Old 01-21-2012, 08:17 AM   #401
Honest Bob
Member#: 94698
2005 30R Wagon
CGM
The sound is awesome! Almost makes me with I didnt go EWG.
Honest Bob is offline   Reply With Quote
Old 01-26-2012, 09:25 PM   #402
michael_cano
Member#: 227643
2008 Stock as Hell
:( STi
Finished tuning today. Phatbotti tuning FTW. Stock STi's make 211awhp on this software. It feels great.
michael_cano is offline   Reply With Quote
Old 01-26-2012, 09:59 PM   #403
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
start saving for a motor and trans. You could get the same numbers on pump though.
scby rex is offline   Reply With Quote
Old 01-27-2012, 03:31 PM   #404
michael_cano
Member#: 227643
2008 Stock as Hell
:( STi
i will be. i think pump gas is a little more dangerous for the numbers i made. a stock 2011 STi makes 211 on this software. 100 hp more than a stock 2.5l sti makes is pretty good for a 2.0l. given that e85 helps the engine run cooler and cleaner, i'll take the same numbers on e85.
Old 07-26-2012, 07:35 PM   #405
silbugeye
Member#: 270366
2005 sti
Just starting to build the extra 2.0 block I have. Looking to hopefully hit 500whp on e85 with pt5757. Point is to prove everyone aroundk here that the motor can make the power
silbugeye is offline   Reply With Quote
Old 08-11-2012, 04:39 PM   #406
GeneralTJI
Member#: 152680
Figured I'd update my setup on this thread.... All about high revving, big turbo 2.0s myself
Budget built 2.0, 07 6 speed, surge, etc. all homebuilt... full mods: http://www.tjituning.com
Super HX40 w/ .70 ar BEP housing
(made 491hp on the virtual dyno setting... car weights about 3200 at the track when empty on fuel, no tools etc.)
All 4" piping, 4" borla XR1 in the fender, not terribly loud
Car should trap 127-129 and go 10's. Log was taken at 6600ft, local tracks are 5800ft and 4800ft elevation. If I can drive it properly
Thing loves to rev, and I love it for that
Will make a thread on PPB in a few weeks when temps drop and it hits the track.
Thanks for checking it out,
Todd
GeneralTJI is offline   Reply With Quote
Old 08-11-2012, 04:48 PM   #407
207STi
Member#: 197062
1998 Swapped Impreza
black
Todd
Did you have ant trouble fitting the 90 degree coupler coming off of the compressor cover? I have a HX35 and am debating on welding a 90 degree directly to the compressor cover or just using a silicone coupler like you did.
207STi is offline   Reply With Quote
Old 08-12-2012, 01:02 AM   #408
GeneralTJI
Member#: 152680
It was a bit of a task... I carefully grinded down the vband to just leave a nice smooth lump to keep the coupler on... Doubled up on clamps to also make sure lol. Seems to be working well...
Old 08-28-2012, 12:59 PM   #409
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Bump this because larger turbos on smaller motors are INTERESTING!
Old 08-28-2012, 01:38 PM   #410
SpamMansXe
Member#: 15920
1999 White Mock 22B
2014 Plasma Blue GR STi
I just need my hard inlet to come in and I will be using a PnP Blouch TD06 20G on my ej20k. Should be for some goooood times!
SpamMansXe is offline   Reply With Quote
Old 11-04-2012, 04:03 PM   #411
Dr. octagon
Member#: 171127
2015 Subaru
bump because this thread good ****
Old 11-04-2012, 05:21 PM   #412
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
Love the work General has done in the past year. love the oil cooler idea. might have my friend w/ his build ej25 do that since he has fmic short pipe style courtesy of my design! He is on a twin scroll huge BW turbo off a John Dee of some sort. even has the deer logo on the compressor! made 540whp on the virtual dyno setting and amost 600 w/ the dynojet setting. all on e85. got the turbo off ebay for 200 dollars too!
WhiteBgeye02 is offline   Reply With Quote
Old 01-11-2013, 02:37 PM   #413
codys_scooby86
Member#: 342842
07 Rex
JBP
any one having any luck with 50 trim's on the 2.0, as that is a choice i am considering atm?
codys_scooby86 is offline   Reply With Quote
Old 01-11-2013, 02:57 PM   #414
SRT6
Member#: 301685
05 Wrx sedan
Wtf? You guys are running cummins turbos holy crap!!! That's badass how much mods you have to do to run one?
SRT6 is offline   Reply With Quote
Old 02-04-2013, 03:54 PM   #415
smadasam
Member#: 161271
2005 Saab 92x
Here's a look at my rotated GTX3071R setup on my 2.1 stroker. That turbo flows ~57 lbs/min.
It made about 412 whp, but could have kept going maybe another 50 whp on 92 octane pump gas. Dom tuned down the torque curve and power in consideration of my 5-speed. I am satisfied with the results.
smadasam is offline   Reply With Quote
Old 02-04-2013, 09:23 PM   #416
Excision
Member#: 294622
2007 STI - WRB
Perrin GTX3076r, Slow
^ nice setup man. are you running the turboxs fmic?
Excision is offline   Reply With Quote
Old 02-21-2013, 02:47 AM   #417
smadasam
Member#: 161271
2005 Saab 92x
It was just a cheap ebay one. It seems to work though.
Old 02-21-2013, 03:34 AM   #418
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Originally Posted by Audiosavvy View Post
I agree, but a few things need to happen before you can just raise the rev limit. And all of them include disassembling the block, and it would be foolish to not at least build build the internals a bit to take the abuse. So if you're sticking with the stock block, I say stick with it as it is and see how she runs
I agree, I spun the bearings on three stock blocks at 7.5k. Build for it. I now turn 8k.
