Old 01-28-2013, 05:57 PM   #1
Johaen
Member#: 281951
2011 WRX Stage 2+
Default Help taking off downpipe on 2011 WRX.
Hello all. Two years ago my father and I installed a COBB DP on my 2011 WRX. We didn't change the gaskets, and I've kinda regretted it. I've finally gotten around to buying the gaskets, and I'm ready to replace them. I took my car to the hobby shop yesterday and I just could not get the downpipe off. It's stuck on the bracket than hangs underneath the car (yes it's unbolted), near where the O2 sensor is. I tried moving it all around but could not get it off the bracket. Does anyone have any advice on getting it off the bracket?
Johaen is offline   Reply With Quote
Old 01-28-2013, 06:02 PM   #2
09rexrunner
Member#: 293955
Unbolt it??
09rexrunner is offline   Reply With Quote
Old 01-28-2013, 06:05 PM   #3
Johaen
Member#: 281951
2011 WRX Stage 2+
It is unbolted. There's a lip on the bottom so you can't pull it down. You can't pull it up or to the passenger side because it hits the body. You can't pull it to the driver side. You can't pull it forward because it's still connected to the turbo. And you can't pull it back because the bracket hanging from the car is behind the bracket connected to the downpipe.
Old 01-28-2013, 06:06 PM   #4
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
WD40? did you ask any of the staff @ the hobby shop for help?
ChesterWRX is offline   Reply With Quote
Old 01-28-2013, 06:08 PM   #5
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
idk what is the problem.its a little bolt on a bracket. after just unplug the o2 sensor up top and pull the dp out.
Old 01-28-2013, 06:09 PM   #6
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
what if you drop the midpipe down some? pry that damn bracket to the side some! it will come off
Old 01-28-2013, 06:10 PM   #7
Johaen
Member#: 281951
2011 WRX Stage 2+
No. I wish I had. I feel like such a doofus when I ask for help. Lol.
Old 01-28-2013, 06:15 PM   #8
Johaen
Member#: 281951
2011 WRX Stage 2+
The downpipe and the midpipe are one solid piece on 2011 (2009+?) WRX. The bracket I'm talking about is back maybe a foot or two ahead of the rest of the exhaust (where the two springy bolts are).
Old 01-28-2013, 06:30 PM   #9
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
You have all the bolts removed that hold the dp to the turbo correct? With those removed and the two bolt that connect to the catback removed, the dp should just fall out.
Old 01-28-2013, 06:37 PM   #10
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
i know they are seperate. i have one. you have to pry that bracket with a prybar away from the pipe. you see it has a bent edge on the side of it? get between and pry.im saying drop the midpipe to make more wiggle room.
Old 01-28-2013, 06:38 PM   #11
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
dude...
yeah, those bolts should come right out. try clamping (compressing) down the springs? are they overly rusted? if so, WD40.
-again, ask for help. don't be a hero and break something.
Old 01-28-2013, 07:01 PM   #12
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Shove a flathead screwdriver into the lip on the bracket and use it to pry the downpipe up and out.
You might also be able to unbolt the bracket itself from the transmission, that's what I always do on my STi.
Old 01-28-2013, 07:46 PM   #13
Johaen
Member#: 281951
2011 WRX Stage 2+
Sorry for my poor wording. All the bolts are off, including those springy ones, and the one on the bracket.
I will definitely ask for help next time. I'm not sure when I'll have a chance to go again. I think I'm going to have a friend come help, but he's going out of town for a couple weeks. I think I'll try again when he gets back. And we'll definitely ask for help if we need it.
Old 01-28-2013, 07:48 PM   #14
Johaen
Member#: 281951
2011 WRX Stage 2+
I thought about using the flathead to do that, I just didn't want to break anything. I also thought about unbolting the bracket, but it didn't look too easy to get to. I'd have to look under there again to see what that looks like, but I'm not sure when I'll be able to get it on the lift again. Thanks for your advice.
Old 01-28-2013, 07:49 PM   #15
Johaen
Member#: 281951
2011 WRX Stage 2+
I gotcha. I'll definitely try that the next time I have a chance to get under there and work on it.
Old 01-28-2013, 07:50 PM   #16
Johaen
Member#: 281951
2011 WRX Stage 2+
It doesn't fall out because of this bracket that I'm talking about. I wish I had taken pictures while it was on the lift so I could better explain what I was talking about.
Old 01-28-2013, 08:11 PM   #17
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
all you have to do is pry it apart. thats it. happens to everyone here man.you arent gonna break anything.
Old 01-28-2013, 08:15 PM   #18
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yep. If the bolts are off then just use some muscle. I can usually get it by hand (with gloves on), but you may need to pry at it with a flathead. You can't unbolt that bracket easily on the 5 speed like you can on the 6 speed.
Old 01-28-2013, 08:41 PM   #19
Johaen
Member#: 281951
2011 WRX Stage 2+
Thanks all for the advice. Muscle and maybe a little bit of prying, got it. Hopefully here in the next weekend or two I'll get a chance to get it on the lift again.
Old 01-28-2013, 09:15 PM   #20
WRXSteye20008
Member#: 175565
2014 Sport Premium
Past: 351awhp Sti
I was going to recommend pulling the engine if that didn't work Glad you got it.
WRXSteye20008 is offline   Reply With Quote
Old 02-04-2013, 06:14 PM   #21
Johaen
Member#: 281951
2011 WRX Stage 2+
Thanks to all those that gave advice. I was able to get it back on the lift this weekend. I used a screwdriver and pried the downpipe off the bracket. Once it was over the edge of the bracket, it fell right out. I was able to replace the gaskets and my girlfriend and I both think the exhaust note is just a little bit cleaner. I'm glad I got that done.
Old 02-04-2013, 06:30 PM   #22
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
glad you got it. i told you to pry the bracket in post #6.
