Old 11-12-2012, 11:17 PM   #1
JoeyS07sti
Member#: 218475
2007 CGM STI
Default Differential or axle problem?
Hey it's been a while since I been on this site. My 07 STI has a problem up front, basically at low speeds it feels quite wobbley and it pulls hard to the right at full throttle. If I put my DCCD all the way to the rear it goes away. Does anyone know what this could be? A little information on the car is that I recently installed a Heavy duty clutch in the car if that helps any. The car only has 40k on it so I do not know what it could bbe
Pm me or email me at j.saa.engratgmail.com
I also wanted to add, that I took it to get it "pre-diagnosed" and my dad and another tech think from the noise that it could be a bearing that connects the drive shaft into the transmission moving around too much.
JoeyS07sti is offline   Reply With Quote
Old 11-15-2012, 06:24 AM   #2
icmfamous2
Member#: 337941
maybe u have an alignment issue??
icmfamous2 is offline   Reply With Quote
Old 11-15-2012, 09:39 AM   #3
JoeyS07sti
Member#: 218475
2007 CGM STI
Thanks for the input. Do you think it could bethe camber bolts? A whole back the place I got my alignment done at said I need bigger can bolts cuz they couldn't align it anymore with the stock ones.
Old 11-25-2012, 01:31 PM   #4
JoeyS07sti
Member#: 218475
2007 CGM STI
Bumpage
Old 11-25-2012, 03:00 PM   #5
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Sounds like a front diff. problem.
Bikelok is offline   Reply With Quote
Old 11-26-2012, 11:08 AM   #6
JoeyS07sti
Member#: 218475
2007 CGM STI
Thanks I appreciate the advice ill take a look at it this weekend.
Old 11-26-2012, 08:54 PM   #7
SLeRoux92
Member#: 295552
2005 STi
I have the same problem, but changing the diff settings does nothing for me
SLeRoux92 is offline   Reply With Quote
Old 11-28-2012, 11:29 PM   #8
Maddies Daddie
Member#: 298565
2008 STi
You probably already did this but check your tire psi.
Maddies Daddie is offline   Reply With Quote
Old 11-29-2012, 09:41 AM   #9
JoeyS07sti
Member#: 218475
2007 CGM STI
Lemme know if you find out the problem.
Old 11-29-2012, 12:22 PM   #10
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Are all the tires the same size, with the same wear and good pressure?
Old 01-31-2013, 05:50 PM   #11
dfoy01
Member#: 315002
16 WRX
CPW
Originally Posted by JoeyS07sti View Post
Hey it's been a while since I been on this site. My 07 STI has a problem up front, basically at low speeds it feels quite wobbley and it pulls hard to the right at full throttle. If I put my DCCD all the way to the rear it goes away. Does anyone know what this could be? Pm me or email me at j.saa.engratgmail.com
I'm also experiencing the same problem. My is to the point to where I'm drivning in DCCD Auto I feel the same sensation but when I put it in manual and all the way back in the green the sensation goes away.
Any comments?
dfoy01 is offline   Reply With Quote
Old 02-01-2013, 08:50 AM   #12
JoeyS07sti
Member#: 218475
2007 CGM STI
Any comments?
That is exactly what happens to my car, I took it to my buddys shop and had him a tech and my father look at it while I was inside spinning the wheels, and they think that there is something wrong with one of the center bearings. there is too much play on mine evidentally, so that is where we are going to start. Please keep me informed if you look into it any further. My email is [email protected]
I had recently changed my clutch before this started happening. Did you do the same?
Old 02-01-2013, 02:57 PM   #13
jamal
Member#: 71875
98 Legacy GT
my wheels fit
I would think alignment problem before anything else.
jamal is offline   Reply With Quote
Old 02-01-2013, 03:06 PM   #14
JoeyS07sti
Member#: 218475
2007 CGM STI
Why do you think so, just because it pulls to the right when I give it the gas and DCCD is in "Auto" mode? I do not think it is an alignment issue due to the fact that it is making a clanking sound and very wobbly at low gears and when the DCCD is in "Auto" mode.
Old 03-26-2013, 10:05 PM   #15
JoeyS07sti
Member#: 218475
2007 CGM STI
Bump!!!
Old 04-01-2013, 10:36 AM   #16
runner19
Member#: 39562
My02 WRX Sedan 5MT
WR blue
To echo what the others said.
It can be
alignment
tire issues
gearbox/diff
But the gearbox/diff is the most expensive to fix and also not a common issue.
So start with the cheaper options
1. post your alignment final figures
2. move tires from front to back. Tire wear can also cause issues
runner19 is offline   Reply With Quote
Old 04-01-2013, 10:47 AM   #17
JoeyS07sti
Member#: 218475
2007 CGM STI
It can be
alignment
tire issues
gearbox/diff
Thanks, so I should put some aftermarket camber bolts, then get an alignment and post my numbers?
Old 05-30-2013, 02:42 PM   #18
JoeyS07sti
Member#: 218475
2007 CGM STI
Cool
For anyone who cared, or has the same problem, it was the passenger side front differential roller bearing. Some how it warped, and it looks like it is due to someone bottoming out pretty bad. Car is fixed now, and drives perfectly again. Hope this helps!
