Old 03-20-2008, 04:48 PM   #326
rougeben83
Member#: 115154
2005 Outback XT
White on grey
For the wiring, I would highly suggest getting the merge done by ECS or some other place. ECS though, I would highly recommend as they have experience doing the BE/BH engine swap...
I think ten80 voiced his opinion that in hindsight he wouldve paid someone to do the merge himself...
rougeben83 is offline   Reply With Quote
Old 05-29-2008, 01:09 AM   #327
BeckaSki
Member#: 40535
'00 Red LegacyGT w/
'03 Stage 2 WRX Swap
I discovered an interesting new issue with the car recently. When I stop the car and leave it in reverse, and turn the key off, the car stays on, engine running, dash lit up, everything. It's very very odd and quite disconcerting. It stays on until the shifter is pushed into neutral without engaging the clutch. We have no idea if it's done this all along, since I usually park it in neutral, but the hilly northwest is changing up my routine. Anybody know what might cause this?
Also, here's a picture from the tulip festival in Skagit County last month. My boss and I were in Bellingham for a meeting and stopped by on the way home. She mocked me profusely, so enjoy.
BeckaSki is offline   Reply With Quote
Old 05-29-2008, 02:06 AM   #328
rougeben83
Member#: 115154
2005 Outback XT
White on grey
wait, how is it not stalling when left in reverse and clutch out?
Old 05-29-2008, 03:20 AM   #329
ten80
Member#: 53625
00 16' FXT
She means in reverse, ignition off, clutch in, and car stays on.
ten80 is offline   Reply With Quote
Old 05-29-2008, 05:40 AM   #330
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
I think he was confused about this part:
Very strange indeed. Still one of my favorite cars in colorado though.
Plays_With_toys is offline   Reply With Quote
Old 05-29-2008, 12:00 PM   #331
ten80
Member#: 53625
00 16' FXT
Not quite, the car has been in Washington for a year now and I get to go play with it next week
Old 05-29-2008, 04:55 PM   #332
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Hmm, do you think it has something to do with the clutch switch/ignition wiring being crossed up somewhere?
I got to see if that works on my car now
Did you even get the boost spike resolved?
Old 05-30-2008, 12:33 AM   #333
BeckaSki
Member#: 40535
'00 Red LegacyGT w/
Nope. Christophe is still in Colorado for graduate school, so he only hangs out in Washington with the car once a month or so, and we usually do other things instead of work on the car. It's on the list for when he's here for longer later this summer.
Old 05-07-2010, 03:11 PM   #334
Mr Evolution
Member#: 103333
any updates with this car?
I want to know for longterm
Thanks a lot for the write up and this thread should be stickied
Mr Evolution is offline   Reply With Quote
Old 05-07-2010, 09:15 PM   #335
matty2hotty
Member#: 145838
01 B4 LGT "Sedan"
DR
+1 for updates
matty2hotty is offline   Reply With Quote
Old 05-08-2010, 12:26 AM   #336
L_C99
Member#: 225787
2004 Impreza RSTI
Just read this thread from top to bottom and enjoyed it all as a fellow BE owner. Too bad I have no ambition and no money.
L_C99 is offline   Reply With Quote
Old 06-28-2010, 11:38 AM   #337
njdriver04
Member#: 248747
04' SG XT
Blk
would there any difference if this was done with a 04 sti?
njdriver04 is offline   Reply With Quote
Old 06-28-2010, 10:25 PM   #338
ten80
Member#: 53625
00 16' FXT
Quick update-
car still runs fine with over 30k miles on the swap. Boost spike at WOT due to serious leaks from the silicone intercooler hoses- took a long time to figure out but was easy to fix! Boost is not rock-solid going up hills using cruise control, but I don't have the patience to figure that one out.
Also have a small issue when driving in traffic and warm weather; the idle RPMS get higher with every stop and eventually reach near 3000 RPM when stopped at lights. Pulling the gas pedal up with my toe brings them down a bit (~1500 RPM). I've checked the throttle cable, have flushed the radiator fluid, and installed an Grimmspeed thermostat. Don't think it's a cooling issue, but have no idea what to look at next.
Nothing new to report, I've just done basic maintenance on the car and have no plans for any upgrades or changes.
Swapping in an 04 STI would be essentially the same, except you'd might run into complications with the rear axles, I think they differ for R160 and R180 rear diffs, but I've not thought about it for a long time.
Old 12-21-2012, 09:34 PM   #339
b4Legacy02
Member#: 341267
05 Legacy / 04 WRX
any updates on this build how the car runs?
b4Legacy02 is offline   Reply With Quote
Old 02-03-2013, 10:28 AM   #340
97ej22e
Member#: 327710
1999 Impreza OBS
Green
This is an awesome build thread! I may be doing the same thing to my 98 Outback eventually.
97ej22e is offline   Reply With Quote
Old 02-07-2013, 04:10 AM   #341
Fuzzyfuzz
Member#: 284245
[quote=BeckaSki;22448081]I discovered an interesting new issue with the car recently. When I stop the car and leave it in reverse, and turn the key off, the car stays on, engine running, dash lit up, everything. It's very very odd and quite disconcerting. It stays on until the shifter is pushed into neutral without engaging the clutch. We have no idea if it's done this all along, since I usually park it in neutral, but the hilly northwest is changing up my routine. Anybody know what might cause this?/QUOTE]
My stock 02 Legacy does this. Check it out:
Anybody know what's up with that?
