Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Old 12-27-2012, 07:16 PM   #251
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Originally Posted by Maxwell Power View Post
The d25 head has a faster burning chamber than the b25. So in theory it can make more power at higher rpm provided you don't go crazy with the timing.
I know the chamber is more hemispherically shaped and smaller yielding a higher cr, it also makes sense that it has a faster burn cycle because of the hemi shape! Is Chrysler going to sue me for saying that? LOL
I just want to know what you feel the long block is good to. I know you only built me the short block but know the heads are very nice and flow well!
Thanks Dom for your input on this!
Old 12-28-2012, 10:04 PM   #252
manitou
Member#: 193757
2006 XTI Limited
Hey guys,
This is totally unrelated and a diversion from this thread, sorry Chris but I know you like Angel's work and he's a big proponent of Killer B products! I was in Angel Ortiz's shop (HP Techs) yesterday. Angel worked on my XTI's latest motor build, he is a Subaru guy at heart but works on some rowdy cars. I've been meaning to take a few photos of a couple of the unique projects they have going on. So here they are.
Datsun 1200 drag car with Rotary power plant. This car is getting a new rear wing and a new 3 rotor motor. With its last motor it ran 7.60's
Honda CRZ. I know, I know....but this one is a one off and will be kind of crazy! The owner is the local Honda distributor and he wanted to turn the wick up on his hybrid Honda. Angel's building the 1.5L motor and is doing a custom sleeved block, custom CP billet pistons, custom Carillo rods and custom crank. The PnP'd heads will sport custom cams. Pretty much all of it is one off stuff as there isn't any parts for this car/ motor. The motor will have a Garret GTX30 pumping it up! Angel thinks they should see 400WHP! Combine that with the electric motor's torque and it will be pretty interesting to say the least!
Again sorry Chris for the thread jack here but I wanted to share this stuff!
Old 12-31-2012, 07:14 AM   #253
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Two words I never expected to say together: bada$$ Datsun
Old 12-31-2012, 10:08 AM   #254
manitou
Member#: 193757
2006 XTI Limited
I know, I love that 1200 body style! That car is going 100 just sitting still!!
I can't wait to see this car making passes!!
Old 01-02-2013, 09:11 PM   #255
manitou
Member#: 193757
2006 XTI Limited
Injectors are swapped out, Juniors revised tune is flashed in and compression is solid, it idles perfectly and AFRs are right where they should be! We used absolutely no oil during Juniors dyno tuning session. If things are dry this weekend I will do some pulls with the XTI and send data logs to Junior to see where we go with it. I will report back with how it feels after some road tests!
Old 01-03-2013, 07:31 AM   #256
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Sounds good
Old 01-05-2013, 07:53 PM   #257
manitou
Member#: 193757
2006 XTI Limited
Well I got the XTI out for some road time today. 33 degrees, sunny and dry roads. It feels very strong and seems to be running well. AFR's look to be right where they should be but I was unable to record any data on either a 3rd or 4th gear pull. The damn Access Port cuts out when doing any pull while logging.
Junior mentioned to me that I should send it back to Cobb for a retrofit of the USB connector and a new cable. I will look into this but if anyone has any info could you please chime in here?
The other thing I saw today on the E85 tune with the colder 33 degree weather was 28.6 psi maximum boost. I was not logging but the AP recorded that as max boost! I think with the denser cold air here in Detroit I saw this additional 2+ psi of boost over the 26 psi map.
Old 01-06-2013, 12:37 AM   #258
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Nice to hear that ur getting some drive time. Def get some in car Speedo vids. I'm tuned at 26.8 and I was hitting 28.7 this morning in the 23 degree weather, scared the crap outta me.
Old 01-06-2013, 08:20 AM   #259
manitou
Member#: 193757
2006 XTI Limited
Thanks! Yea it freaked me out some seeing that boost level. The car loved the colder air for sure! I will get some in car speedo vids but can't remember if I have my gopro with me.
I just did another firmware upgrade on the AP last night so I'll see if that allows me to log some data today.
Old 01-09-2013, 12:02 AM   #260
manitou
Member#: 193757
2006 XTI Limited
OK, I got some good logs yesterday and today! They were all a bit short pulls though, especially 4th gear. I can't find anywhere around here that I can run it out to 140. That and the cars is idling well and driving pretty well at slower speeds. I say pretty well because the fricking thing is so hyper that it's not that easy to drive slowly.
