Old 01-25-2013, 11:09 PM   #2701
SWP is Sexy
Member#: 302389
I'm a stormtrooper pewpew
Connect it to your computer and download the most recent updates first, being up to date is always good
SWP is Sexy is offline   Reply With Quote
Old 01-25-2013, 11:39 PM   #2702
thildwrx
Member#: 303531
12 Subaru WRX
Awesome guys thanks for all the info
thildwrx is offline   Reply With Quote
Old 01-28-2013, 07:52 PM   #2703
thildwrx
Member#: 303531
12 Subaru WRX
Does anyone here know what the stock sti center cap diameter for the stock wheels are?
Old 01-28-2013, 09:05 PM   #2704
_davin
Member#: 260501
2003 miata SE
Blurple
From this I'm going to assume 65mm.
Old 01-29-2013, 11:09 AM   #2705
Redmed427
Member#: 254409
2011 WRX 5-door
LR
I've noticed my eibach sway bar is no longer parallel to the ground in the rear since the c/o install. I think I've read about this online before. Is this ok? Are my sway bars still providing the amount of load as they were before the lowering of the car? I'd say the rear sway is about 30-40 degrees above parallel.
Redmed427 is offline   Reply With Quote
Old 01-29-2013, 11:50 AM   #2706
SWP is Sexy
Member#: 302389
Uh, are you sure its 40*? Thats a ****load, if you're lowered on coilovers I'd be surprised if the sway bar could achieve a 30-40 degree angle without hitting the ground
Did you make sure the coils were even before installing?
Old 01-29-2013, 04:57 PM   #2707
Redmed427
Member#: 254409
2011 WRX 5-door
LR
Yes they were even. Okay I think its more of a 10-30 degree. Can't be accurate. Here is a picture
Old 01-29-2013, 05:33 PM   #2708
SWP is Sexy
Member#: 302389
I had a different mental picture of what was going on, I'd have to get up under there and see it stock and then with the sway to tell you for sure. Can anyone else chime in?
Old 02-03-2013, 09:36 PM   #2709
thildwrx
Member#: 303531
12 Subaru WRX
Ok quick question just did some data logs everything looks but 1 question on boost. I am running stage 1 ACN map which calls for 15 psi max boost. I am seeing about 15.4 to 15.6 peak boost. From what I've read within 1 psi is ok. What's everyone's thoughts and is this enough info? Thanks
Old 02-03-2013, 10:54 PM   #2710
SWP is Sexy
Member#: 302389
You're fine. If you get over 16 you'll have to start thinking about your bpv, and at 17 your intercooler.
The ap says ~.5 variance is expected. Especially in the cold
Old 02-03-2013, 11:09 PM   #2711
thildwrx
Member#: 303531
12 Subaru WRX
Ok thanks.
How do people go stage 2 then if that calls for 17psi? Is stage 2 unsafe then?
Old 02-03-2013, 11:43 PM   #2712
SWP is Sexy
Member#: 302389
They will hold higher, the numbers I posted are the lowest numbers I know of where theyve been reported to blow. I have heard of one or two cases of BPVs separating on stock tune.
That being said I've spiked over 20psi with mine and its magically still together
Old 02-03-2013, 11:45 PM   #2713
thildwrx
Member#: 303531
12 Subaru WRX
So what are you running on your car?
Old 02-03-2013, 11:47 PM   #2714
SWP is Sexy
Member#: 302389
Cobb OTS stage 2+AEM. I overboost in 4th because of my exhaust, and I have the "bulletproof" TMIC mod
Old 02-03-2013, 11:49 PM   #2715
thildwrx
Member#: 303531
12 Subaru WRX
Sorry for the noob question but what's that?
Old 02-03-2013, 11:51 PM   #2716
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
tp stage 2 is 19psi..although it usually only reaches 18 or so, probably because im 850ft above sea level. I think my bpv is fine but idk
Old 02-03-2013, 11:53 PM   #2717
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
http://legacygt.com/forums/showthrea...rx-158870.html
nightdown fox is offline   Reply With Quote
Old 02-03-2013, 11:54 PM   #2718
SWP is Sexy
Member#: 302389
Whats which part?
Cobb OTS Stage 2+AEM - A preformulated map available for download on Cobb's website for use on an Accessport that is intended for a mostly stock car with a catted downpipe and an AEM intake
"Bulletproof" TMIC mod
Available to buy here assuming they're still in stock
Old 02-03-2013, 11:55 PM   #2719
SWP is Sexy
Member#: 302389
Have you tried a HWG variant?
edit: assuming TP has one
Old 02-04-2013, 01:05 AM   #2720
Celery GT-5
Member#: 98210
2002 WRX SRP
its hitting what it should depending on the conditions
its around 19..lol
Old 02-04-2013, 01:09 AM   #2721
SWP is Sexy
Member#: 302389
Houston is supposedly only about 50-100ft above sea level, I guess that would contribute to higher psi
Old 02-04-2013, 01:10 AM   #2722
thildwrx
Member#: 303531
12 Subaru WRX
So in your guys opinion would a dp and ots stage 2 be relatively safe? Stage 2 is as far as i want to go, but also want to be safe.
Old 02-04-2013, 01:15 AM   #2723
Celery GT-5
Member#: 98210
2002 WRX SRP
i haven't personally heard of any stage 2 failures with torqued performance stage 2..but I'm sure some one has blown up...idk...seems pretty safe as long as you driving in a relatively sane manor. Cobb's got to be pretty safe considering the amount of people who use it...
its probably safer than stock honestly...but if you blow up stock you can just go get a new engine from subaru, if you are tuned it could go either way
Old 02-04-2013, 01:42 AM   #2724
SWP is Sexy
Member#: 302389
Make sure its a catted DP and you should be ok. I would also consider doing something for your intercooler and BPV, Stage 2 is usually in the 18-19psi range and both those parts have been reported to fail at lower pressure than that. Granted those aren't the majority of cases, but its not really the kind of thing you want to chance without a backup either
Old 02-04-2013, 02:01 AM   #2725
thildwrx
Member#: 303531
12 Subaru WRX
Ok sounds good thanks for the input.
I was just looking at cobbs map that I would be running and the target boost is 17psi. But still better safe than sorry on those two parts!
Differences of 2011 wrx motor and 2011 sti motor stpkenton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-06-2012 11:03 AM
Differences of 2011 wrx motor and 2011 sti motor stpkenton Newbies & FAQs 3 05-12-2011 09:27 PM
2011 Subaru shifter fitment! All TWM Shifters still fit! TWM Performance Vendor Announcements 14 02-28-2011 03:27 PM
iPod 3g DLO Jam Jacket (clear) and Radtech 3g Indigo Podsleev 10gb/15gb agentmaxwell Private 'For Sale' Classifieds 1 05-24-2006 07:41 PM
Attn: Clayton, Ben and all others involved in the 6MT discussion. sherifx Mid West Subaru Owners Club Forum -- MWSOC 1 07-31-2002 03:00 AM
