Old 02-02-2013, 03:33 PM   #1
sonicyellowwayne
Member#: 334435
2003 wrx
sonic yellow
Default help a newbie out...Please?
Hello I am new to posting and in need of some help with suggestins or tips with my build
I recently just pullled my motor and went over it with a new gaskets and a gates racing timing belt kit w/water pump and all the goodies.I then did my own tgv deletes and p&p my intake .I have a header and up pipe and down pipe and hks catback but no cats.then I did a blouch 18g xt turbo and d/w 750 injectors and I already had a aem cai.I have a tial 44 with a new up pipe but I didn't put it in cuz it against my downpipe. The dumptube is to long so I have to get it shortened so I used my stock waistgate actuator and any time I get on it it throws the p0244 dtc code.I know I need a tune and I forgot to mention I have a cobb that im using to try and manage a little.but until I break the clutch in I cant get tuned I talked to ivey tuning as I live in n.j. and I will get there soon but as for the present could someone please help me trying to make my car run a little better for now.and I aplogize for seeming stupid as I hate typing
sonicyellowwayne is offline   Reply With Quote
Old 02-02-2013, 04:59 PM   #2
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Don't drive the car AT ALL until you get some type of a break in tune done.
Old 02-02-2013, 07:14 PM   #3
w.lash1
Member#: 316855
any idea or suggestions on where or how to get a break in tune
w.lash1 is offline   Reply With Quote
Old 02-02-2013, 07:15 PM   #4
w.lash1
Member#: 316855
and for some dumb reason i have 2 nasioc accounts so sonicyellowwayne and myself are the same.
Old 02-02-2013, 07:39 PM   #5
Andrewxxcarlson
Member#: 316415
2006 WRX
Get an e tune, various tuners offer these. I know of Clark turner and torqued performance that do e tunes. Also search phatbotti. That'll be the best easiest cheapest way for you to go. Do it quick cuz your gonna blow up your motor with no tune and those mods.
Andrewxxcarlson is offline   Reply With Quote
Old 02-02-2013, 08:01 PM   #6
w.lash1
Member#: 316855
okay im going to try and re word this so hopefully somebody can help me
i recenttly pulled my motor and did a gates racing timing belt and all the pulleys and water pump then i gutted my tgvs put on a grimmspeed lwcp and threw on a stage 1 clutch and lightweight flywheel as the clutch was the main reason for the motor pull.i then popped a set of d/w 750 and a blouch 18 g xt turbo onto what ar my supporting mods
cobb ..running there stage 2 map
e bay turbo inlet
hks catback
invidia up pipe
aem cai
idk the make of the header
b&m short throw
tein coilovers
stoptech drilled and slotted
bbs wheels and brand new tires
aluminium radiator
ported and polished intake
and a colorfull brand new set of blue vacumm lines all the way around
so my problem here is i need a pre tune DESPERATELY to break my clutch in and get to ivey tuning to have a pro tune done please somebody help me yell at me just tell me something
Old 02-02-2013, 08:17 PM   #7
w.lash1
Member#: 316855
and am i going to need an ebcs and an aem wideband ? are they neccasarry or mandatory
Old 02-02-2013, 08:27 PM   #8
Andrewxxcarlson
Member#: 316415
2006 WRX
I'm telling you! Stop driving your car if you are! You don't NEED a wideband! It's nice to have for peace of mind.
You cannot just run a stage 2 map using a completely different set up then the Cobb map specifies.
Get an e-tune. Do more reading on everything you have and understand how everything works.
Old 02-02-2013, 08:47 PM   #9
w.lash1
Member#: 316855
its parked im not going to drive it but i am considering putting my stock turbo back on for safety and just wait until the clutch is broke in and what else can you suggest before i go get pro tuned and how bad will it load up with those big ass injectors if i did put the stock turbo on
Old 02-02-2013, 09:08 PM   #10
Andrewxxcarlson
Member#: 316415
2006 WRX
Putting stock dp on is not gonna help. Everything you have on there you need to tune for or drivability is lost.
Old 02-02-2013, 10:21 PM   #11
sonicyellowwayne
Member#: 334435
2003 wrx
sonic yellow
When I put the stock turbo back on the only diffrence from before will be the injectors everthing else ran great with the stage two map from cobb and a few tweaks with atr for my tgvs.so why would drivability be shot. I fully understand components and what one does to another .basically I started this thread so I could see if somone with similar mods has some expierience or maybe has an atr map to help my sitiuaton. But I still value your input so please elaborate so I can make the best informed decision possible. And thank you
Old 02-02-2013, 10:23 PM   #12
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
send a PM to Phatron... and dont post again until you talk to him.
Old 02-02-2013, 10:36 PM   #13
w.lash1
Member#: 316855
i tried to send phatron a message but nasioc said i have to post 5 more legitimate posts before i can pm anybody
Old 02-02-2013, 11:22 PM   #14
Andrewxxcarlson
Member#: 316415
2006 WRX
Mmm I just never consider running injectors untuned. You just never wanna put these motors through anything they don't have to be through.
Treat your baby nicely, always with a good tune rather then puttin by. Treat her with love and she will do the same.
Old 02-02-2013, 11:26 PM   #15
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Not exactly sure what the issue here is?
You need a tune. Cobb doesn't make ots 750cc maps.
For an etune I require that u have a wideband. If you go into a shop you don't need one cause their dyno will have one. But I still think its a must have mod for all cars.
Old 02-02-2013, 11:46 PM   #16
sonicyellowwayne
Member#: 334435
2003 wrx
sonic yellow
And will I need a wideband or will the tuner work that out also.and I understand that cobb doesnt have ofs maps for my mods I was only looking for an e tune so I can run my new stuff safely.I aplogize if you feel I waisted your time I am simply trying to figure this all out and I appreciate your input.
Old 02-02-2013, 11:53 PM   #17
Phatron
Member#: 36033
CEO PhatBottiTuning
I already answered the wideband part.
If you get an etune a wideband is required.
If you go to a dyno in person the shop will have a wideband on the dyno.
Old 02-03-2013, 01:35 AM   #18
Andrewxxcarlson
Member#: 316415
2006 WRX
Wideband wasn't required for my e tune. I log constantly. I know it's a need for most. But not in my budget for the time to be. Tough times and my etune runs fantastic.
Old 02-03-2013, 01:36 AM   #19
sonicyellowwayne
Member#: 334435
2003 wrx
sonic yellow
Sorry I meant a ebcs.ive been looking and reading so much its all becoming blurry
Old 02-03-2013, 01:56 AM   #20
Phatron
Member#: 36033
CEO PhatBottiTuning
I always recommend a Perrin or gs. Not a necessity but most people do it.
Old 02-03-2013, 02:00 AM   #21
Andrewxxcarlson
Member#: 316415
2006 WRX
Agreed.
