Old 02-01-2013, 11:53 AM   #1
grimzella
Member#: 345608
Default Legacy 2002 SOHC timing belt question.
Hello,
I have an issue with my timing belt marks on the ej25 SOHC. i have a picture of what my main question is about. The crankshaft mark is just how i left it when i pulled the belt to do a head gasket replacement. Both sides. the cam markings on the belt and on the plastic guard lined up perfectly but the picture shows that the crankshaft mark is off to the right. does this mean i should do another rotation to realign the crankshaft mark? does it matter if i just turn the crankshaft without the belt.. or should i put the belt back on and just rotate everything? if i can just turn the crankshaft to align the centermark.. must i turn the engine to the right(driver) or to the left(pass). one thing i noticed when the heads were off is that the drivers side cylinder head valves were open (not sure now which ones) but not all. but yet the left side had all valves closed.
Thanks for any help in this matter.
David
edit.. image to come..
grimzella is offline   Reply With Quote
Old 02-01-2013, 12:36 PM   #2
grimzella
Member#: 345608
well i cant seem to get my website to upload the picture.. the centermark on the crankshat gear seems to be just one tooth to the right.. if i turned it to the left just a smidget.. the marks would line up perfectly.. but right now the mark on the engine block is in the "valley" and not on "top" of the tooth if thats imaginable?
Old 02-02-2013, 01:20 PM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
1-Make sure you're using the correct crank timing mark, it's on the "timing tooth" towards the back of the timing/crank gear, not the front face of the timing gear.
2-With the timing belt off, it really won't make a difference in which way you spin the crank, especially if the cams "move freely" meaning the valves are closed.
3-I didn't see your linked picture, it appears to be a business website with Quad pictures.
Old 02-02-2013, 10:11 PM   #4
grimzella
Member#: 345608
thank you.. that info helps alot.. ya, i dont know what happened there.. that was not the plan with the way my business page came up. i tried to keep all that stuff out but just show the pic of the crank..
Old 02-03-2013, 09:24 PM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Sooo....how did you make out??
