Old 02-04-2013, 05:47 PM   #1
Phil_Dunphy
Member#: 273862
2011 WRX STI 4D
Dark Gray Metallic
Default Need help w/ 255/40/18 Tire Decision
I apologize as I see a lot of similar posts asking for help w/ tire decisions but after searching none were close enough to my situation...
I am in the market for a good all-around Summer tire for my 11 STI. Dry/wet Grip and non-excessive noise is the two most important criteria for me. Treadwear is not as important but still a consideration. I was about to get Pilot Super Sports but quanities are limited and I was told they could not be purchased through my wholesale connection.
I found three back-up options, Bridgestone Potenza Pole Position S-04, BF Goodrich g-Force Sport Comp-2, and Continental ExtremeContact DW. Some people have told me anything will be better than the stock Dunlop SP Sport 600's which I tend to believe as they're awful, but needed more opinions if possible.
Phil_Dunphy is offline   Reply With Quote
Old 02-04-2013, 06:28 PM   #2
Uncle Scotty
OK Houston
we have an Uncle
that means that you must be driving on a planet other than the earth
Old 02-04-2013, 06:44 PM   #3
Phil_Dunphy
Member#: 273862
2011 WRX STI 4D
Dark Gray Metallic
Hahaha meaning all off older gen wrxs or 17s in general.
Old 02-04-2013, 07:09 PM   #4
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Crystal Gray, Silver
SO-4's. Those will be my next tire. I had the older S0-3's and they were the best street tire I've ever had.
mav1c is offline   Reply With Quote
Old 02-04-2013, 07:15 PM   #5
Isshinryu28
Member#: 336091
Def the Bridgestone tires always good choice low noise good tread wear too
Isshinryu28 is offline   Reply With Quote
Old 02-04-2013, 07:42 PM   #6
06trackguy
Member#: 334263
2006 WRX STI
Federal 595 RS-R it's a track tire but I love them!! They are amazing in the dry and good in the wet as well. I'm at 20k and they still have 35% tread left. they are cheap to $105 per tire. They fit wide though so you might need 245's for stock wheels
06trackguy is offline   Reply With Quote
Old 02-04-2013, 08:45 PM   #7
Uncle Scotty
OK Houston
we have an Uncle
im still waiting for the punchline, here.....
you mean to tell us that NOBODY who has any car anything similar to yours has never posted any tire questions here before
amazing......simply amazing
Old 02-04-2013, 09:46 PM   #8
Phil_Dunphy
Member#: 273862
2011 WRX STI 4D
Dark Gray Metallic
Nope, but I checked about 15-20 threads that came up in the search and none of them applied to the GR chassis STI. It's totally possible I overlooked a useful thread or two, yes. However, I was at work and didn't want to camp on the forums for too long as that kind of thing is frowned upon there.
Also, I put that "I tried searching" disclaimer on any post that may have a "tired" subject so people don't bitch or try to make an example of me.
Some people have nothing better to do than to do that ;-)
Old 02-04-2013, 09:48 PM   #9
Phil_Dunphy
Member#: 273862
2011 WRX STI 4D
Dark Gray Metallic
Anyway, I appreciate the opinions. If I cannot get the Super-Sports through my wholesale connection I will most likely default to the Bridgestone Potenza S-04's. I was already kind of leaning that way and it sounds like others have had good experience as well.
Thanks!
Old 02-10-2013, 10:25 AM   #10
dingobite
Member#: 82391
08 OBP Sti
stg2.... 279awhp, 299tq
There are still people that drive in #I mode.
Id avoid extremecontact DW unless you want a very soft tire putting around everywhere.
dingobite is offline   Reply With Quote
Old 02-10-2013, 03:22 PM   #11
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
I don't see why this matters at all. Are you trying to infer that the same tire on a GD and GR will feel and behave differently?
nhat is offline   Reply With Quote
Old 02-10-2013, 03:41 PM   #12
Phil_Dunphy
Member#: 273862
2011 WRX STI 4D
Dark Gray Metallic
I only said that because the GD had 17's and there are great tires that you can't purchase for the GR because they are 18's (Star Specs, certain Kumhos, etc). I was just stating that to compare apples to apples.
Old 02-10-2013, 04:24 PM   #13
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
So nobody has ever gone with a set of 18s on their GD? And what tires can you buy in 17s but aren't available in 18s?
