Old 02-04-2013, 12:59 PM   #1
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
So for the past 8 months or so I have been getting some kind of high pitch flutter under part throttle when I give it full throttle it goes away. It sounds like me Cobb intake making the noise but tuner said its my vf52 wastegate. It's gotten to be pretty annoying cause I highway drive a lot and it only seems to do it in 4th or 5th mostly under part throttle. It seems to high pitch to be the wastegate and it cant be a leak cause it doesnt happen at full throttle. Anybody else experiencing this? Thanks Ryan
Edit: mods are grimmspeed ebcs, turboxs catless turbo back, Cobb sf intake, torque solution Tmic, dw65c fuel pump, turbo smart Bpv full recirculating
ryblair is offline   Reply With Quote
Old 02-04-2013, 01:08 PM   #2
The Duke
Member#: 264877
Wastegate.
The Duke is offline   Reply With Quote
Old 02-04-2013, 01:16 PM   #3
the suicidal eggroll
Member#: 51961
2005 STi
Intakes don't make noise, especially not fluttering. All they do is allow other noises to resonate and get louder when compared to the stock intake.
Old 02-04-2013, 01:25 PM   #4
coalslaw
Member#: 324808
2006 IWL Stg2
list your boost controller and your exhaust setup
coalslaw is offline   Reply With Quote
Old 02-04-2013, 02:01 PM   #5
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
Post edited
Old 02-04-2013, 02:13 PM   #6
tuzzio
Member#: 292532
05 STI
You're just hearing the wastegate opening and closing under heavy load.
tuzzio is offline   Reply With Quote
Old 02-04-2013, 02:31 PM   #7
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
It's not under heavy load though its happening around 10psi heavy load would be more around 18psi
Old 02-04-2013, 02:40 PM   #8
ryblair
Member#: 309638
2011 wrx premium
dark metallic grey
Thanks that's what I figured I suppose ill just put up with the high pitch flutter
