Old 01-31-2013, 11:57 PM   #1
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
Default How much knock is too much?
Hola guys (Bill),
I read the other thread titled similar to this and didn't really take much away from it.
The question is simple, how much knock at WOT is too much? Is any acceptable?
My experience is, when I first reflash to a map, I don't see any knock the first few runs. Then, a month later, I do a log and see some knock at roughly peak torque and occassionally some around 5500 rpm. Why would this be time dependent? Is it ok to see -1.4 degrees pulled every now and then at peak torque (3500) or higher (5500) at WOT?
Thanks!
Nimbus09 is offline   Reply With Quote
Old 02-01-2013, 08:36 AM   #2
Cobb Tuning
Member#: 4803
Originally Posted by Nimbus09 View Post
Hola guys (Bill),
Thanks!
When the knock is occurring is the key factor here. If you see feedback knock correction when mashing the throttle or abruptly lifting off the throttle, then this is normal noise. If you see consistent feedback knock correction during your WOT run that is not due to the above, then that is something you would want to address. One typical solution would be to move to a less aggressive map (ex. move from 93 to 91 octane map while still running 93 octane fuel). You would also want to make sure you are using gas from a decent gas brand. There can be other reasons for consistent WOT knock, including mechanical problems.
Fine knock learning is a lot more tricky to analyze. This is because it is learned based on an event and then re-applied again and again to a sometimes broad load and RPM range after that event. It will be re-applied and then gradually ramp back down to zero. So, you really don't know under what conditions the fine knock learning was learned. Sometimes, with WOT fine knock learning, it can get learned when abruptly lifting off the throttle at the end of your WOT run. Then it gets re-applied and you see it during the WOT run which can be confusing. Generally, though, that is a single count (-1.4) correction. If your ECU supports the knock sums parameter(s), you can log it/these to give you a better idea of when fine knock learning is actually learned. The knock sum value(s) will increment when there's perceived knock. Do not be concerned with the values themselves - you will see sometimes larger numbers. This does not mean you are knocking quite a bit as these numbers are meaningless (they increment even at idle when the knock detection system sucks as determining any actual knock). Cylinder 4 knock sum (if your ECU supports per cylinder knock sum) will also generally be higher than the others - this is normal. You just want to look at when the knock sum increments at WOT - this is indication of knock. You will see it when feedback knock correction drops (from previous value) and when fine knock learning is learned. If knock sum does not increment when you see fine knock learning, it means that it was learned previously and you are only seeing what is being re-applied.
The final thing to check is the dynamic advance multiplier (DAM). For the 2.5L Subarus, this will learn up to 1.0 and should stay there. It should not drop from 1.0 as this would indicate knock. However, keep in mind, depending on the map, the DAM may start out at an initial lower value after the Accessport install, map reflash, ECU reset or disconnecting the car's battery. This is normal behavior in that case and does not indicate knock.
Bill
Old 02-01-2013, 09:41 AM   #3
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
Interesting, thanks for the response.
Guess, follow up question is: does that mean the best condition to determine if a map is good is to log immediately after reflash so the car doesn't have time to register false fklc (given your DAM is at 1)?
It just bugs the heck out of me when I first put a map on and it looks great, only to see the car show knock a month down the road with the very same map.
Also, why doesn't Cobb recommend just logging knock sum if that's the best parameter to show true knock?
Old 02-01-2013, 10:20 AM   #4
Cobb Tuning
Member#: 4803
The reason that fine knock learning doesn't show up immediately after a reflash or ECU reset is because the ECU will enter a mode that looks at making changing to the DAM after that reset rather than fine knock learning. In that case, either the DAM would drop or feedback knock correction would drop if there was knock (dependent on conditions). Feedback knock correction is the default correction so it can be used (depending on conditions) regardless if the ECU is poised to make changes to the DAM or changes to fine knock learning (as conditions dictate - those changes would be disabled and feedback knock correction would respond to knock). After a period of time, the ECU determines that the DAM evaluation is done and moves to making changes with fine knock learning (with feedback knock correction still as the default).
Regardless, if you get a WOT log shortly after a reset and there's no feedback knock correction and the DAM doesn't drop, then there's was no perceived knock.
We don't add knock sum to the default set of parameters as only the later ECUs have it. We want a default set of monitors that is as consistent as possible across all the Subarus we support. But, you certainly add it to logging set if you have a particular need to do so. In this case, it would be to determine when fine knock learning is occurring.
Bill
Old 02-01-2013, 02:01 PM   #5
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
good info, thanks!
Old 02-03-2013, 11:09 PM   #6
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
Bill
i just re-read this. my question is really not why knock learning is not registering after a reset. i understand that it wouldnt
my question is, after i initially reflash, my logs are DAM=1 and FKLC=0 all around the rpm range. a month later, DAM=1 but FKLC is not 0 anymore and i actually see some feedback knock too. i don't understand what happens in that month that the very same map gives me crappy results later.
Old 02-04-2013, 08:37 AM   #7
Cobb Tuning
Member#: 4803
A reflash does the same thing as an ECU reset - that explains why fine knock learning is not being used right after a reset. The amount of time it spends in the DAM learning mode (before switching to fine knock learning mode) depends a lot on driving conditions. Certain conditions (steady load/moderate boost) will speed that process while others may prolong it. But, it shouldn't take very long on these cars.
Really, what you are seeing for knock correction depends on where you are seeing it. Some amount of low load correction or correction with throttle changes is normal noise and not something to be concerned about. If you getting consistent correction during your WOT run (other than due to mashing the throttle or lifting off it abruptly), then that would be a concern. As to why you may see more correction well after a reset/reflash (if the DAM starts at 1.0 initial), it may just be a coincidence (knock is not always consistent run to run) or it could be something fueling related if your long-term fuel trims are learning something that is not appropriate. For example, the A/F Learning 1 "D" range is also applied in open loop, so if you see if pulling fuel (with a notable correction), that will also impact your WOT fuel targets and there could be some relationship there with the knock. But, those fuel trims are cleared after reflash/reset so they would start at 0.
Bill