Old 02-10-2013, 04:30 PM   #14
Phil_Dunphy
Member#: 273862
2011 WRX STI 4D
Dark Gray Metallic
I know people have gone to 18's with them but in this case I was looking for a quick answer and I wasn't finding any scenarios that were the same as mine. I don't know why you are making me out to sound like a snob or elitist because I have a GR STI, I just wanted an apples-to-apples comparison.
Old 02-10-2013, 08:28 PM   #15
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
I'm not making you out to be anything other than confusing. I really have no idea what you mean by an apples-to-apples comparison. Are you looking for someone with a GR to chime in on their experiences with certain tires? As if a tire will behave differently between a GD and a GR?
Old 02-10-2013, 08:41 PM   #16
Phil_Dunphy
Member#: 273862
2011 WRX STI 4D
Dark Gray Metallic
I got the answers I needed from other members but I basically wanted to pinpoint people that were coming off their OEM Dunlops and looking for their first replacement set. In other words, people in my exact shoes and also just happening to be looking for 245/40/18s or 255/40/18's. You are right, the situation is broader than that and not just confined to my exact chassis/year/etc, but I was looking to nail down opinions of those in the same position as me (buying first replacement set and generally new to the Suby world).
Old 02-11-2013, 12:53 AM   #17
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
I ran the SP600s 2 years ago and they're not as bad as what people make them out to be. Are they great? No. Are they noisy? Yes. I didn't mind them on a daily basis but I also wasn't comparing them to better tires I've had in the past.
I've never shopped for quiet tires but your best bet is to check with Luke at TireRack.
Old 02-11-2013, 12:11 PM   #18
hakira
Member#: 74211
SSM WRX 4DR
Quiet and Great Dry Grip really don't go together
I don't have experience with the SP600 but the SP01 are great if you don't mind the noise and can find a set for cheap locally. *edit*Just adding comparison about the OEM tires I know the sp01 don't have the size for 18"
I'm still debating on 595RS-R or PSS as my next set if I don't find some SP01 locally
Also, I'm with everyone else.. not sure why OP doesn't seem GR and GD can be compared. Hell there is plenty 09+ wrx posts about the same exact questions....
hakira is offline   Reply With Quote
Old 02-11-2013, 12:24 PM   #19
Phil_Dunphy
Member#: 273862
2011 WRX STI 4D
Dark Gray Metallic
The Pilot Super Sports came back in finally. Went with those after planning on Bridgestones.
Thank you to those that helped with the question instead of overly scrutinizing the question.
Old 02-11-2013, 01:38 PM   #20
Badler
Member#: 133597
255/40r18 is too tall.
Badler is online now   Reply With Quote
Old 02-11-2013, 02:34 PM   #21
Phil_Dunphy
Member#: 273862
2011 WRX STI 4D
Dark Gray Metallic
I've heard of many going from 245/40 to 255/40. The difference here is .1 inches on sidewall height. ???
Old 02-11-2013, 04:39 PM   #22
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
I don't see an issue with the GR. Definitely not a size I'd recommend for the GD.
Old 02-11-2013, 06:39 PM   #23
sc00by4life
Member#: 97135
Not for the 6 speed.
Old 02-11-2013, 08:04 PM   #24
krzyss
Member#: 8365
2005 Legacy GT Ltd
Atlantic Blue
Nominally (real size is separate matter) 40% of 10mm = 4 mm.
1 inch -> 25.4mm.
~1.6"
Krzys
krzyss is offline   Reply With Quote
Old 02-17-2013, 09:19 PM   #25
jaxx4k
Member#: 232010
2013 STI hatch
S04 tread wear is not better then his other 2 options.
I'm only stg1 7 mostly stock, don't track, don't auto X, I've been searching for tires, which came down to this.
BF Goodrich g-Force Sport Comp-2 or conti DWS.
they both are great for me to do HWY driving and some back roads.
I don't see the NEED for having S04 w/-350whp and non tracker.
1 inch -> 25.4mm.
~1.6"
Krzys
total diff is 4mm between the 2 tire, 245 or 255.
I'm went with 255/40/18 & BF Goodrich g-Force Sport Comp-2, as my new set up.
jaxx4k is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 02:58 PM.
