Welcome to the North American Subaru Impreza Owners Club Wednesday February 10, 2016
Old 01-24-2013, 01:59 PM   #4926
BIGSKYWRX
Member#: 7958
09 GH B+
the last STi wagon made was in 2001 (jdm only) and was a v7, for an 07 to use these you'd have to swap in the older v7 top mounts (not as good), not to mention these springs are pretty rare
the 06 STi takeoffs will fit w/o any top swapping and the rates are firmer than both the v7 STi sedan and wagon. yes the free length on sedan springs is a little less than wagon springs, thus the reason folks will commonly add a spacer/shim
BIGSKYWRX is offline   Reply With Quote
Old 01-24-2013, 02:42 PM   #4927
ringe
Member#: 49998
2007 WRX CT Stg 2
Ah, I see... hence the availability of Wagon Pinks, not simply STI wagon springs... Thanks, man.
From what I understand, the GR2 wouldn't be an ideal shock for these springs, but probably better than stock, no? Just while I prep for inserts.
ringe is offline   Reply With Quote
Old 01-24-2013, 02:56 PM   #4928
BIGSKYWRX
Member#: 7958
09 GH B+
^ I think the GR2's would fine w/ those springs, the Koni's are simply a better damper
Old 01-24-2013, 03:01 PM   #4929
Daddy_Digital
Member#: 274205
2002 WRX Sport Wagon
World Rally Blue
I am going with KYB AGXs and Swift wagon springs.
Daddy_Digital is offline   Reply With Quote
Old 01-24-2013, 03:16 PM   #4930
ringe
Member#: 49998
2007 WRX CT Stg 2
Excellent. Thank you for your expertise!
Old 01-26-2013, 11:01 PM   #4931
cbaldwin
Member#: 310287
08 sti wagon
white
ive seen a couple threads about converting wagon suspension to sti knuckles hub and bearings ? is this worth itnin long run with possibly wrx bearing going out. and wider stance ? thoughts thnks
cbaldwin is offline   Reply With Quote
Old 01-26-2013, 11:32 PM   #4932
Daddy_Digital
Member#: 274205
World Rally Blue
Never mind. Going with the Koni Yellows and Swift springs.
Old 01-27-2013, 10:16 AM   #4933
ringe
Member#: 49998
2007 WRX CT Stg 2
I was thinking of the Swifts too, but decided I wanted near-stock ride height, so I'll just be doing sti takeoffs, and eventually koni inserts.
Old 01-27-2013, 02:26 PM   #4934
Daddy_Digital
Member#: 274205
World Rally Blue
This weekend I met someone with an identical wrx wagon like mine. He had the swift springs on his wrx and it didnt look very low. just right. If you want stock height, stay with the stock springs and just upgrade your struts. I have tried looking for stock replacement springs and there is nothing but lowering springs everywhere. Have you looked at/heard of King springs? Those dont lower your car.
Old 01-27-2013, 07:17 PM   #4935
BIGSKYWRX
Member#: 7958
09 GH B+
I would say only if you are frying bearings at the track
if you want increased front track, go w/ sedan front arms (a wider front track to rear dials out a little understeer)
Old 01-27-2013, 11:47 PM   #4936
ringe
Member#: 49998
2007 WRX CT Stg 2
Haven't looked at King.
The STI springs are affordable and effective, so I'll give that a shot first, as this is my first time dipping my toes into the waters of chassis mods (other than sway bars).
-Better F/R ratio (1.15/1 vs 1.22/1 stock).
-Proven performance.
-Not excessively stiff for DD duties.
Old 01-28-2013, 12:45 AM   #4937
04wrx008
Member#: 261447
2004 Impreza WRX
Figured I'd share my hard work too.
04 WRB WRX
Whiteline sways and endlinks front and rear. sways: 22f/24r
Koni sport inserts in stock housings w/ rce black springs.
Group-n top hats front and rear
Saggy butt spacers
Whiteline strut bars front and rear
Kart boy diff locks, shifter bushings.
Tic rear diff, outrigger, tranny x member bushings.
So far happy with the outcome especially because it's my daily.
Only thing that bothers me is my rear passenger strut has started to make a small popping noise when it travels a bit. (going in and out of driveway, over speed bumps)
On a side note, how has everyone liked/disliked adding the anti lift kit and roll center adj?
04wrx008 is offline   Reply With Quote
Old 01-28-2013, 06:31 AM   #4938
Gunner
Member#: 36540
04 GGA
Cobb Stage 1 EQ Tuned
Does anyone know anything about the KYB Ultra-SR? According to their catalogue it seems that there is a fitment for USDM 2004 and 2005 WRX wagon (part # 324034/5/6/7). It appears to be stiffer than the Excel-G and if the fitment is right, it might be a good pair with the SPT pink springs! rockauto ships them for $650 a set.
http://www.kyb-europe.com/shocks-ultra-sr.html
Gunner is offline   Reply With Quote
Old 01-28-2013, 07:02 AM   #4939
Daddy_Digital
Member#: 274205
World Rally Blue
I would imagine the STI springs would have a solid ride but not too harsh for daily driving. I have been reaching suspensions for a week and I am more confused now then when i started.
Old 01-28-2013, 12:38 PM   #4940
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
Well its not that complicated. Look for info from Bigsky
then look at your goals:
Looks ( do what ya like to get low )
Looks + performance+DD (I like Koni but d-spec & 04 STi take offs are good)
Auto X ( just for fun or nationally competitive)
Rally X (don't use koni inserts)
Track car.