Old 02-21-2013, 08:56 AM   #419
gervais007
Member#: 283793
How much rpm you get full boost
gervais007 is offline   Reply With Quote
Old 02-21-2013, 10:30 AM   #420
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Im still tuning but it is early like about 3800.
Old 03-04-2013, 12:01 AM   #421
treystoys
Member#: 97436
03 toyota tundra
gray..missing my WRX's :(
Hey guys havent been around in a while lots going on lately. Anyhow, ran across this thread today. Figured I'd throw mine out there.
Ver8 207 completely stock long block oe big ports
AVCS enabled s203 ecu
Perrin rotated 3076 .82 a/r my home brewed I/C pipes w/blow-thru maf
255 fuel pump
PE800s
Externally dumped w/g
Fxt 4.44 fd tranny
Tuned by me 93 octane 24 psi
Oh as far as track times, it's been a while since I've been, but with this set up and numbers in the 425 range the car ran 11.60s @ 118ish 1.90 short times. I'd wager a guess and say she's good for 11.40 @ 120 or so possibly better if I can get it to 60' worth a darn...here's the motor and graph for your viewing pleasure!
Actually just added a dei titanium blanket and wrapped the downpipe, I'll update the pic later
Trey
treystoys is offline   Reply With Quote
Old 03-22-2013, 06:43 AM   #422
2000subie
Member#: 207638
2004 WRX
Yellow
Well figure I will get in on this as well. My car is currently down right now, willl post results of my new set up once its up and running. My old set up was as listed.
stock 04 ej205
reversed IM
ks tech 16mm spacer's
fic 1000's
walbro 255
tgv deletes
rotated gt3076r
precision 39mm EWG
turboxs fmic (hacked up to fit)
turboxs mbc
3" tbe straight pipe
AEM ems
tuned on sd and corn at 21psi
going through a 05 6mt swap.
car was tuned pretty conservativly by Harvey at the boostcreep in Longmont, Co.
Was putting down 374whp. Never got to make a full/clean pass on this set up. When doing the 6mt swap I ran the missing link set up, but it was for sti to gc impreza axles (tiny shafts). Day before going to the track i broke one from a roll, so needless to say I had no intentions of it holding off the 2 step. At the track I never got to do a launch, was leaving from the line as if taking off from a stop light. I still managed a 13.01 at 121mph. So with hopes of setting the stock 205 record, I went home and ordered axles that would handle the job, only to blow through my stg.2 exedy the first time back at the strip. Car is now undergoing quite a few changes still ej205 base though! I believe the car had mid 11's in it if all went well.
2000subie is offline   Reply With Quote
Old 05-15-2013, 08:15 PM   #423
under0athh51189
Member#: 193959
2001 Lexus IS300
05 Wrx AW 18x9.5 WFC#295
well here is my contribution.
stock ej205(115k)
comp turbo 5858
custom rogue ic piping and precision core
custom rogue/tampabay tuned rotated up and dp.
prosport uel header
dw 780cc inj
walbo fp
hks bov
3 inch straighpipes
tial 38mm ewg with dump out hood
aem v4 ems
prosport mbc
prosport titanium turbo blanket
legacy gt gears cryo treated
act hd streetdisc and lightweight flywheel
dyno will be dynojet
tuned by omar crespo area 51 tuning at tampabay tuned
elevation sea level
haven't tuned yet having a problem with the aem connecting with the crank. don't know why my tuner is speaking with the guy who made the harness now to figure out whats going on. looking to make around 350whp or so.
old setup was the same supporting mods with blouch evo III big 16g on 20psi making 330whp on a high reading dyno. was really around 300whp but was a blast to drive. we'll see how this setup is. gonna be laggy but should still be fun.
sorry for the crap cell phone pics. ill post updates and graphs when it gets done.
under0athh51189 is offline   Reply With Quote
Old 05-15-2013, 09:11 PM   #424
2000subie
Member#: 207638
2004 WRX
Yellow
stock ej205(115k)
comp turbo 5858
prosport uel header
dw 780cc inj
walbo fp
hks bov
3 inch straighpipes
aem v4 ems
prosport mbc
elevation sea level
Nice looking set up! How much boost are you planning to run? I'm assuming your on 93oct with only 780cc injectors. And I wouldn't expect spool to be too bad, prolly 45-4700rpm. Lag is over rated anyway, my set up doesn't spool great but definitely revs! How far do you plan to rev yours out to?
Old 05-15-2013, 09:36 PM   #425
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
Yeah Im running a Precision/Garrett PTE5031 (50 trim) on my stock EJ205. Made 330whp with it, however, throwing a EJ25 in with my port matched heads. Hoping to get a GT3071R soon but will be running the 50 trim on the EJ25 for a little bit
emsmap is offline   Reply With Quote
subaru 2.0 GX AWD - NOW 2.0 L TURBO jay_parot Normally Aspirated with bolt-on Forced Induction Powertrain 0 07-24-2009 10:48 PM
subaru 2.0 GX AWD - NOW 2.0 L TURBO jay_parot Normally Aspirated with bolt-on Forced Induction Powertrain 0 07-24-2009 10:46 PM
Cobb Stage 2 0-90 MPH log - how's it look? Drivinwest AccessPort 3 06-18-2009 04:09 PM
New Hyundai 2.0 and 2.0-Liter Turbo Diesels with up to 200HP AVANTI R5 Non-Subaru News & Rumors 10 11-06-2008 01:50 AM
apv2 2.0 wrx 2002-2005 600 shipped paypal nuffy Engine/Power/Exhaust 0 07-24-2007 10:48 AM
