Old 01-16-2013, 04:56 PM   #201
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
Originally Posted by SlimJim8804 View Post
What's a vid 46 turbo stroked?
New Craftsman Lawnmowers come with a VID 46 Turbo That is Stroked to help with large hills... I guess he managed to get some extra HP out of his limited edition sti by installing that
ftw... vid 46 turbo...stroked..
white guys wrx is offline   Reply With Quote
Old 01-24-2013, 10:55 PM   #202
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
Says it all.
SlimJim8804 is offline   Reply With Quote
Old 01-24-2013, 11:54 PM   #203
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
Says it all.
Doesn't show up.
JSchell1309 is offline   Reply With Quote
Old 01-27-2013, 07:54 PM   #204
flargggWRX
Member#: 326396
2012 WRX
PBP
This isn't all THAT funny, but apparently this Subaru sucks.....
http://detroit.craigslist.org/wyn/ctd/3556960090.html
flargggWRX is offline   Reply With Quote
Old 01-27-2013, 08:28 PM   #205
flargggWRX
Member#: 326396
2012 WRX
PBP
Old 01-28-2013, 10:31 AM   #206
JSchell1309
Member#: 321321
Tuxedo Black
Originally Posted by flargggWRX View Post
I know my car runs like a champ when I have new tye rids too. I be pushin no like a mofo.
Old 02-01-2013, 11:40 PM   #207
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
http://springfield.craigslist.org/cto/3530402821.html
:-| my old car for sale.... they have completely ruined it.. every single thing they are describing about the car is incorrect...
His description below:
Hi I have a 2002 Wrx awd turbo five speed manual. This car has 120k on body 8-10k on built motor and trans. This car is very fast and clean has sti front seats. This car is lowered an inch and rides great does awesome in snow rain and ice. The car has fuel pump injectors cams heads agp head studs vf46 ported turbo turbo inlet TB Cobb ap built trans !! 3" down pipe 3 1/2" hks exhaust boost controller turbo timer intake hks bov big front mount with hard pipe and soo much more trade for rx8, is300, 93^ rx7, srt4, srt 4, gto, trans am, Camaro ss, cts, lifted truck, turbo, supercharged.
417-818-2952
What it really has...Details on the motor -
Engine installed at 111,xxx
EJ20 bored .020" over
Stock Rods
Stock Crank
Manley Pistons 92.5mm which result in 8.5:1 compression when using OEM dished valves
Crower SS Valves with Flat Faces were used which will bump the compression up to 8.7:1
Crower Valve Springs and Retainers
ACL Race Bearing on the rods and mains
all gaskets were purchased new from subaru
head bolts were purchased new from subaru
ported cylinder heads
gates racing timing belt kit
gates waterpump
gates alt belt.
Transmission:
Rally Spec transmission with treated gears installed at 50k
engine addons/Other:
exedy clutch
ported an polished tgv deletes with motors so no CEL
sti pink injectors
vf34 turbo inspected during engine build looks GREAT!!!
hallman MBC purple (boost controller)
aluminum racing radiator 4 gallon
turbo xs fmic kit head wrapped around turbo.
hks bov/bpv adaptor included
turbo xs turboback bell mouth full exhaust
new battery installed with new engine
polished alternator
polished intake manifold
fresh valve covers beautiful purple/blue with tons of metal flake
no name up-pipe heat wrapped
exhaust manifold stock with new gaskets heat wrapped
no name silicone turbo inlet
turbo xs shortie intake with maf
turbo xs turbo timer
new o2 wideband sensor
brand new headlights with HIDS installed 10.23.11
rota 17x8 tarmac II's
I sold the car with a few miles driven on the new build. Due to recent job loss I had to part ways after spending a few grand getting it up and running ready for a new turbo setup.
I explained to the new buyer of the car to BRAKE IN the engine and drive it right for the first few thousand miles at low boost. The boost was set at 7lbs for breakin when I sold it, I told him to leave it at that until it was done being broke in... He did not.
200 miles or so into the break in period he (the new owner) managed to melt the BLUE GATES TIMING BELT off of the car and turn it black causing head damage... he then took it to a local mechanic who managed to put the cam caps on incorrectly.
A few days after the 17 yo high school kid ran the piss out of the freshly built engine...his father called me threatening to sue due to their ignorance...
A few weeks later I called the shop that the kid dropped the car off at and they told me that he attempted to have it tuned with a cobb access-port tuner... when the car originally had an open source tune on it that should have stayed for a few thousand miles to allow the engine to break in but apparently they did not care to listen. The mechanic also told me that due to the kid not breaking the engine in properly he had to replace a cylinder head due to improper break-in... so the current engine may have miss matching cylinder heads... one being built and ported and the other being a stock head.
This car has seen 3 owners sense I last owned it..
Old 02-02-2013, 09:59 AM   #208
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
417-818-2952
Stock Rods
Stock Crank
gates waterpump
gates alt belt.
Transmission:
exedy clutch
sti pink injectors
polished alternator
Sorry, but not breaking it in wouldn't cause those issues. Sounds like he drove the living piss out of it and did something else to cause the problems. There are different schools of thought on break in, some break it in hard the way they plan to drive it, others baby it. I've seen guys who break it in hard have no issues at all, while guys that baby it have engines fail early.
LIQUIDSK8S is offline   Reply With Quote
Old 02-02-2013, 01:24 PM   #209
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
I know that breaking in engines is a touchy subject. I do highly agree to you that he did something other then drive it right... He did not even change the oil the 3 or 4 times every few hundred miles to get out any old scrap metal ...
I do know when I break my engines in I take it easy for the first few hundred miles an then after a few thousand increase RPMS to ensure that the cylinder walls seal well with the rings but in this case I believe he just ramped the boost back up and slapped a stage 2 or 3 cobb stock tune on it an was ripping it every chance he got... After I sold it he sold it a few months later then 2 other owners bought it after that... so there is no telling what the 3 kids did that bought it after me its sad really... vf46?? really? ...
"The car has fuel pump injectors cams heads agp head studs vf46 ported turbo turbo inlet TB Cobb ap built trans !! 3" down pipe 3 1/2" hks exhaust boost controller turbo timer intake hks bov big front mount with hard pipe and soo much more"
Old 02-02-2013, 03:08 PM   #210
cmk82600
Member#: 248305
97 OBS
my custom mixed silver
"The car has fuel pump injectors cams heads agp head studs vf46 ported turbo turbo inlet TB Cobb ap built trans !! 3" down pipe 3 1/2" hks exhaust boost controller turbo timer intake hks bov big front mount with hard pipe and soo much more" :-|
???? Holy run on sentences Batman. Ever here of punctuation? I don't understand any of this.
cmk82600 is offline   Reply With Quote
Old 02-02-2013, 04:25 PM   #211
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
This is not the thread for grammar, if you have not noticed yet.
Keep trolling.. I'm sure you will hit your 1000th post soon so you can be a Subaru Specialist!
Thanks for stopping by!
Old 02-02-2013, 11:51 PM   #212
danyol3
Member#: 200562
2011 STi
Lolol. Punctuation. You also forgot a comma.
danyol3 is offline   Reply With Quote
Old 02-03-2013, 12:12 AM   #213
cmk82600
Member#: 248305
97 OBS
Atleast mine can be understood when read.
Old 02-03-2013, 12:58 AM   #214
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Please for the love of god let this pointless thread die.
Old 02-03-2013, 01:58 AM   #215
danyol3
Member#: 200562
2011 STi
Bump.
