Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Old 02-01-2013, 10:02 PM   #1
GF8STILimited
Member#: 345662
Default some problem encountered after head gasket replacement
i was replaced head gasket on 1998 sti engine, and then all is fine and the idling is good ,engine is steady when i start the car, it can run to 6000 RPM and 1,1bar boosted in the road testing , but i encountered the problem in the next day test drive, it was running not smoothly when the car accelerate to 140 km/h , and the engine check warning light is on in that moment, after that i drive back to garage and open the hood ,
i saw the engine and the idling is not steady,,,anybody have similar case?
the engine has beem stalled if i remove the air flow sensor when the engine is not steady.
GF8STILimited is offline   Reply With Quote
Old 02-01-2013, 11:02 PM   #2
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
What codes is it giving you?
i_c_the_light is offline   Reply With Quote
Old 02-01-2013, 11:53 PM   #3
GF8STILimited
Member#: 345662
Um...i cannot check the code becoz the check engine light just switched on in a short time,,
and i keep in 3500-4000 rpm in nature gear, the light on again in short time, and i can hear a little bit back fire in this period.
Old 02-02-2013, 02:00 AM   #4
cmk82600
Member#: 248305
97 OBS
my custom mixed silver
Take it to a shop and have them connect to it with their scanner they can read codes even if you can't.
cmk82600 is offline   Reply With Quote
Old 02-02-2013, 03:31 AM   #5
GF8STILimited
Member#: 345662
are there have a plug under steering wheel for checking the error code?
Old 02-02-2013, 03:34 AM   #6
lavid2002
Member#: 226864
Yeah there's an OBD2 port for a plug where the drivers knees are for the OBD2 scanner.
Any vacuum leaks?
All the sensors hooked up?
Throttle cables good?
IACV hooked up properly?
lavid2002 is offline   Reply With Quote
Old 02-02-2013, 04:13 AM   #7
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Any vacuum leaks?
It's not ODBII though so codes are read old skool styles.
Old 02-02-2013, 04:53 AM   #8
cmk82600
Member#: 248305
97 OBS
Every vehicle built from 1996 and on is OBDII.
Old 02-02-2013, 12:28 PM   #9
sc00by4life
Member#: 97135
Only for the US market.....
sc00by4life is online now   Reply With Quote
