Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 02-01-2013, 11:50 AM   #1
RickDC
Member#: 199171
Default Replace engine component 2004 WRX Wagon
Can someone identify this part? I need to replace it.
http://www.flickr.com/photos/rickdc/8436011774/
RickDC is offline   Reply With Quote
Old 02-01-2013, 11:55 AM   #2
cmiovino
Member#: 134005
2004 WRX Premium
Pics no worky. I'll see what I can do when you get them up as I have an '04 too.
Old 02-01-2013, 12:21 PM   #3
RickDC
Member#: 199171
Default Uploading
I tried uploading to flickr and then pasting the link but it's not working. Let me try again.
Old 02-01-2013, 01:22 PM   #4
Wicked Innovation
Member#: 265606
manifold crosspipe
Wicked Innovation is offline   Reply With Quote
Old 02-01-2013, 02:11 PM   #5
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
nothing to see, i'm stock
Post in the wtb section. Someone who upgraded to aftermarket headers must have a stock manifold up for sale. Saves you the trouble to drop your exhaust manifold and take that old crosspipe apart.
Old 02-01-2013, 10:03 PM   #6
RickDC
Member#: 199171
Thanks for the responses, this is helpful. Do you know which model years are compatible and if its the same between sedans and wagons (assuming STI versions are different)
Old 02-01-2013, 10:40 PM   #7
D-Rodman
Member#: 110078
2005 92x - 02 wrx
silver 92x-wrb bugeye wag
Looks like you just need the cross pipe heat shield, I may have it, I'll check tomorrow and message you.
Old 02-01-2013, 11:08 PM   #8
rdieder
Member#: 257818
2007 STi
Are you having an exhaust leak? Or just want to replace because of the rust?
If its just the rust, unbolt the shield and hit the rust with a wire brush attachment, then spray with hi-temp paint.
rdieder is offline   Reply With Quote
Old 02-02-2013, 08:35 AM   #9
RickDC
Member#: 199171
Unfortunately there's a small hole in it...
Old 02-02-2013, 10:33 AM   #10
DZXN
Member#: 306186
2002 Subaru WRX
Are you talking about the hole in the picture (middle of the center rust)? If it is just that hole then you don't need to worry, that is just a heat shield. If you have an exhaust leak, then it could just be gaskets.
DZXN is offline   Reply With Quote
Old 02-02-2013, 01:54 PM   #11
RickDC
Member#: 199171
Thanks for the heads up, sounds like I may only need to replace the shield and inspect the rest of the crosspipe to make sure there's nothing else wrong.
Old 02-02-2013, 07:20 PM   #12
cmiovino
Member#: 134005
2004 WRX Premium
Why would you replace it?
It's just a heat shield.
Old 02-02-2013, 08:21 PM   #13
RickDC
Member#: 199171
I guess if a hole in the heat shield is nbd then maybe I'll leave it alone
Old 02-02-2013, 11:05 PM   #14
miracle_whip4130
Member#: 343854
2005 WRX
As said above, there is no reason to replace a heat shield with a small hole in it.
A small hole in your heat shield can actually be a good thing. That way if oil leaks into the shield somehow, it will drain out the hole, instead of filling the entire heat shield with oil and then catching fire. There was a big recall on the 2013 Chevy Cruze for that problem, I believe. Although I've never heard of it happening on a Subaru......
miracle_whip4130 is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 03:17 AM.
