![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 273862
Vehicle:2011 WRX STI 4D Dark Gray Metallic |
I apologize as I see a lot of similar posts asking for help w/ tire decisions but after searching none were close enough to my situation...
I am in the market for a good all-around Summer tire for my 11 STI. Dry/wet Grip and non-excessive noise is the two most important criteria for me. Treadwear is not as important but still a consideration. I was about to get Pilot Super Sports but quanities are limited and I was told they could not be purchased through my wholesale connection. I found three back-up options, Bridgestone Potenza Pole Position S-04, BF Goodrich g-Force Sport Comp-2, and Continental ExtremeContact DW. Some people have told me anything will be better than the stock Dunlop SP Sport 600's which I tend to believe as they're awful, but needed more opinions if possible.
#2 |
Vehicle:OK Houston we have an Uncle |
#3 |
Member#: 273862
Hahaha meaning all off older gen wrxs or 17s in general.
#4 |
Hoodbridge!
Moderator Member#: 560
MAIC
Vehicle:2006 STi, '11 A4 Crystal Gray, Silver |
SO-4's. Those will be my next tire. I had the older S0-3's and they were the best street tire I've ever had.
#5 |
Member#: 336091
Def the Bridgestone tires always good choice low noise good tread wear too
#6 |
Member#: 334263
VIC
Vehicle:2006 WRX STI Black |
Federal 595 RS-R it's a track tire but I love them!! They are amazing in the dry and good in the wet as well. I'm at 20k and they still have 35% tread left. they are cheap to $105 per tire. They fit wide though so you might need 245's for stock wheels
![]() Last edited by 06trackguy; 02-04-2013 at 08:11 PM. |
#7 |
#8 | |
Member#: 273862
Also, I put that "I tried searching" disclaimer on any post that may have a "tired" subject so people don't bitch or try to make an example of me. Some people have nothing better to do than to do that ;-) |
#9 |
Member#: 273862
Anyway, I appreciate the opinions. If I cannot get the Super-Sports through my wholesale connection I will most likely default to the Bridgestone Potenza S-04's. I was already kind of leaning that way and it sounds like others have had good experience as well.
Thanks! |
#10 |
Member#: 82391
MWSOC
Vehicle:08 OBP Sti stg2.... 279awhp, 299tq |
There are still people that drive in #I mode.
![]() Id avoid extremecontact DW unless you want a very soft tire putting around everywhere. |
#11 |
#Belieber
Moderator Member#: 140163
MAIC
Vehicle:03 STi hellaflunctional |
#12 |
Member#: 273862
I only said that because the GD had 17's and there are great tires that you can't purchase for the GR because they are 18's (Star Specs, certain Kumhos, etc). I was just stating that to compare apples to apples.
#13 |
#Belieber
MAIC
So nobody has ever gone with a set of 18s on their GD? And what tires can you buy in 17s but aren't available in 18s?
#14 |
Member#: 273862
I know people have gone to 18's with them but in this case I was looking for a quick answer and I wasn't finding any scenarios that were the same as mine. I don't know why you are making me out to sound like a snob or elitist because I have a GR STI, I just wanted an apples-to-apples comparison.
#15 | |
#Belieber
MAIC
#16 |
Member#: 273862
I got the answers I needed from other members but I basically wanted to pinpoint people that were coming off their OEM Dunlops and looking for their first replacement set. In other words, people in my exact shoes and also just happening to be looking for 245/40/18s or 255/40/18's. You are right, the situation is broader than that and not just confined to my exact chassis/year/etc, but I was looking to nail down opinions of those in the same position as me (buying first replacement set and generally new to the Suby world).
#17 |
#Belieber
MAIC
I ran the SP600s 2 years ago and they're not as bad as what people make them out to be. Are they great? No. Are they noisy? Yes. I didn't mind them on a daily basis but I also wasn't comparing them to better tires I've had in the past.
I've never shopped for quiet tires but your best bet is to check with Luke at TireRack. |
#18 |
Member#: 74211
Vehicle:2011 SSM WRX 4DR |
Quiet and Great Dry Grip really don't go together
I don't have experience with the SP600 but the SP01 are great if you don't mind the noise and can find a set for cheap locally. *edit*Just adding comparison about the OEM tires I know the sp01 don't have the size for 18" I'm still debating on 595RS-R or PSS as my next set if I don't find some SP01 locally Also, I'm with everyone else.. not sure why OP doesn't seem GR and GD can be compared. Hell there is plenty 09+ wrx posts about the same exact questions.... ![]() |
#19 |
Member#: 273862
The Pilot Super Sports came back in finally. Went with those after planning on Bridgestones.
Thank you to those that helped with the question instead of overly scrutinizing the question. |
#20 |
Member#: 133597
SCIC
255/40r18 is too tall.
#21 |
Member#: 273862
#22 |
#Belieber
MAIC
I don't see an issue with the GR. Definitely not a size I'd recommend for the GD.
#23 |
Member#: 97135
NWIC
#24 |
Member#: 8365
Vehicle:2005 Legacy GT Ltd Atlantic Blue |
#25 | ||||
Member#: 232010
Vehicle:2013 STI hatch SWP |
BF Goodrich g-Force Sport Comp-2 or conti DWS. they both are great for me to do HWY driving and some back roads. I don't see the NEED for having S04 w/-350whp and non tracker. Quote:
total diff is 4mm between the 2 tire, 245 or 255. I'm went with 255/40/18 & BF Goodrich g-Force Sport Comp-2, as my new set up. |
