Old 02-02-2013, 08:08 PM   #1
URABUS05
Member#: 134974
05 WRX
Default Power steering pump hose - broken screw
I was getting some belt squeal so I did some digging and thought it might be related to the power steering hose o-ring. After replacing the o-ring, the screw snapped while I was tightening it down. Anyone know how bad I bad I screwed myself on this one? Any ideas for the most cost effective solution?
URABUS05 is offline   Reply With Quote
Old 02-03-2013, 02:16 AM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Use a chisel to turn the bolt out. If that doesn't work weld a nut on it and remove it. There is even enough showing to grab it with vice grips. It looks easy to remove.
Old 02-03-2013, 02:19 AM   #3
Frankh21
Member#: 295776
2005 SAAB 9-2x Aero
You'll most likely have to drill out the broken stud and make some new threads with tap and die set.
Frankh21 is offline   Reply With Quote
Old 02-03-2013, 10:08 AM   #4
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Get vice grips on it and turn it out. Or try to weld on to it if you even have the stuff to do so.
If those fail drill the bolt and use an EZ out to get it out, retap the threads, reinstall.
Old 02-03-2013, 12:24 PM   #5
rdieder
Member#: 257818
2007 STi
Vice grips, or dremel a cross on it and back out with a Phillips screwdriver, a shot of heat with a mapp or propane torch will help too.
rdieder is offline   Reply With Quote
Old 02-03-2013, 12:31 PM   #6
Tweeder
Member#: 129922
2007 Titan
Try getting some PB blaster on it if you don't have a torch to heat it up
Tweeder is offline   Reply With Quote
Old 02-03-2013, 06:42 PM   #7
URABUS05
Member#: 134974
05 WRX
I was able to grab it with a small vice grip. Thanks for the advice all!
Old 02-03-2013, 10:26 PM   #8
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Buy a torque wrench and download a factory service manual.
Old 02-03-2013, 10:29 PM   #9
hopsyn
Member#: 311555
2011 WRX STI
Dark Gray Met
The next time you have a similar situation the correct route would be
1st= vice grips (there are better pliers with sharper teeth made by knippex)
2nd= Easy out / screw extractor, you need to drill a through the center of the screw/ bolt shank to stick the extractor into. Don't use a worn out extractor it'll **** it up worse. You tell by looking at the teeth on it should be clean and sharp where it engages in the hole. I've had guy tell me that it was good only to see it worn in the exact spot it needed to work at.
3rd= (You dont want to ever get to this point) drill out the entire bolt/screw and tap new threads! in most cases you may not be able too because the next bolt size up won't work with the part.
I won't mention welding because unless you have a welder it makes no sense.
also penetrating oil, gas torch, and freezing does work.
always use oil first
cold or heat really depends on situation...
hopsyn is offline   Reply With Quote