I told Junior today that I almost can't wait to switch it over to pump gas cause it kind of scares me and it's gonna get me in trouble and I want to see what kind of gas mileage it's going to get. He laughed at me
Old 01-09-2013, 01:22 AM   #261
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
Should have gotten these headers and had a shop do custom 321SS EWG for me. Maybe next build lol
Tyrial is offline   Reply With Quote
Old 01-09-2013, 02:31 AM   #262
manitou
Member#: 193757
2006 XTI Limited
Here's some more detail from the logs I've run the last couple days.
Everything is solid and I still have not used a drop of oil from the 3.5 hour dyno tuning session, plus 4 tanks of E85 and all the pulls from the last few days!!
I sent Junior 5 logs tonight and we'll see what he comes back with. On one pull yesterday I saw 28 psi by 3640 rpm in 4th gear! Today another log 3rd gear showed 11 psi of boost at 3500 and then 23 psi at 4000 and it's holding 26-27 psi out to almost 7000 in 3rd gear at almost 110 mph, which has been as far as I can take it because I'm running out of room
Old 01-09-2013, 12:56 PM   #263
Maxwell Power
Member#: 190729
I really think you should start your own thread. You're turning a header testing into a thread about your build. I'm super stoked that you like your engine, but I think your own thread would do you (and us) better justice.
Maxwell Power is offline   Reply With Quote
Old 01-09-2013, 01:22 PM   #264
manitou
Member#: 193757
2006 XTI Limited
I will but no time to start one now.
Old 01-14-2013, 07:38 AM   #265
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
manitou, be sure to shoot me a link to the build thread when you get it going.
Old 01-14-2013, 09:55 AM   #266
manitou
Member#: 193757
2006 XTI Limited
Will do for sure. Please stand by....Kind of kidding as I am slammed busy with work and travel right now.
On the road and meetings until Friday eve., home for a day, then off to SLC on Sunday for show, then skiing with best bud around TRide and finally home on the 31st!! I'll be at home a total of 3 1/2 days this month.....aarrgh!
Old 01-14-2013, 09:57 AM   #267
manitou
Member#: 193757
2006 XTI Limited
Can't wait to see that Killer B set up for you know who's car!!! I think it will spool wicked fast
Old 01-28-2013, 08:11 AM   #268
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ Looking forward to that as well! and I owe you a phone call, have not forgot, just been dealing with sick family, weather related issues, and work. Playing catch-up this week!
Old 01-28-2013, 08:31 AM   #269
manitou
Member#: 193757
2006 XTI Limited
No worries on the call, I'm out west in the San Juan's this week visiting some good friends and backcountry skiing after working a show in SLC! We're getting some good pow now up higher elevations but a little higher avi conditions. I got that frickin head cold.....at the show so dealing with that as well....arrgghh It makes the climbing at 11000+' even harder!
Old 02-04-2013, 06:18 PM   #270
kpadill2
Member#: 266208
Here's a video of my car with the Killer B Holy header. I've got a cutout on my car but you can certainly get a sense of how this header sounds and performs.
kpadill2 is offline   Reply With Quote
Old 02-04-2013, 09:12 PM   #271
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Nice.
Old 02-05-2013, 08:53 AM   #272
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
700+ whp Subaru Bugeye - YouTube
Vader!
Old 02-05-2013, 09:55 AM   #273
manitou
Member#: 193757
2006 XTI Limited
Vader!
For sure! How many launches is that on the residential street with the 35 mph sign in the vid? you bad boy!!
Old 02-05-2013, 12:25 PM   #274
AKSubieDubie
Member#: 190003
2007 STI EFR 8374
Lol pretty good video editing. The Vader thing was funny hahah
It does sound like a rally car o_O
AKSubieDubie is offline   Reply With Quote
Old 02-13-2013, 12:29 AM   #275
wildt267
Member#: 161812
06 Wrx STi
CGM
I recently did that and am happy with results. The ap responds quite a bit quicker now. Cobb has very good customer service.
In regards to logging have you tried decreasing the number of parameters?
wildt267 is offline   Reply With Quote
Killer B Motorsport Header - Prototype Testing KillerBMotorsport Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 183 11-27-2012 09:10 AM
Killer B Motorsport - HOLY HEADER / Up-Pipe Released! KillerBMotorsport Vendor Announcements 52 03-17-2011 02:34 PM
Killer B Motorsport HOLY HEADER Group Buy KillerBMotorsport Vendor 'Group Buy' Classifieds 35 06-25-2010 02:18 PM
Vf48 Turbo (18g killer?) w/ WRX Install Results P&L Motorsports Inc. Engine/Power/Exhaust 5 03-25-2008 06:41 PM