Fuzzyfuzz is offline   Reply With Quote
Old 02-26-2013, 12:24 AM   #342
ten80
Member#: 53625
00 16' FXT
Hadn't been on here for so long that I forgot my login....
anyways, it seems that the swap is not the cause of the "on while in reverse" issue. Good to know about this little quirk.
Car still runs great with 190k on the chassis, and we swapped in the engine (with 60k miles) at 127k. Grimmspeed thermostat failed shortly after I installed it and I'm back to a stock thermostat. Have been running Shell Rotella T-6 5w40 for the last 30k or so and the car only consumes 1/2 qt between oil changes (4,500-5,000k intervals). Need to replace door window seals and a few little minor things but mechanically it is sound.
Old 03-01-2013, 03:04 PM   #343
wfo250
Member#: 264111
Looks like the swap worked out pretty good, I might pick your brain as my swap commences.
wfo250 is offline   Reply With Quote
Old 03-01-2013, 06:17 PM   #344
rougeben83
Member#: 115154
2005 Outback XT
White on grey
nice to see you're still driving the lego!
Old 03-02-2013, 02:19 AM   #345
BE5Legacy
Member#: 347875
2005 LGT
Good to know you still have the BE swap. I wanna do this to my BE as well but a automatic turbo swap.
BE5Legacy is offline   Reply With Quote
Old 03-20-2013, 10:07 PM   #346
Sneeky Pete
Member#: 97745
2005 OBXT 5spd red
05 OB Lmited Black
Hell yea, I remember this one, good to see it still hittin them corners. Inspiring write up, I may not have my bh any more but I always wished I did this to it.
Sneeky Pete is offline   Reply With Quote
Old 06-17-2015, 02:26 AM   #347
Magoozle
Member#: 37848
1997 L->WRX
1998 Legacy GT wagooon
Bump from the dead.
I had to comment in this thread because I also have a swapped 2000 rio red Legacy sedan with six spokes as winter wheels, and in the same state, or was. Doppelganger for sure! Small world.
Magoozle is offline   Reply With Quote
Old 02-22-2016, 12:40 PM   #348
ten80
Member#: 53625
00 16' FXT
^Photos or it doesn't exist
Nearly 100k on this engine swap, now with 222K on the chassis. Cold Alaska weather seems to have brought out some fuel rail leakage issues that can no longer be ignored. Time for some serious maintenance!
1. Valve cover seals (leaking) - FIXED
2. Timing belt, idlers (some), tensioner, water pump - REPLACED
3. Injectors off to WitchHunter for cleaning & flow testing (P0301 cause?) - NOPE, all within 2% flow prior to cleaning
3. Fuel rail cold weather leaking recall (-25F Alaska weather causes serious leaks) - TSB fuel rails installed
4. Spark plugs, fuel filter, engine/trans/diff oil/power steering fluid - REPLACED fluids
5. Compression test. - AOK - 138-150 PSI on all cylinders (all within 10%)
It will be interesting to see what the compression test and injector flow testing reveal about Cylinder 1 (and 2,3,4). I'm hoping that the intermittent flashing CEL and boost issues will be resolved with the injector cleaning. The CEL was generally P0301 with random P0302 and P0303 mixed in. Perhaps the increasing frequency of missfires is due to a stretched timing belt/tensioner, a bad camshaft/crankshaft sensor, or a failing coilpack. I expect that if the problem dissapears, I'll not know exactly what fixed it.
Edit:
Completed all the work listed above, but still have a missfire issue related to the timing belt, so the car is off to the local Subaru independent shop for their expert evaluation.
Old 04-05-2016, 02:50 PM   #349
ten80
Member#: 53625
00 16' FXT
Annnnnndd after completing all the work listed above, it turns out the car had a defective new timing belt that was too loose and some leakage from Cyl 3 based on leakdown test results, but compression is good in all cylinders.
Old 04-07-2016, 12:02 PM   #350
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
Sorry to hear.... Labor is more of pain then the cost of materials.
BlackJavaPearl04 is offline   Reply With Quote
Swap 2.0L WRX or 2.5L WRX into my 00RS Rallly2000 Subaru Conversions 1 09-23-2008 10:32 PM
FS: Subaru Legacy JDM Aero Grille 2000-2004 BE BH B4 *MINT* MYfirst00 Legacy Specific Parts 13 05-09-2007 10:52 AM
FS: Fidanza Flywheel, NEW, 9.5lbs, Fits 2.0l WRX and 2.5l NA Impreza/Legacy $300 obo joltdudeuc Drivetrain 12 02-25-2007 11:00 PM
2000-2004 BE/BH Legacy GT Headlight/DRL/Fog Mods ryankenn Electrical & Lighting 4 12-21-2006 10:52 PM
FS: 2.0L WRX Turbo Motor complete ComTekAuto Private 'For Sale' Classifieds 0 04-24-2006 07:51 PM
