#1 |
Member#: 49526
TXIC
Vehicle:2006 VF39 6spd Wgn SGM |
Dyno tune
Where? Cobb Tuning Plano, TX Temp Upper 60s Weather. Clear Car. 2006 wrx wagon Tuner, Calvin @ Cobb Trans. 07 sti six speed. Stock gearset. Gear. 3rd Max power. 353 @ ?rpm Max tq 339 @ ?rpm Stock wrx on this dyno ??/?? Target boost 21 psi Target afr. Unknown. Fuel. Pump 91 octane. Engine mods. Blouch 20gxtr turbo,2.4 inlet, 8cm hotside. Killer B header, DIY TGV delete's, dw850's, walbro 255, Process West TMIC, grimmspeed 3 port bcs, Samco Inlet, Ported intake manifold, Cobb intake, Helix catted 3 inch DP, Mad Dad 3 to 2.5in mid pipe, and Prodrive axle back. Here is the graph. ![]() So far pretty happy with the tune. Huge improvement over my old VF-39. Nice smooth power delivery. ![]()
#2 |
Member#: 56203
Tri-State
Vehicle:00 RSTI Coupe |
What did your VF39 make? Can you post the plot?
#3 |
Member#: 155696
Tri-State
Vehicle:2007 BLK STI Dom3XTR 415/405 Precision Tuning |
Wow man that looks really nice. Smooth power delivery, great spool and it holds the power well. Very nice. You must love it. Get some meth or e85 and crack 400. Lol
#4 |
Member#: 193222
MAIC
Vehicle:05 Wrx 1.5xtr 6spd 2.5 hybrid 367whp/363wtq |
Looking good!
#5 |
Member#: 180861
Vehicle:2005 wrx vf34 ppg's 93/E85 PhatBotti Tuned!!! |
Nice set up! Was the pull def done in third gear?
#6 |
Member#: 49526
TXIC
Thanks guys.
The 39 was never on a dyno, so no plot for you. Yep pull was in 3rd. Calvin said with the 07+ 6 speeds he uses 3rd because of the taller 4th and 5th gears. |
#7 |
Member#: 276209
MWSOC
Vehicle:I am Rub Function>Form |
How long do you expect the engine to last?
#8 |
Member#: 223839
E. Canada
Vehicle:2004 WRX Java black |
Nice graph, looks like a fun ride.
Full boost at 4000rpm on a 2.5l, I can't imagine a 2.0l! (probably 4500 lol) What would a normal 20g without the xtr reach full boost? 200-300rpm later? |
#9 |
Member#: 49526
TXIC
NO idea. I guess it will last as long as it lasts.
![]() Probably negligible difference between the XT ans XTR. Keep in mind it does spool faster on the street. Not a lot faster, but faster nonetheless. |
#10 |
Member#: 171773
South East
Vehicle:04 wrx sti jbp dom 3 xtr w meth! |
#11 |
Member#: 100300
MWSOC
Vehicle:06 WRX CGM |
Very nice graph! Good amount of stable torque in there and hp pretty much climbs to the end. How does it feel? Congrats as well, post some pics of the car.
#12 |
Member#: 346280
congrats man! looks very good. Could you post some pics of the car?
#13 |
Member#: 254371
MWSOC
Vehicle:2003 WRX, Sedan Platinum Silver |
Just out of curiosity, do you know what effect a 3" inlet housing would have in terms of power/ spool? I am thinking of purchasing a about the same sized turbo, Dom1.5xtr-ts, for my stroked Ver.8 ej207 but I am having a hard time figuring out what the advantages of going with either inlet housing would be.
Otherwise the graph looks awesome and I hope I have near the same results. Although I have been thinking about going w/ e85 as well, which would be a whole different ball game lol. -Luke |
#14 |
Member#: 161812
NWIC
Vehicle:06 Wrx STi CGM |
I'm sure a 3" inlet wouldn't hurt. It seems on some turbos it makes a big difference in spool. There is a thread of here from the guy that ran Deadbolt Turbos. He did some testing on the 2.4 vs 3" inlet on an Sti and concluded the gains in spool they saw had more to do with having to do tgv deletes to get the compressor cover to fit than having a 3" cover. I don't have empirical evidence but I bet it would make a difference on 60 lb/ min turbos in a rotated setup.
