is offline   Reply With Quote
Old 09-10-2012, 11:36 PM   #9
luvless2620
Member#: 190566
+1 for the grimmspeed mount. Been rocking it for a little over a year now.
luvless2620 is offline   Reply With Quote
Old 09-10-2012, 11:38 PM   #10
builthatch
Member#: 185105
2009 C63 AMG
Palladium Silver
x2
that subaru dealer in cali that sponsors a lot of the subaru forums has them...south coast maybe? that's where i got mine.
builthatch is offline   Reply With Quote
Old 09-10-2012, 11:39 PM   #11
corvid
Member#: 300097
Totsubo for sure, unless you like they ricey look. Mine have also been on for about a year, work as expected. Only got a little loose when someone backed into the license plate, but a simple fix.
corvid is online now   Reply With Quote
Old 09-11-2012, 12:37 PM   #12
DraXxus1549
Member#: 329943
2013 WRX
WR Blue
Not really a fan of the offset license plate, ruins the symmetry haha. The Totsubo mounts look good. Do they press into the pre-existing holes in the bumper? It says no drilling but I want to double check before I drop the $35 on it.
Old 09-11-2012, 01:09 PM   #13
WRXLTD
Member#: 136314
2014 Grand Cherokee
+100
I love my GrimmSpeed plate delete & relocation mount.
WRXLTD is offline   Reply With Quote
Old 09-11-2012, 01:12 PM   #14
builthatch
Member#: 185105
2009 C63 AMG
Palladium Silver
no drilling is correct. they have well nuts. as you tighten the little Al blocks to the bumper, the well nut expands in the square holes you have in the bumper and hooks into the spaces at the rear of the hole.
Old 09-11-2012, 02:32 PM   #15
d0ugch0i
Member#: 198861
2004 WRX
check out grimmspeed they have some nice ones. or you could go with a plate delete and get the euro plate for the front. imo i think it looks really nice.
d0ugch0i is offline   Reply With Quote
Old 02-01-2013, 10:35 AM   #16
AFP520
Member#: 102932
2014 STI Sedan
FYI, anyone can pretty much make their own mount just using the well nuts. It will require that you drill holes in the license plate, but who gives a shiz
AFP520 is offline   Reply With Quote
Old 03-27-2013, 01:11 PM   #17
Ezrem
Member#: 289077
2011 WRX 5-Door
Lightning Red
Anyone know what the correct well nut size for the Totsubo mount is?
I have one on my car (love it) and suspect I will need new well nuts due to a pending bumper replacement.
Ezrem is offline   Reply With Quote
Old 03-27-2013, 01:30 PM   #18
steverx05
Member#: 128269
'13 VW Golf R
I would only do the offset plate if I was running a FMIC for functionality. Otherwise, it just looks weird since the bumper already has that center mounting spot molded into it.
steverx05 is offline   Reply With Quote
Old 03-27-2013, 07:10 PM   #19
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
ive always thought that too. never liked offset front plates.
Old 03-27-2013, 09:59 PM   #20
builthatch
Member#: 185105
2009 C63 AMG
Palladium Silver
good question.
if you go to 1:09ish of the video below you see some numbers on the nut portion. i searched and it appears H1032 is the one you want, but i can't be sure.
http://fasteners.oemfast.com/item/po...-inserts/h1032
