Old 01-26-2013, 08:07 PM   #1
Serkan
Member#: 180514
2004 Sti
Default upsizing muffler pipe diameter
I have the turboXs magnaflow cat back setup on my car. I have heard so many exhaust but this is my favourite.
The downside for this setup is it goes from 4" bell mouth downpipe to 2.5" axleback. With a bigger turbo setup I definitely need 3" exhaust all the way.
Is it possible to weld 3" piping to Magnaflow muffler ?
Are the internals still going to restrict and making the modification useless ?
Thanks.
Serkan is offline   Reply With Quote
Old 01-28-2013, 10:34 PM   #2
bebesito21
Member#: 176128
5862 ...baby boosted
I think its been proven that there isn't a difference up to x whp between 2.5 and 3" pipe
With that said nothing is stopping you from cutting and substituting 3" pipe however if the muffler is 2.5" then its pointless and u will have to swap the muffler to get a true 3" exhaust
My .02
bebesito21 is offline   Reply With Quote
Old 01-28-2013, 10:38 PM   #3
bugeyesubie
Member#: 179783
Silver STi swap 380wph!!
Most rally cars in the North American rally circuit that are all over 400 whp run 2.5" exhaust. I'd say. Stick with 2.5"
bugeyesubie is offline   Reply With Quote
Old 01-29-2013, 12:34 PM   #4
DeleriousZ
Member#: 323869
2000 ST-outback
White/Grey
To answer your question, yes it is possible. You can pick up a 'reducer' to stick between the two different diameter pipes. You'll need to cut some of the pipe pre-muffler to allow for the added length of the reducer.
DeleriousZ is offline   Reply With Quote
Old 01-29-2013, 04:44 PM   #5
Serkan
Member#: 180514
2004 Sti
I don't want to do this if there is still going to be a restriction inside the muffler.
I guess I will just sell this and get a full 3" catback.
Thanks.
Old 02-04-2013, 01:23 PM   #6
Serkan
Member#: 180514
2004 Sti
Ok, I bought a 3" fujitsubo jasma cat back.
Even tho it has 3" piping if you look inside from the muffler tip there is 2.5" diameter piping in there ?
I want to know how are 3" mufflers are designed inside.
If i can get same performance by making the magnaflow muffler 3" than I want to stick with it rather than using another 3" cat back has the same restriction in the muffler.
