Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 02-02-2013, 11:19 PM   #1
Mastuss3055
Member#: 334085
Default valve cover problem
I just got my motor rebuilt finally. I got the 255 in the car and started it up but foind out that the valve cover gasket around the spark plug is leaking. My question is can I pull the valve cover without draining the oil? Please let me know I want to get this done asap.
Mastuss3055 is offline   Reply With Quote
Old 02-03-2013, 12:09 AM   #2
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
Yes you can pull the valve cover without draining the oil.
Old 02-03-2013, 12:12 AM   #3
Mastuss3055
Member#: 334085
Old 02-03-2013, 12:19 AM   #4
Mastuss3055
Member#: 334085
Ok so what would be the easiest way to pull the valve cover while in the car. My hands are to big to get to the lowest bolt at the back of the valve cover on the driverside. So can I just unbolt the motormounts and jack up that side of the motor to make room?
Old 02-03-2013, 12:26 AM   #5
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
Yes that is what I do. I jack it up and move it over. Remove the pitch stop first though.
Old 02-03-2013, 09:10 PM   #6
Mastuss3055
Member#: 334085
ok got tha suby up today I just have to get the money together to have the motor broke in
Old 02-03-2013, 10:22 PM   #7
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Need money to break in a motor?
Old 02-04-2013, 12:27 AM   #8
Mastuss3055
Member#: 334085
I'm taking it to cobb to have them break it in on the dyno
Old 02-04-2013, 12:28 AM   #9
Mastuss3055
Member#: 334085
I have no idea how to do it
Old 02-04-2013, 01:47 AM   #10
mod maniac
Member#: 300551
2&4 fxt & fxt sti
Fullers Garage
drive it with some boost and don't push it.
Old 02-04-2013, 12:43 PM   #11
Mastuss3055
Member#: 334085
How maby miles for a break in?
Old 02-04-2013, 12:44 PM   #12
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Google "subaru motor break in." It's easy, and just involves driving. No need for a "dyno break in." That's simply throwing money down the drain. Do your own research on how to do it and be educated.
Old 02-04-2013, 01:43 PM   #13
some dude
Member#: 100300
06 WRX
Does it need to be tuned? If its all tuned then just drive it easy for 1000 miles and vary the engine speed. Don't do full throttle much, especially at the beginning of the break in.
Old 02-04-2013, 03:35 PM   #14
Mastuss3055
Member#: 334085
I'm guessing it needs tune
Old 02-04-2013, 10:05 PM   #15
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Why are you "guessing" it needs a tune? Did you add components to the motor that would require a tune? Without giving us info, you might be throwing money right down the drain.
Old 02-05-2013, 12:23 AM   #16
Mastuss3055
Member#: 334085
I heard from a master subaru tech that when u add forged pistons you need to have it professional broke in to keep from any damage since I have never broke in a motor before