Then you look at you budget. (are you cheep/pore find Sti take offs)
Then you look at what is available and works well.
Then realize you have a wagon and most of what available will be sedan specific. This is not a problem just wrinkle:
  1. So you will loose some negative camber up front and you want to have the ability to add some camber adjustment back in.
  2. So you will also loose some rear ride hight and will likely want to add a set of saggy but spacers in the rear.
so the answer goes like this:
If you are going to a low spring it should be stiffer/high rate.
If you are putting on stiffer springs then you should use stiffer top hats ( Group N (F/R)/ Whiteline Com C front)
Struts options last I checked we have 4 choses.
Koni inserts preferably in wagon housings (get D rex extenders I wish I had) works well with most options
D spec good and robust works well with most options
KYB adjustable cheep but not very adjustable 4 point only
KYB GR2 not adjustable very close to stock but 10%-20% stiffer
Ok with pinks and other less stiffly sprung springs
Springs
STi
Sti take off's (cheep get them used and easy to find)
Sti wagon springs (less cheep but good for wagons no saggy but shimneeded)
RCE
Blacks better then Sti take offs but same ride hight
Yellows as low as you can go and still have high performance
Swift
WRX
STi
There are a few others manufactures that people like.
Sway bars
Sway bars a little stiffer is good for body roll more use full for soft springs.
No need to go crazy unless you are Auto X Rally X or track day, in this case go see what works for those guys in those threads as they have very specific set ups that people like. Don't think that this is the same as DD the same stuff might work but it might not.
check out the appropriate threaded in the Motorsport section
Other stuff
lots of ways to get you car stiffer for higher performance. Do you need it well what are your goals what are class requirements.
Anti lift kit and roll center correction. In every thing i read they are an improvement to how the car handles.
always start here Suspension Supersticky: Springs, Coilovers, Swaybars, S-Techs, fitment, tech, more!
look for stuff written by Bigsky, the unabomber, ether of the guys at TIC and Buttdyno or a few other that are very knowledgeable.
See its not that complicated. notice I did not even say coil overs you probably don't need them.
Ry
labcoat is offline   Reply With Quote
Old 01-28-2013, 01:23 PM   #4941
Gunner
Member#: 36540
04 GGA
And the Ultra-SR appears to be inverted according to a guy on scoobynet...
http://bbs.scoobynet.com/suspension-...pe-struts.html
Old 01-28-2013, 04:36 PM   #4942
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Trying to search from the mobile is proving harder than I remembered.
04 wrx wagon
Hotchkiss sway bars
Soon to be adding sedan front control arms.
The question: Can I use whiteline spherical endlinks and retain the wagon bar with sedan arms?
I could've sworn I read it somewhere but I'd like to confirm.
Old 01-30-2013, 12:04 AM   #4943
jhayesvw
Member#: 326502
2003 WRX Wagon
RCE camber plates would lower the front- in addition to more neg camber (and positive caster if you can't them)
just what I wanted to hear.
I checked Racecomp's site and I dont see them though.
Perhaps they are discontinued?
jhayesvw is offline   Reply With Quote
Old 01-31-2013, 07:28 PM   #4944
Gunner
Member#: 36540
04 GGA
Are you referring to the STI/SPT pink springs? If so, aren't they direct bolt on if the matching 04+ top hats are used? Why is shim needed? Thanks.
Old 01-31-2013, 11:07 PM   #4945
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
The is only need a saggy but shim is if you use sedan springs on a wagon. They give you back 1/4 or 3/8 of an inch back that the extra hevy rear end of the wagon takes.
Almost springsmworth having are 04+ so plan on getting new tophats and make them Group N
Old 02-01-2013, 07:44 AM   #4946
mhoerath
Member#: 131379
2003 354 ftlb@3k rpm
justablue hatch
04 wrx wagon
Hotchkiss sway bars
suggest GC aluminum front LCA's. And I used the stock endlinks that came with. if you do make sure the conical ball joint ends come with the lca.
mhoerath is offline   Reply With Quote
Old 02-01-2013, 03:51 PM   #4947
Psychoreo
Member#: 79643
2015 WRX STI
I'm getting the stock sedan ones for beyond a deal and they're going to be coated before install so rust isn't an issue.
Are the mounting tabs close enough to work?
Old 02-09-2013, 05:39 AM   #4948
Daddy_Digital
Member#: 274205
World Rally Blue
Do I HAVE to get 04-07 group n rear top hats so the sti pink usdm wagon springs to fit? Could i just use a normal OEM 04-07 rear top hat? I have an 02 WRX wagon. Id really like to not have to use different top hats. But I have to, i will.
Old 02-09-2013, 08:44 AM   #4949
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
You don't need group N you do need 04 +
Old 02-09-2013, 10:36 AM   #4950
BIGSKYWRX
Member#: 7958
09 GH B+
with an 02 I would want to freshen up the front mounts as well- they are a wear item and this would be the optimum time to replace them
The HID FAQ Thread - Read before posting your questions dithergizzard Electrical & Lighting 661 01-30-2016 12:37 PM
What does your rim/tire combo weigh? Post your setup + weight Trevor723 Tire & Wheel 42 06-04-2010 11:40 PM
Post your setup... az ej20 fan South West Impreza Club Forum -- SWIC 20 02-11-2004 12:59 AM
Are these gauge readings correct? post yours too please! T33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-28-2003 02:35 PM
