Old 01-14-2013, 06:19 PM   #1
SiiD
Member#: 215418
2005 VF39'd Forester
Red
Exclamation 2002 WRX Restriction at around 4-4.5k. I NEED HELP!
Hello my fellow Subie owners . My buddy and I have done extensive research on a problem he is having with his bugeye and we havent found anything exact. We have found some things that are similar but they're not the same issue.
The car is a 2002 WRX and the major engine mods include...FP 68HTA, UL Headers, up-pipe w/ v band EWG flange and dump tube, Tial 38mm MV-S EWG, FMIC, DW 750cc injectors, 2.4'' turbo inlet, Perrin SRI, Hallman MBC, Forge BPV, Walbro 255 fuel pump, and a bellmouth dp. Road tuned at 21 psi.(roughly 350whp, 300wtq)
The problem is as follows...
When WOT
~1st gear pulls all the way through redline, hits boost normally. It went by quick but i believe psi was in the low teen range.
~2nd gear builds boost and hits19/20 psi then begins to choke at 4k and wont pass 4.3-4.5k range
~3rd and 4th gear do about the same as second gear
~5th gear begins to choke at around 3.5k in the the high teen boost range
This problem ONLY occurs when WOT. If the gas is pushed half way and we stay in negative to low boost, we are able to take gears all the way to redline without the engine choking up.
Boost is hitting the same as before when driving normally and AFR is also the same at idle, normal driving, and at WOT so we concluded it couldnt be anything to do with the fuel pump/fuel lines/fuel filter, etc. Also isnt anything to do with the clutch or tranny, so it's pretty evident that it has to do with the engine not being able to release higher boost pressures.
We are thinking it's the EWG not releasing properly at higher boost due to a damaged spring or other component but we are not entirely sure.
Please let us know what you think! Others' thoughts and opinions would be highly appreciated. My buddy wants to make sure he buys only the necessary parts needed to solve the issue. Thank you all!
SiiD is offline   Reply With Quote
Old 01-14-2013, 06:45 PM   #2
SiiD
Member#: 215418
Red
also it's not throwing any codes
Old 01-15-2013, 02:00 PM   #3
SiiD
Member#: 215418
Red
anyone?
Old 01-16-2013, 11:49 AM   #4
Dat8687
Member#: 243261
2004 WRX
Java black pearl
post your maps?.. Tune possible? High load in the higher gears.
Whats your afrs doing
Dat8687 is offline   Reply With Quote
Old 01-16-2013, 01:17 PM   #5
quazimoto
Member#: 70395
This post is worthless without a datalog. I don't understand how people can spend 10K+ in mods but can spend $10 for a VAGCOM cable and download a free datalogging program.
Old 01-29-2013, 03:29 PM   #6
SiiD
Member#: 215418
Red
afr numbers are normal. has to be either the bpv or ewg not releasing higher amounts of boost pressure properly
Old 01-29-2013, 03:42 PM   #7
tachrev
Member#: 115260
04 WRX
205/22E Hybrid w/ VF39
Sounds like an ignition or fueling issue. If you waste gate wasn't opening correctly your boost would be way high. What is your boost cut set at? A jammed waste gate would trigger boost cut.
The BOV/BPV only opens when shifting, unless something is set wrong.
AFR's are normal as per what, your wide band? They don't change at all when the problem occurs?
As said before, it's going to be pretty impossible to diag the issue without a log of it happening.
tachrev is offline   Reply With Quote
Old 01-30-2013, 11:40 AM   #8
CuervoVT
Member#: 277303
2004 WRX
Obsidian Black Pearl
When were the injectors installed? My 04 did the same thing this summer and it turned out that my #3 injector was dumping fuel. New injectors and a retune later and car ran fine.
CuervoVT is offline   Reply With Quote
Old 01-31-2013, 07:58 PM   #9
cliffyh
Member#: 335815
2002 Impreza WRX
Midnight Black
you must have noticed that on the wideband though didnt you? I wonder what this guys wideband is reading and if they have one.
cliffyh is offline   Reply With Quote
Old 02-01-2013, 01:16 PM   #10
SiiD
Member#: 215418
Red
CuervoVT- Injectors were installed september of 2011 i believe. but i dont think thats the issue...im still getting the same mpg and what not
my wideband reading has been the same as before the issue started. when just cruising and being easy on the throttle with normal driving it stays around 13.8-14.7
wot i believe it gets to about 10.5-10.9
tachrev-and no, the wideband is the same as before.
Old 02-01-2013, 01:20 PM   #11
SiiD
Member#: 215418
Red
in the near future(hopefully this weekend), i am going to swap bpv/bovs with someone and see if that fixes the issue. if thats not the case i am going to assume its the ewg and i am going to just buy a new one. ill keep you guys updated and thank you for the help. more thoughts would be much appreciated
Old 02-03-2013, 07:07 PM   #12
SiiD
Member#: 215418
Red
new info...my wideband readings have been very odd. they were normalbefore but now on cold starts at idle it starts at about 10.9 and works its way up to normal readings of 14.5 -14.7 as it warms up. also at anytime, in any gear, at any speed, if i push the gas peddle down to the floor for a split second and let off, the wideband instantly hits 10.0...very odd. another friend of mine suggests i get a new bpv/bov
any thoughts on this? thank you
Old 02-03-2013, 07:28 PM   #13
quazimoto
Member#: 70395
Boost leak. Probably due to the FMIC.
Old 02-07-2013, 06:48 PM   #14
pyrox
Member#: 345474
02 WRX
240sx 2jz GT4088R
http://www.meritline.com/elm327-blue...FcGqPAodinoAsA
>get one.
>check for boost leaks
>profit..
pyrox is offline   Reply With Quote
Old 02-15-2013, 02:04 PM   #15
SiiD
Member#: 215418
Red
Are you sure its a leak? Wouldnt I still be able to redline? And wouldnt the turbo not spool up the same and hit the same until the restriction occurs?
Old 02-15-2013, 02:05 PM   #16
SiiD
Member#: 215418
Red
btw my idles are back to normal, i think it might just have something to do with this cold weather... but my wideband is still hitting 10.0 when i hit the gas peddle all the way down
Old 02-15-2013, 02:05 PM   #17
SiiD
Member#: 215418
Red
and thanks pyrox, jut ordered it
Old 02-23-2013, 04:54 PM   #18
SiiD
Member#: 215418
Red
ill have logs available once the reader comes in the mail. i cleaned the maf sensor and my afr is back to normal and car isnt running rich anymore(kinda miss all the backfires lol) i also took off bumper and made sure intercooler piping was on snug. any suggestions now? could there be a way the turbo is going out?thanks guys
Old 02-26-2013, 10:49 AM   #19
SiiD
Member#: 215418
Red
Some people are suggesting that I replace my spark plugs and they believe the ignition and timing might be off, so I am getting those replaced in less than two weeks. any other thoughts?
