Old 01-03-2013, 11:14 AM   #76
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Originally Posted by classicaddict View Post
Correct me if I'm wrong but the lgt uses 16 inch wheels no?
The '05-09 2.5GTs had 17" wheels (or 18" in the SpecB guise).
Patrick Olsen is online now   Reply With Quote
Old 01-14-2013, 06:16 PM   #77
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
Prototype should be here tmrw.
Old 01-14-2013, 08:22 PM   #78
04jaxwrex
Member#: 82762
2005 Saab 9-2x Aero
Desert Silver
04jaxwrex is offline   Reply With Quote
Old 01-14-2013, 08:36 PM   #79
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
So correct me if I'm wrong, but these would fit on the BRZ yeah? The calipers aren't differentially bored so no swapped the bleeders, just gotta flip caliper from side to side. Mounting holes on Legacy, Impreza, and BRZ appear to all be the same....
OrbitalEllipses is online now   Reply With Quote
Old 01-15-2013, 03:03 PM   #80
04jaxwrex
Member#: 82762
2005 Saab 9-2x Aero
Desert Silver
Bracket!
Bracket!
Bracket!
Old 01-15-2013, 06:09 PM   #81
KNS Brakes
Member#: 125739
2015 WRB WRX
Bracket bolts on an older knuckle just fine (press in bearing)
I raised the points a bit too much so the pad sits high - that's an easy fix.
But...
I was looking at a newer knuckle w/ bolt in bearing assemblies. At least on an STi knuckle it will not fit (at all)
Who has a pic of a bolt in new age knuckle? That will require a different bracket I bet.
Old 01-15-2013, 06:44 PM   #82
04jaxwrex
Member#: 82762
2005 Saab 9-2x Aero
Desert Silver
02-05? or 02-07?
Old 01-15-2013, 09:45 PM   #83
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
But...
Well the STi does have a larger bearing than the WRX does. So maybe that's just the hang up.
Old 01-15-2013, 11:17 PM   #84
KNS Brakes
Member#: 125739
2015 WRB WRX
The OG bracket was on my 06 WRX - so I think WRX to 207 is OK.
Pretty sure 2008 WRX has the new bolt in so we'll have to revisit that one.
The LGT....meh who cares
Foresters up to 2008 should be good to go as well.
So - let me get a revision done and we'll make them.
Can we please get a list going?
And can you please at least consider getting the other required parts from me?
-Ken
Old 01-15-2013, 11:18 PM   #85
KNS Brakes
Member#: 125739
2015 WRB WRX
Unfortunately I think you are screwed. I need to get a 2008+ knuckle.
-Ken
Old 01-15-2013, 11:18 PM   #86
KNS Brakes
Member#: 125739
2015 WRB WRX
We will attempt to make it so.
-Ken
Old 01-16-2013, 09:50 AM   #87
04jaxwrex
Member#: 82762
2005 Saab 9-2x Aero
Desert Silver
-Ken
Ken,
I actually have a quote from you for some LGT DBA Tslot front rotors and WRX DBA Tslot rear rotors. Wish you carried EBC redstuff pads! But ill be #1 on the list and get the rotors and bracket once its ready! will it come powdered?
Mike
Old 01-17-2013, 05:10 PM   #88
KNS Brakes
Member#: 125739
2015 WRB WRX
A couple more tweaks need to be done to the prototype!
I have to push the pad down a few mm to get it about 1 mm below the edge of the rotor.
This means we may need to ever so slightly kiss the edge of the rotor channel for clearance. Worth it to get that pad down where it needs to be.
Hardware is easy and readily available
Looking pretty good.
Sending the revised model tonight. He should be able to turn them out quick.
They won't be powdercoated - that is too thick.
Old 01-21-2013, 01:37 AM   #89
cueballsi
Member#: 202736
2002 WRX- 6spd - MBP
1992 Civic VX 40MPG
Would it be better to have the adapter made of steel for less flex? Are there thoughts of making an adapter to use the rear 2 pots as well?
cueballsi is offline   Reply With Quote
Old 01-21-2013, 12:27 PM   #90
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
i see what you mean about the hub maybe causing issues with the bolt in bearings. im assuming they have less radial clearance?
cant you just take some material out of the center? around the bearing area. the original bracket was like that.
im not suggesting take out as much, as to make it look like the original, but maybe a middleground for strength and compatibility.
Old 01-21-2013, 12:30 PM   #91
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
also, i know this thread is concerned with the front 300zxtt calipers and the braket development right now,
but what were the rear brakes like on these cars? did they have a comparable 2 pot rear? just curious lol.
Old 01-21-2013, 02:28 PM   #92
cueballsi
Member#: 202736
1992 Civic VX 40MPG
I saw in a post that a guy used wrx 06 back plates and bolted on Nissan 2 pots, but had the pad over hang the rotor a little. are there thoughts of making a special bracket to use the 2 pots in the rear??
Old 01-22-2013, 11:17 AM   #93
04jaxwrex
Member#: 82762
2005 Saab 9-2x Aero
Desert Silver
I cant wait for these things to be produced. I have the 300 brakes ready to go!
Old 01-22-2013, 03:38 PM   #94
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
If you check his pics and read the comments, he mentioned needing to clearance the calipers to get the pads at the right spot on the rotors (with pictures to support that)... so you probably don't have the calipers "ready to go."
Old 01-22-2013, 11:41 PM   #95
Purpose_Built
Member#: 222879
2003 WRX 60-1/td06h
Hybrid/6spd
Will there be a solution for the Sti hubs, because dont want to drop 1k on Brembos or 500 on LIC modded hubs. I havent swapped hubs yet and my wheels have a dual pattern so it doesnt matter.
Purpose_Built is offline   Reply With Quote
Old 01-24-2013, 02:21 PM   #96
KNS Brakes
Member#: 125739
2015 WRB WRX
I'm not sure what to do there.
That big blob on the hub is a pia.
Old 01-28-2013, 10:34 PM   #97
04jaxwrex
Member#: 82762
2005 Saab 9-2x Aero
Desert Silver
Old 01-29-2013, 07:08 PM   #98
Einobaka
Member#: 69126
1998 2.5 RS
Whoa I'm glad I ran into this.. I have LGT front brakes on my RS already and I've been looking for a 4-pot caliper upgrade, stumbled on 300zx calipers then went searching for a bracket. Would be in on the group buy!
Einobaka is offline   Reply With Quote
Old 01-29-2013, 07:37 PM   #99
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Me too lol. Not having the brackets has nothing to do with being able to have the calipers ready to go haha.
Old 02-01-2013, 10:11 PM   #100
Einobaka
Member#: 69126
1998 2.5 RS
Would you also consider brackets for the STI rotors?
WTT WRX front rotors/brackets for RS rotors/brackets + WTB WRX rear caliper brackets Jard MAIC Private Classifieds 9 11-24-2009 09:38 AM
WTB: 02+ WRX Front Caliper Brackets, H6 Rear Caliper Brackets JDMFLCL Private 'Wanted' Classifieds 4 10-30-2009 01:19 PM
WTB: Front WRX caliper bracket and rear Legacy caliper bracket 92XJET MAIC Private Classifieds 0 11-20-2007 10:37 PM
WTT: I want YOUR Rs rotors and caliper bracket for MY Wrx caliper bracket and rotors scobaru MWSOC Private Classifieds 6 12-10-2006 08:02 AM
WTB: WRX Caliper Brackets + H6 Caliper Brackets Krelkor Private 'Wanted' Classifieds 11 07-12-2004 03:28 PM
